Question about Toro Lawn Mower With Toro Power Tools
Toro GTS5 600 has not been used for 3 years, it starts on choke with a spray of engine starter then stalls out when choke removed Jim Slezak slezakj@yahoo.com
  • 1,040 Answers
You will need to buy a carburetor kit and replace all appropriate parts. Use a Den Tek Brush,(http://www.shopping.com/xPO-Lustrasilk-Lustrasilk-Cholesterol-Shea-Butter-Mango-20Oz-Bonus), to clean the small portals in carb.
Jim
Posted on Jun 06, 2009
  • Jim Parker
    Jim Parker Jun 09, 2009
    Did this solve the problem?
    Hear is a working link to the Den Tek Brush:(http://www.drugstore.com/products/prod.a...).
    Jim
  • Jim Parker
    Jim Parker Jun 10, 2009
    Thanks for the rating!
    If you should have any questions about "Drywall Finishing/Patching, or know someone who does, put your questions to Category: "Tools- Building & Power- Hand Tools" at FixYa.com
    Thanks Again,
    Jim
Have a self-starting, self propelled toro lawn mower about 5 years old, I ran it out of gas by accident & now it won't start
It seems to be an obstruction in your fuel delivery system. Get a can of ether and a spray a short burst of it into the breather area near the carburetor, if the mower starts up and then stalls out, then you may need to get your carburetor serviced.
Dec 18, 2013 | Toro Lawn Boy Self Propelled CARB Walk...
I have a Toro 20462 power mower -- about 15 years old, but until just today still running great! The spark plug is good, the gas is good, the oil is good the air filter is good. After priming, it starts...
Remove and clean the brass bolt that holds the float bowl on the carburetor. Clean out the bowl too. Use no metal objects to clean this bolt. It has 3 small holes...bottom...and on the sides near the top. Use carb/choke aerosol spray cleaner on it. IT can clog (esp. without an inline fuel filter on mower). Clean the bolt good, reinstall (not forgettting felt gasket between IT and the bowl) and your runnability problem and fuel flow problem should be solved as the bolt is also the main jet of the carburetor.
Sep 11, 2011 | Toro Power Lawn Mower
Engine starts but won't continue to run. Choke doesn't stay closed after starting. will stay running only if I hold choke closed manually.
let it warm up with choke closed manually after it starts to stall with choke closed open it and dont let it stall u can learn to play with the choke a little to get it to run right GOOD LUCK!
Aug 14, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
My 1984 rx7 starts when choke is pulled out. WHen engine warms and choke pulls in it stalls out. when trying to start it back up the engine sounds like it's trying to start, and it does when I pull the...
try removing air filter and spaying CARB CLEANER in carb while holding open intake rub thouroughly with hand in side carb, start vehicle and run... spray more cleane and by hand throttle open and spray reinstall filte and runner good on open stretch of highway.
see how that works
Apr 27, 2010 | 1983 Mazda RX-7
My echo srm-210sb will start and run, but only if I carefully find the right spot on the choke lever; like at almost full choke. Turn off the choke & engine stalls.
Check the fuel lines for cracks/breaks. If they are o.k., then:
Youwillneed to disassemble the carburetor and spray withcarb.cleaner.Makesure the small screen is free of debris. (Should beable to see daylightthrough it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Dec 02, 2009 | Echo Garden
Troy built 2 cycle trimmer/ only runs when choke is on. already changed out oil/fuel mixture. Engine will not accelerate, when I try it dies
First, check the fuel lines for cracks or breaks.
Second, Disassemble the carburetor and spray with carb. cleaner. Use a Den Tek Brush,
(http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in the carb. Make sure the small screen is free of debris. Reassemble and start. If you need further assistance, just let me know.
Jim
Jun 07, 2009 | Toro Lawn Mower With Toro Power Tools
Got a Craftsman 6.25 HP push mower. Had it for just over 2 years. I pulled it out of the garage to mow the grass the other day, and it would not start. I used some starting fluid and it started right up....
Check the fuel line for cracks or breaks. Check the fuel filter if it has one. And finally, you may need to disassemble the carburetor and spray with carb. cleaner.
Jim
Toro mower dies when i try to pull out
Disassemble carburetor and spray with carb. cleaner. Use a Den Tek Brush,
(http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Make sure that the small screen is free of debris. Reassemble and start.
If this doesn't work, then you will need to buy a carb. kit and replace all the appropriate parts.
Jim
Jun 06, 2009 | Toro Lawn Mower With Toro Power Tools
Toro recycler will run until primed gas is consumed.
The problem is that the gas that sat in the carb all winter glazed it over and gummed it up. Begin by going to any auto parts store, like an aiutozone, and getting a bottle of carb. cleaner. Seafoam is one I use. Add it to your gas, one ounce per gallon of gas. Also, pick up a can of engine starting spray.
Remove the air filter and spray the engine starting spray into the air intake. Pull start the engine and give it additional squirts of engine starting spray until it runs smoothly.
May 30, 2009 | Toro Lawn Mower With Toro Power Tools
Engine starts and then stalls out
I don't believe it's the button.
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
Jim
Apr 11, 2009 | Toro Co M/R Blwr/Trmmr Rear Bag Kit
Toro Lawn Mower With Toro Power Tools Logo
1,060 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
