Question about Emerson Em1200 Answering Machine
I can,t figure out how to set the number of ring,s. Please help me. Right now it only ring,s twice.
    Brigadier General:
  • 3,614 Answers
for clarifications of your problem; first I want to know what the exact phone model that you have, & also do you want a user manual for that if I still have the save file.
Let me know
micro
Posted on Jun 05, 2009
We have the Avaya Partner phone at work and no one can figure out how to silence the ringer. I can get the volume down but not off.
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Central telephone Programming.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing..
Press feature "00" to logout
Sep 22, 2010 | Avaya 700340193 Corded Phone
# of rings
that information is in the user manual which can b down loaded from the hp site.. or simply go into the menu on the display and into setup you should find it
Mar 31, 2010 | HP OfficeJet J4580 All-In-One Laser...
I am having trouble with setting up the fax function with my phone line. I have one line I am trying to use for both phone and fax. I am able to receive faxes automatically when I am not on the phone. ...
You need to make sure that the line from the wall jack is plugged into the "Line" jack on the fax then the phone is connected to the "Phone" or "Out" jack. You might want to check the number of rings before your fax picks up.
Oct 14, 2009 | Office Equipment & Supplies
Need phone to ring more than twice before going to message
CLICK HERE for your owners manual in PDF format.
However the model # is for an external handset (add-on)
The number of rings is set on the base.
Please post the Model # of the actual Base unit for help on the answering machine.
Thanks for using Fixya - a Very Helpful rating is appreciated for answering your FREE question.
Jul 30, 2009 | Panasonic KX-TGA101S Cordless Handset
Need to change the pickup from one ring to picking up on the 5th
This should do it:
Press the {Function} {6} then enter
the access code {2} {2} {2} {2}.
Then press {6} {1} and the {Yes} key
press the 'next' (right arrow) key until it displays "set number of rings" . Press "yes" (the current setting is displayed). Press "no" to change. Enter the desired number, then press "yes" to set. Press "function" to exit.
Please rate me :)
Mar 14, 2009 | Ricoh 2050L Laser Fax
Trying to change number of rings before voicemail
By default individual coverage is set to 45 seconds. Ask your phone vendor to reduce it.
Feb 20, 2009 | Avaya 5400 Series 5410 Phone
My Phones only ring twice before it goes to VoiceMail
What you can do is go into the management console for your system and find the forwarding this is under extentions option 2 fwd/dnd select your extention number and on the bottom option FWD No Answer Time (s) set it to 10 or more and this will change the number of rings.
I use a KX - TDA600 PABX so I hope this helps
Jan 06, 2009 | Panasonic KX-T7630 Corded Phone
Cannon Fax JX200
The JX200 has four modes of fax receipt - Fax/Tel, Manual, Answering Machine, and Fax Only. The Fax/Tel mode, which appears to be your setting, is meant to let the fax machine automatically switch between fax and voice calls. Documents are received automatically, and the machine rings for voice calls based upon the times that are input in the settings of the machine. It would seem that the best thing to do would be to lengthen the times involved - particularly at step 7 below. I would imagine it is set at a low number - perhaps 10 seconds or less - and needs to be increased to give you sufficient time to answer the call.
Set the mode by pressing [Receive Mode/Resolution]. Every time you press [Receive Mode/Resolution], the mode changes cyclically.
If you set Fax/Tel mode, you can control precisely how the fax handles incoming calls by adjusting the following settings:
• Adjust the time the fax takes to check whether a call is from a fax machine or a telephone (<RING START TIME> setting).
• Adjust the length of time the fax rings when the call is a voice call (<TEL RING TIME> setting).
• Set whether the fax switches to receive mode after the ring time set in <TEL RING TIME> has elapsed (<DEFAULT ACTION> setting).
1. Press [Menu].
2. Use arrows to select <DATA REGISTRATION>, then press [Start/Copy]. The LCD displays <USER SETTINGS>.
3. Use arrows to select <RX SETTINGS>, then press [Start/Copy]. The LCD displays <ECM RX>.
4. Use arrows to select <FAX/TEL AUTO SW>, then press [Start/Copy]. The LCD displays <RING START TIME>.
5. Press [Start/Copy]. The LCD displays <8SEC.>
6. Use the numeric buttons, or arrows to enter the time the fax waits before ringing when it receives a call, then press [Start/Copy] twice.
7. Use the numeric buttons, or arrows to enter the time the fax rings while waiting for someone to pick up the Handset, then press [Start/Copy] twice. The LCD displays <RECEIVE>.
8. Use arrows to select <RECEIVE> or <DISCONNECT>, then press [Start/Copy]. This setting tells the fax what to do if the Handset is not picked up within the specified ring time set in step 6.
9. Press [Stop].
Setting ends and the fax returns to standby mode. The machine will now handle calls as indicated in the settings you input.
It may take a few rounds of going through these steps to get the settings just right for your situation, but it should definitely solve your problem. If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently, and I will gladly help you until we have reached a definitive solution.Thank you for using and rating FixYa!
Jul 13, 2008 | Canon FAX-JX200
Lost programing
From extension 10.
you have to set the ringing.
feat 00
left intercom twice
right intercom once
enter ext number
touch the lines util they display how you want them to ring
feat 00 when done.
To set the feature to p/u a ringing call
feat 00
left intercom twice
right intercom once.
press: ** (then press lines in order 1, 2, 3, 4, etc)
then press ** again.
feature 00
repeat both for all extensions.
Mar 05, 2008 | Lucent PARTNER18 Corded Phone
Emerson Em1200 Answering Machine Logo
108 people viewed this question
Top Emerson Lands Phones Experts
Computer Repairing
Computer Repairing
george  peters
george peters
Are you an Emerson Lands Phone Expert? Answer questions, earn points and help others
