Question about Cooktops
Oven wont turn off i unpluged it last night and it turned back on this morning when i pluged it back in
  • enigma_41_99 Jun 04, 2009
    this whirlpool modle has a control board do you think it's bad
  • enigma_41_99 Jun 12, 2009
    thank you i pulled the board off and disconnected the power line to the oven and it reset the oven now it works just fine. thanks again
    President:
  • 1,185 Answers
If you have turned the on/off switch to off and the oven stays on then the on/off switch contacts have fused together inside the switch.
If it were the thermostat it would get hot but would shut down in the off position
You need a need switch as simple as that
Posted on Jun 04, 2009
  • Tom
    Tom Jun 07, 2009
    The user control should have a switch inside it to take the power off the board which controls the oven
    If the switch clicks when you turn it off then it should open circuit and kill the pcb
    When you turn the control switch up and down does the oven get hotter and colder.
    If so then the control board is doing its job and I would go for the main switch as being the problem
    A man with a meter can test it out in a very short time
Maytag gas range oven wont cycle
it could be the thermocouple . or thermostat .
Feb 09, 2016 | Maytag 30" Free Standing Gas Range -...
How to fix gas burners
The electronics are controlled by AC using a simple plug usually. If you can locate the plug and reach it you may be successful resetting things by unplugging the cord, wait a minute or two and then plug cord back in. Try the burner controller again. If still doesn't work then controller module may need to be replaced.
Oct 14, 2014 | Dacor DR30DLP-H 30" Distinctive Dual Fuel...
Electric range
Good Morning Kent, thank you for allowing me to assist you!
Typically error code F1 on your Frigidaire appliance indicates that your range has detected an issue with the runaway temperature (overheating). One of the best ways to determine if this is a false error code is to reset the power to your appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, at this moment I would suggest connecting a professional to proceed further. Most likely the EOC (Electronic Oven Control) or RTD Probe (Resistance Temperature Detector) will need replacing. I hope this information helps to some degree.
Feb 05, 2014 | Frigidaire Stove/Oven/Range White Cooktop...
Caps come on my cooktop but indicator light wont come on
Hi George - Thank you for your post! Let's try resetting the cook-top by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn the unit back on. If resetting the power does not correct the issue, your appliance could be experiencing a communication error with the EOC (electronic oven control) or a potential wiring failure. You may wish to reach out to an appliance expert who is best equipped to pinpoint the exact problem, which can often save you funds and a headache.
Jul 13, 2013 | Frigidaire 31 in. FEC30S7E Electric...
Oven door is locked somehow
UNplug it and let it sit for a half hour to a hour then plug it back in and it might reset itself.
Jan 05, 2013 | Maytag Stove / Oven / Range Cooktop -...
Maytag oven will not heat after self cleaning
try to unplug the oven and let it sit for a bit then plug it back in.
Dec 10, 2012 | Maytag Stove / Oven / Range Cooktop -...
Kenmore gas stove - oven won't ignite
hi gud day,do u think the gas is ok or every time u open is come out, or check ur control gas line valve maybe it close or authomaticaly close due to some laekage. chect it by smeling every turn on ur knob,but unplug the item b4 u do.
tnx gerbee
May 27, 2009 | Cooktops
Whirlpool Cooktop will not reset
Well the solution was to unplug the 220Volt connection for one minute--plug it back in--reset the clock, hit start and bingo it worked. I found on the back of the stove the technicians schematic, and error codes in a plastic envelope that described the procedure for finding--isolating--and solving the issue by the use of the error codes, which were not avaialable online anywhere but in the diagram and description for a technician's use.
I saved myself $109 dollars by avoiding the call out, but still my breakfast was four hours late!
Dec 27, 2008 | Whirlpool 30 in. RC8700 Electric Cooktop
Ignition sparking on its own with GE mongram gas stove top.
the sparking is one of the switches under the knobs shorted you may be able to open the top and take a switch off 1 at a time and you can figure out what one is shorted.or you can just change all of them.
to stop this you may be able to just unplug the cooktop from under the top.if you unplug the cooktop you should be able to light the burners with a match.
Nov 14, 2008 | Cooktops
Cooktops Logo
129 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
