No pic I have no pic just beeping or ringing noise what is the problem with my tv it's a samsung crt hdtv  txp3064w
When it makes a buzzing noise turn it of well unplug everything and plug back in after 30 secounds it should work if not it will not go away for 1 to2 months. Hope it works
Posted on Mar 28, 2009
  • 8,457 Answers
Ur hight voltage transformer is dead,the FBT the flyback transformer.The big block of plastic with a red wire with a cap hook up to ur CRT(tv tube).That thing it dead that where the noise came from.
Posted on Sep 03, 2009
Samsung hdtv plasma ringing noise
the echo is probably a expanded stereo or something that you have turned on in the menu under audio. do yourself a favor,reset all your menu settings. the ringing,could be something more,coil on the buffer boards??? Check out http://www.shopjimmy.com/ they have tech assistance plus the best prices
Sep 06, 2012 | Samsung HP-P5581 55 in. HDTV Plasma...
I cleaned out my Samsung hl-s6187w and put everything back together and now it doesn't turn on. It makes a beeping noise like fast morse code and keeps cycling the power trying to turn on. The ballast gets...
Tv projection lamp inside the tv less than 2 years or so?Yes than the tv projection Lamp is good.You have this tv like 3 or 4 years already?The tv colors wheel even have been replace at leat once?No the tv probally require replacing the colors wheel these tv have to replaced the colors wheel every now and than.
Apr 14, 2011 | Samsung HL-S6187W 61 in. HDTV
I have a rubbling noise when the TV is on. The picutre and the the souind is clear although you hear this loud rubbling (bad bearing noise) fromtheback of the TV. When you turn the TV of, the noise is...
This DLP tv have a colors wheel.No,the colors wheel is dying,just not dead yet.It spinning off of it motor axis,when it total dead it will have black&white pics,very loud squiling motor noises.Ur tv need a new colors wheel.Call the tv repair tech for this job,require take out many machanicals parts,before even can take the colors wheel to replaced.Never done this before,don't atemp to replaced the colors wheels ur self.
Jun 14, 2010 | Samsung DLP HL-P5663W 56" TV
When i turn my samsung 50, no pic or sound 3 lcd lights keep flas
Hi friend,,,
welcome to fixya
Commonly for plasma tv's if the screen went out,,the problem will be the CATHODE RAY TUBE,it is costly to buy.if you want you can buy it,,or it may be the D-board problem will be also,,,
but it is unusual,so check the tube.
if your satisfied with my solution PLEASE RATE IT
thank u...
Apr 09, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
The problem I am having with my samsung tv is it has just recently started to make a hissing sound that I can only describe as the noise of a gas leak ...the pic etc is ok only having problems with sound...
This is a High Tension "Leak" this is a frequent occurance, it is the High Voltage drive to the screen that causes it. really you should have it looked at by a professional serviceman get a firm "Quote" for any fix before you proceed.
Jan 31, 2010 | Samsung DLP HL-P5663W 56" TV
Annoying noise from back of tv
If its a DLP tv its the color wheel, If its a conventional rear projection sounds like flyback.
Apr 03, 2009 | Samsung Televison & Video
Bought a used lg ru52sz51d
It sounds to me as though your old HDTV has a HD tuner built in. Not all HDTVs do and unfortunately your LG does not (I looked it up).
If you want to get free over the air HD you will need to buy a HD digital tuner box and an HD antenna.
Jan 07, 2009 | LG RU-52SZ61D 52" TV
Video appears distorted--halo like
check your sharpness setting, it should be very low and even in the negatives possibly on a plasma. I was told the sharpness option was for crt tube tv's anyway
Jan 05, 2008 | Panasonic TH-50PX75U Plasma HDTV
Weird noise over everything
According to the Samsung website: "The high pitched sound you hear is probably coming from the flyback transformer. The flyback transformer converts the relatively low voltage electricity that comes from the outlet in your home to the high voltage electricity needed to drive the cathode ray tube in your TV. It is not unusual for a flyback transformer to buzz softly when it operates. However, if the sound is loud and high pitched, it probably means the transformer is failing. To eliminate the sound, you will have to get your TV serviced."
Nov 08, 2007 | Samsung SlimFit TX-S2783 TV
Color rings on hdtv
Sounds like a CRT (picture tube) that did suffer a bit of a blow to it. The rings are caused by the thin sheet of steel inside of the CRT called a shadow mask being warped. The other cause for this is the internal degauser in the TV comming on and staying on too long causing damage to the CRT. Either way the CRT is over $400 plus you will need to find out what caused the issue and repair that first.
Apr 17, 2007 | Samsung TXP3275H 32" TV
Televison & Video Logo
695 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
