Question about Lexmark X83 All-In-One InkJet Printer
It prints ok, but paper is blank (no ink at all)
When I print or copy something, paper feeds ok, printer head also moves fine, but nothing is printed on paper (no ink). I thought I run out of ink or something, so bought a new cartridge. But the issue still exists. Your help is appreciated! Thanks.
  • 2 more comments
  • redknot Apr 30, 2008
    my printer prints out blank pages i just refilled the cartledges what can i do
  • Anonymous Mar 20, 2014
    I ahve an epson 2000p that won't print all. The head moves back and forwards, the paper feeds through on print command, but nothing prints.
  • Anonymous Mar 28, 2014
    the printer engages like it is about to print and sounds like it is printing but nothing on paper
    any solution for blank papers in printing out copies
Bought new ink and still the paper is coming out blank
Posted on Jan 04, 2009
  • 2,035 Answers
1. Remove the protective tape from the cartridges:
1. With the printer power on, open the front cover of the printer. The cartridge carrier should move to the middle.
2. Remove the cartridge(s) from the printer.
3. Look on the underside of the cartridge(s). If there is yellow tape and/or transparent blue tape there, remove it.
2. Clean the cartridge nozzles:
1. Go to the Lexmark Control Program or Solution Center and run the Clean print nozzle test.
If a black cartridge is installed, you should see black lines only.
If the color cartridge is installed, you should see yellow, magenta (a reddish purple), and cyan (a dark sky blue) lines.
If a photo cartridge is installed, you may see different colors.
2. Examine the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right, with no gaps.
If there are gaps in the lines, you could run the Clean Print Nozzle page a few more times to try and clear it up or try the "wicking" procedure below to conserve ink.
If the page is faded from left to right and the wicking procedure doesn't clear it up, your cartridge is probably out of ink.
3. Clean ("wick") the cartridges:
1. Remove your cartridges following the instructions in your User's Guide.
2. Take a warm, damp paper towel and fold it so that it has about 4- to 6-ply thickness.
3. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are touching the towel, and hold the cartridge in this position for about 15 seconds. The nozzles are where the ink comes out of the cartridge.
4. Now drag the cartridge lightly across the paper towel in one direction only (left to right) until the bottom of the cartridge looks clean.
5. Turn the cartridge over so that you can see the bar code sticker on the back. Note: Only perform steps 6 and 7 if the contacts look dirty or corroded.
6. Using a clean pencil eraser, clean the contact points on the copper strip (only the little squares just below the bar code). Caution! Do not use the eraser on the nozzles that were cleaned, as this will damage the cartridge.
7. Using a clean part of your dry paper towel, wipe the eraser dust off the contacts; ensure that they are dry, and snap the cartridge back into the printer.
8. Make sure to install the cartridges following the instructions in your User's Guide, selecting Old Cartridge. Failure to do so could reset your ink levels as explained above.
9. Repeat the nozzle cleaning procedure one more time. At this point the diagonal lines should be solid.
10. If they are not and you think the cartridges should have ink in them, contact our technicians by e-mail and let them know the results of this test.
4. Reset the ink levels:
Lexmark printer cartridges do not have ink sensors. The levels of ink are produced by a mathematical calculation of ink drops and page counts. The printer stores this information and then writes it to the win.ini file on your computer.
Ink levels can be reset by telling the printer you have installed a new ink cartridge or by reinstalling the printer drivers and selecting Cartridges Installed. Once ink levels have been reset, there is no way to change them except by printing.
Accordingly, even if your computer says that your ink is full for a particular cartridge, it may be incorrect and the cartridge may need to be replaced. You may want to try a new cartridge to see if that clears up any print quality problems.
Posted on Mar 24, 2008
Trying to copy and nothing printing. Ink levels are good, paper is coming out
Perform "clean print heads" in printer properties select printing preferences,service then click clean nozzles, perform twice or thrice then do the nozzle test, if print heads are recovered your will be in safe, other wise***Two print heads are in this printer each print head leads two colors, left print head leads black & yellow and other one leads cyan & magenta. You need to replace the print heads based on the color which missed.
Jan 03, 2012 | HP Officejet 6500 Wireless All-in-One...
My EPSON Stylus Photo 1400 Ink Jet Printer is printing blank photos. The ink levels are fine, it's feeding photo paper fine, it's making the same noise as it does when it prints but the photos are...
Your problems states that photos are being blank when trying to print it.
Please try these tips.
  • Make sure your printer is selected in the Print window or in the Macintosh Page Setup and Print windows.
  • The print head nozzles may need cleaning.
  • Make sure your printer software settings are set for the paper size you're using.
Plus,i also wanted to know if you can print ordinary documents or print a test page.
Hope this helps.
Sep 09, 2011 | Epson Stylus 1400 InkJet Photo Printer
Prints blank pages
check if there is still ink in the cartridge.also use a soft cloth and little water to clean the nozle of the cartridge.
Jul 02, 2009 | Epson Stylus C62 InkJet Printer
Epson R220 won't print. Paper feeds through OK, print head moves as if printing but no ink comes out. Tried several sets of cartridges and this makes no difference. Cartridges are recognised fine and no...
Nothing at all? Problem with micropiezo (micro pump) at head. But you said, replaced print head. So it might just lost electricity to head (problem with board).
Jun 10, 2009 | Epson Stylus Photo R220 InkJet Printer
Epson C63 printer, printing process is fine. Cartridge is fine. But nothing was printed on the paper.
Check the flow of ink. Move head to the parking position/head cleaning position. Do suction from outlet of head cleaning mechanics. Is there is ink "out from outlet", head isn't clog. then, if still nothing to print, the problem is micropiezo (micro pump) of head. Lost contact/lost electricity or damage.
May 30, 2009 | Epson Office Equipment & Supplies
Black ink smears everything.
you may have to clean the print head. since the jam cause the smear, and there still have some ink left on the print head.
you wouldn't get aclean copy till all of the ink trace are gone.
May 20, 2009 | Canon Office Equipment & Supplies
HP All-in-One Printer Series 1300 prints blank copies
Have you tried printing a test page from the printer itself. usually holding down the power button will instruct the printer to print a self test by itself.
Mar 10, 2009 | HP Officejet Pro L7680 All-In-One Printer
Not printing at all!
Change your cartridge and then try again
Sep 23, 2007 | Canon i9900 InkJet Photo Printer
BJC 4550
chech if the ink cartrades are plugged in tight in they are check if all the chords are plugged in if that doesnt work go to a tech man or get a new printer
Jul 08, 2007 | Canon BubbleJet i550 InkJet Printer
Lexmark X83 All-In-One InkJet Printer Logo
520 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
