Question about Garden
Lawn Mower Starts, Runs at Idle Smoothly, but it will not kick up
When it hits thick grass
  • Dwain Pippen May 11, 2010
    Is it running at less than full speed when you crank it up and doesn't rev any higher? What is the Model and Type # on the engine?
  • 78 Answers
Ok it need a governor adjustment,depending on the brand of engine, there should be a tab with a spring attached. U need to bend the tab slightly to increase the rpms.
Posted on Oct 29, 2009
My mower cuts the grass fine but does not collect the grass cuttings which are left all over the lawn.
check and clean under deck --wet grass -to slow a speed - grass to thick/to high improper hook up of bag
Sep 15, 2016 | Garden
Procedure for adjusting valves on series 100 lawn mower
if you think it is a valve problem briggs and stratton website has a page that gives all the specs. for intake and exhaust vale setting. you will need to know your engine size and model number.
May 29, 2016 | Garden
Popular Pro 625 series. starts and runs but why does it die while cutting?
Poulan PR625Y22SHP Lawn Mower User Manual
homeappliance.manualsonline.com > ... > Poulan Lawn Mower
Poulan PR625Y22SHP Lawn Mower User Manual ... Briggs & Stratton 850Professional-Series Commercial Replacement Push Lawn Mower Engine (190cc, 7/8
Sep 11, 2015 | Garden
John deere instructions
Your mower doesn't have enough power to handle very thick grass at high speed. You need to go slower across the lawn. That's easy to do if this is a push mower (just don't walk so fast) or if it's a self-propelled model with a speed control. But if it's a single-speed model you'll have to mow the lawn in fits and starts: squeeze the lever to move it forward; release it when you hear it bogging down; wait for the motor to reach full speed; squeeze the lever to move it forward again; repeat. Also, is the grass very high? If so, try setting the cutting height higher on the first pass, then lower it for a second pass. Finally, make sure the blade is sharp.
Aug 06, 2014 | Briggs & Stratton 190cc 875 Series OHV...
It starts and runs for a bit but as soon as it hits thicker grass it dies
Joe Hi there. Sadly your trimmer will struggle on thick grass as it's not made for it. You could try moving the trimmer like a scythe. This will aid it as your cutting bit by bit.
Sep 27, 2013 | Husqvarna 28cc Gas Line Trimmer
Lawn mower runs, but moter runs slow and smells like its burning. I have owened the mower about 5 years.
If it has bhushes (90%), they may need to be replaced. Or the rotor may have been fried. You better start with the brushes, they are cheaper.
Nov 06, 2009 | Black & Decker 19" Electric Lawnhog...
Lawn mower engine stops while pushing
sounds like the float is set too low or you need to clean the carb.check the fuel filter and tank screen also.
Jul 29, 2009 | Poulan "" Push Mower
Billows of white smoke when Toro lawn mower runs
You overfilled the oil. If the mower runs, just go ahead and mow grass until it runs the oil out of the gas tank. Or you can empty the gas tank and fill with new gas. White smoke is not a serious problem. Only a hassle.
Jun 19, 2009 | Toro Lawn Mower With Toro Power Tools
Mower won't start
13 to 15 amps electric or battery operated mower may runs slow when cutting thick grass. also recommended not to cut grass when it's wet & need very sharp blade to do the lawn. may overloading it, cutting grass too thick also draws too much power. check house breaker first.
Jun 11, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
214 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
