JVC Audio Amplifier model AX-22bk no power. All that lights is the leds above the function buttons. No output. No action from the relay on the main pc board, also No schematic.
5 Suggested Answers
  • 10 Answers
SOURCE: need information
Try http://www.servicemanuals.net/
They are not free, but the amplifier service manuals I have purchased through the site have been very good.
Posted on Jan 02, 2008
SparkGap
  • 363 Answers
SOURCE: Audio Amplifier JVC Model A-GX3
If the service manual is not available on the JVC websites then you should just Google search "JVC A-GX3 service manual" There are many websites that archive manuals. You'll probably have to pay for a copy. Why can't you disassemble the unit and see the output transistor numbers first? More importantly how do you know this is the fault?
Posted on Sep 22, 2007
SOURCE: JVC AX-66 Integrated Amplifier seems to be muted?
You need to have a jumper between the 4 standalone jacks on the right side of the column of stereo connectors. A stereo RCA cable would work for this.
Posted on Oct 14, 2009
  • 8 Answers
SOURCE: Got a crown amplifier XLS 602 its powering up the relays are clicking, all voltages seems ok the signal led's are on but there's no sound output on both channels. I manage to trace the signal
Check your input or output cables might be dirty I had the same problem
and 1 of my output wire was dirty so i sprayed tha electric cleaner and its all good now
Aloha
Posted on May 21, 2012
Aloha
May 21, 2012 | Crown XLS 602 2-Channel Amplifier
Technics SU-G75, No Speaker Output, Headphones Work. So I woke up this morning to find that my roof leaked ...onto my laptop and stereo. I love this amp, bought it new with all accessories in 1993,...
The fact you have output from the headphones is a good sign. It shows the main amp is working fine. However water has clearly got inside something and affected it. The best course of action is to trace back the wires from the headphone socket and see if there is a relay or anything that could get water in it. If you do find something, try applying warm air from a hairdryer. The alternative is to apply a soldering iron to the solder conections of the device. This should get rid of any water inside. If all else fails you might have to replace the relay. But I would try a spray of Servisol first. Just in case some dust has got inside or mineral salt from the water.
Nov 09, 2011 | Technics SUV500 2-Channel Amplifier
Stereo amplifier shutdown.
  • The amplifier is showing the protect mainly due to a safety feature on the power circuit. The fault could be failure or short in the output stages, short in the speakers, fault in the power ciicuit or the error amplifier that triggers the relay.
  • To trace the fault it is impotant to make the test in the main board, disconnect the power to output to confirm if the output is faulty. similarily disconnect the powering circuit one by one to identify. replace or disconnect to confirm. Hope this helps. Good day
Jul 11, 2010 | Sony Audio Players & Recorders
I want to connect YST-Sw1500 sub woofer to the AX-596 amplifier .How can I do the connections .
on ur subwoofer u will see HPF output, connect this output to MAIN IN of ur power amp (first remove jumper between pre-out and main in from ur power amp) connect pre-out of ur power amp to input 2 L&R (Left is also for mono input). the HFP selector switch will cut off 80Hz or 100Hz to the main input depending on the position enabling u to have high frequency sound on your main speakers. connect the speakers to the main output terminal of ur power amp. do not connect speakers on the woofer ouput.
make sure u are using the right impedance speakers. do not switch speaker impedance selector while the unit is on.
Apr 04, 2010 | Yamaha AX-596 Amplifier
How do i turn my protector light off of my amp?
I'm not really sure how your amp works but i can tell you that if that light is on there is probably something wrong. Check your ground wire. Also it could be your not getting enough power to your amp, or too much
Mar 06, 2010 | JVC KS-AX7300 Car Audio Amplifier
Oct 14, 2009 | JVC Audio Players & Recorders
Unbalanced LEDs> amplification problem, or mere graphic drop out?
This could be a defect in the metering circuit. In order to verify this, you should measure the output externally. Get that external measurement and post the results here. We'll continue from there.
Dan
Apr 12, 2009 | Yamaha DSP-AX1 10-Channel Amplifier
Audio Receiver Input Selector
i , too, i working with Amplier sony TA-V715
Apr 03, 2009 | Sony Audio Players & Recorders
Orian d5000 amplifier
output module probably gone, or switching relay stuck. Refer your problem to a certified tech to avoid injury.
Oct 26, 2007 | Orion HCCA-D5000 Car Audio Amplifier
324 people viewed this question
 Grubhead
Grubhead
