Question about Casablanca Fan Casablanca B722 Blade in Rustic Iron
I need to clean the parts where the pan sits on.
I have an Baumatic hob. The material that the pans sit on are quite rough and black, the material is like the model B72BL.
It has stains on it but with washing up liquid it does not come off. I do not want to use anything that is too harsh and will reuin it. I have tried to scrub it but it wears away the material.
Will bicarb and white vinigar help to remove it? Or if you have a cleaner that I can buy to solve this problem I have.
I have put the Casablanca Fan in the 'product ' but I cannot find the model. I hope this is ok?
Many Thanks
Miss C Duff
    President:
  • 1,185 Answers
Buy a can of barbeque cleaner, spray it on leave it to work and then use a scrubbing brush to get into the grooves
Posted on Jun 04, 2009
My clients ceramic hob has small scratches appear on one of the pan areas it's only a week old how can this happen the pans seemed clean underside .
ceramic tops are not made for sliding pans or skillets on . as on GAS ranges. give them a bottle of cook top cleaning creme
Dec 22, 2015 | Bosch 233331 - GLASS CERAMIC HOB TOP
Oil pressure guage was working fine then just quit working altogether truck does idle rough could it be a problem with ignition sensor truck sat 6months
Did you change oil before starting after sitting 6 months? Oil goes bad just sitting, because moisture condenses in the oil pan, which leads to acid formation that can etch main and rod bearings. Best advice is get a mechanical oil pressure gauge and hook it up where electrical unit is now to check if your oil pressure is really low or not.
May 06, 2015 | 1995 Jeep Grand Cherokee
Need to put new gasket on transmission pan,to stop leak.95 ford-crown vic-overdrive 4 speed,automatic tranny
Jack up the car on a level surface, put jack stands and tire chocks in place. Drain transmission fluid, this usually involves loosening the tranny pan bolts on one side and letting it drain, some vehicles come with a plug like the oil pan. Once the fluid is drained, remove all of the bolts from the transmission pan. Make sure you remove ALL of the old gasket material from both surfaces with a scraper. You can clean out the pan with a commercial cleaner or just use a little gasoline on a rag and wipe the entire pan and gasket surface. Take off the old tranny filter and replace with a new one. there should be a small magnet sitting on the pan wipe it down also. Place new gasket onto lip of pan ,you may also use some sealant if leakage is an ongoing problem, then re bolt to the transmission. DO NOT OVER TIGHTEN BOLTS!!!!! Refill transmission fluid at the dipstick and DO NOT OVERFILL !!!! CHECK FLUID LEVEL
Aug 27, 2013 | Transmission & Drivetrain for Ford Transit...
My bread pan doesn't sit correctly so the paddle doesn't move around well, especially when it kneads faster
First pull the springy steel clips out so they bend some and stick out a little further this will hold your pan in better. Before putting your pan in make sure the little ears on the underneath side of the pan are lined of roughly opposite of the pan ears in the bottom of the oven that push the paddle around. If that doesn't make sense contact me.
Oct 01, 2011 | Cuisinart CBK-200 Bread Maker
Hello. I have a new hotpoint CIO644 induction hob but when I turn a hob on, and put a pan of any size on the hob, it start ticking. The ticking stops when I take the pan off. The display shows the setting...
Hi
I'm not sure that you really have a problem as with induction hobs you need to put your pan (metal only) with the ingredients in it on the hob before switching the heater on.
it is the pan which will get hot, the ticking may or may not be the pan heating up.
Try it with water only in the pan and see if it works.
Dec 20, 2010 | Hotpoint Ovens
My 58 Chevy 348 engine is holding oil in the upper part of the engine I've checked the oil before starting and it is full but after approx. 2 min. running the oil pressure is gone. I check the oil again...
Try using high pressure air to blow out oil returns. The engine may have sludge build up due to foreign material sticking in oil drains from a 52 year old chevy. Love that engine. It was good in it's day! Good luck!
Sep 05, 2010 | Chevrolet Impala Cars & Trucks
The drip pan that sits under the freezer side of our Kitchenaid Superba side by side refrigerator is full of nasty looking black water that I wanted to clean out but I can't figure out how to get it out of...
well to take that out ? which isn't normal part of it the drip pan catches water from the fridge / freezer and is caught in the pan while the evaporator generates heat to dry the pan out!! so if you really must remove it then you have to remove the wire in front of it to get it out other wise you just unplug it and reach in there with a brush to clean it
Jan 20, 2010 | KitchenAid Superba Architect KSCS25INSS...
Smoke from top of stove
no it means that what ever spilled on the elemnet drip pan has not completely burnt itself off. replace the drip pan at first chance you get
Mar 23, 2008 | Kitchen Ranges
Casablanca Fan Casablanca B722 Blade in Rustic Iron Logo
41 people viewed this question
Top Casablanca Fan Dryers Experts
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
