Question about Hunter Low Profile III 20807 Ceiling Fan
Fan stopped running
Fan was running fine, switch direction, heard pop sound and now fan will not run.  Get a low wine from motor but no rotation.
    Genius:
  • 1,036 Answers
Most likely the "pop" was either a capacitor (used in some fans to offset windings) or one of the coils going open circuit.
Turn off everything and remove it.
Look for the obvious first - hole in component or charring. Then check coils and switch for continuity, Then on to any control circuitry in there.
Posted on Jun 11, 2008
Minka gyro fan noise, my fan has a popping sound at the same point in each full rotation.
i'd take it back and get a replacement. It has a lifetime motor warranty. I used to sale Minka Aire but always had motor problems.
Apr 19, 2013 | Minka Aire F602-BNCH Gyro? Fan
Noisy when running
condenser fan blades are cover with lint or the fan motor may be going out. Clean fan blade first before doing anything else. If noise stops after cleaning the fan blades; hooray! If not you might have to replace the fan motor itself. Test and re-check before taking other step(s)
Jan 04, 2011 | Haier BC112G Wine Cooler
Kenmore over the stove microwave,model # 721.62629200,only low speed fan works on the keypad,no high speed fan.
The fan has a setting for high speed, low, and off. Fan only running at low speed.This indicates problem towards. 1) the fan motor. 2) The loose fan wiring. 3) The fan switch. IN the unit there is a motor for fan.If the motor gets weak or short. The fan will run but only at low speed.Because at high speed the motor will require more power to run.In this case motor needs to be checked and replaced. The other possibility is the fan wiring.There are two wires going from fan to motor and two going from motor to power board.If any of this wire is got loose or getting short then this will stop the fan to run in high speed.In this case the wires needs to be checked and reconnected properly. In the unit there is a switch internally.When you select the fan to high speed mode the switch goes up. when you select the fan to low speed mode the switch turns down.But if the switch is faulty or got worn out.Then it will not move properly up/down.In this case switch needs to be replaced.IN some brand models the High speed and low speed are directly controlled from front control panel.There is no switch in that models.In that case the control panel needs to be checked and replaced. Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Jun 10, 2010 | Kitchen Ranges
A/c suddenly stops blowing
Maybe your blower fan is faulty.
The whine you heard could be dry/seized fan motor bearings or foreign matter (such as leaves/twigs) in the fan.
If fan motor is faulty it will need to be removed for repair; but first check as below:-
1) Check fuse is ok.
2) Check motor runs if power applied directly to it. - If motor OK, check:-
3) speed resistor module (usually in fan ducting, in air flow),
4) fan switch operation.
Sep 21, 2009 | 1987 Oldsmobile Toronado
Fan motor comes on, however, when a/c is turned on, breaker pops
If the unit is working fine in heat mode and in fan only mode, you have a short in the wiring going to the ouside unit. If it were a fan relay, then everytime the fan came on the breaker would trip. But either way, there is a low voltage short taking place in the unit. If the compressor was bad, the indoor unit would run fine and would only blow the breakers to the ouside unit. I had a unit last summer that did the same exact thing. After I replaced the control wiring to the outside unit, everything worked like a charm. Good luck!
Apr 04, 2009 | GE Heating & Cooling
Riello 40 F5 oil burner, on boiler, intermittently running
with a forced draught burner the fan motor would be checked via a pressure switch. if the pressure switch is not set correctly or the fan is too weak the contacts will not be made in the switch and the burner will lockout. if the damper is not open enough when the fan runs then the air supply will be too small for the switch to make. check to see if you have a capacitor on the fan windings if this is faulty then the fan will fail intermittently.
Jan 19, 2009 | Heating & Cooling
Lasko E20739 Fan
It sounds like the electronic controls have put the fan into "breeze mode". The fan turns slowly then is supposed to surge back to high. Some people love this feature for some reason...
Disable breeze mode via your remote (its the button with the stacked ~'s).
A bad motor wouldn't rotate at all. The only other problem might be the motor's running capacitor. If you can start the fan in either direction (give it a hand spin in the opposite direction of rotation) you have a bad capacitor...and you can find a replacement anywhere (Radio Shack).
Aug 03, 2008 | Lasko 2530 Elite WindTower Fan
Hunter Bayport Fan
You need to get the running capacitor replaced then it will work fine and its a very low cost part.
Jun 16, 2008 | Hunter 20404 The Bayport Bright Brass...
Hunter Low Profile III 20807 Ceiling Fan Logo
123 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
