Question about EliteGroup P4VMM2 Motherboard
Hi.I am having two problems. 1.When I start my PC the mice doesn't work and when I reboot my PC it starts working. 2.The keyboard lights blink continuously when I start my PC and it doesn't work even after rebooting the PC.
  • angleye23 Jun 06, 2009
    No the pins are not bent.I have tried the mice and keyboard on other system and it worked on that.
  • 105 Answers
Hi there if you are using the small round 7 pin ps2 connectors for your mouse and keyboard remove both plugs and have a good look inside at the pins to make sure they are not bent it sounds like one of them has got bent pins and shorting out this would give you the problem with both ports
Posted on Jun 04, 2009
Hi my keyboard started working erratically a few days ago. it's an A4tech keyboard. and at first while using photoshop the spacebar stops working then I would have to reset it to have it start working...
It sounds like the keyboard is starting to you can try a different keyboard if you have one and it that works your keyboard is bad. If your other keyboard doesn't work to your port were your keyboard is plugged into maybe going bad, let me now if any of this helps.
Aug 02, 2011 | Compaq Keyboard
Keys won,t work on keyboard
In regards to your problem you might want to try some of this steps
1. Check the keyboard cable, try to reconnect the cable and check if any message will pop up to verify
the keyboards connection
> you can restart the Pc then check again once it booted up
2. Be sure the numlock is on
3. Check if your PC detects your keyboard by checking it on Control Panel
> Click Start
> Choose Control Panel
> Go to Device Manager, then check if your keyboard if present
4. If this steps didn't work then you might need to replace your keyboard. ^_^
Hope this help you with your keyboard issue. Have a great day and thanks for using Fixya.
May 18, 2011 | Acer NSK8458AN Keyboard
A program deleted my keyboard and now I don't have one showing when I check the keyboard in my control panel. It works at the very start up but not after. I have tried a new keyboard and windows doesn't...
Generally additional drivers are needed for basic keyboard functionality, although Windows does actually install them as unique devices. Sometimes this process can take several minutes (depending on computer speed) and the keyboard will be unresponsive until it's actually installed. Try plugging in your keyboard, rebooting the PC, and giving it a few minutes once it's up and running.
If that doesn't work you can try booting into Safe Mode by hitting the F8 key during the startup process. This will load generic drivers and will allow you to troubleshoot additional drive and/or software issues.
May 02, 2011 | Microsoft Basic Keyboard 1.0A PS/2 KEMIBA
I installed the program computer shows it is working properly but it does not work
1. Check the batteries. Unless you have a very old mouse, there will be a light on the bottom if there is a charge. 2.Pair the mouse and base. Each will have a 'connect' or similar button; press the one on the base, then the mouse. 3. Plug in the base.
Jan 12, 2010 | Logitech Cordless Mouse
PLEASE HELP.. KEYBOARD AND MOUSE ARE COMPLETELY DEAD
If you can bott the computer normally and don't have to type a password in, then go the control panel and then choose device manager. Scroll down to the mouse and keyboard plus signs and right click on the mouse and keyboard one at a time and select uninstall. When the original mouse and keyboard have been uninstalled, reboot the computer. When Windows starts back up it will be forced to search for the new hardware and will install the drivers for it. If it wants to search for new ones allow it. If you have to type a password, you will have to go and get a usb keyboard that works off one of the usb ports. If this doesn't work, reboot the computer with the Vista disc in. Click any button to boot from the cd. When the windows files load and windows starts, choose repair, choose the windows installation and let windows search for problems and see if it can fix them. If all fails, go to system restore and back the computer up a few days and let system restore fix the problem by taking you back in time a few.
Nov 02, 2009 | Computers & Internet
Keyboard and mouse not working when windows starts
Hi there.
While you are in the operating system, unplug both the USB devices, then plug them back in, let windows recognize the new hardware and install it for you, this can take a couple of minutes, once it says hardware is installed and ready to use reboot the PC and see if you can use the keyboard and mouse while in the OS.
please post back with any more problems
Good luck and thanks for using Fixya!!!
Feb 23, 2009 | Micro Innovations PD7250LSR Wireless RF...
Trackball stops communicating with PC
Hi, logitech mice quite often have an 'auto power off' after a period of time. Instead of unplugging and plugging it back in, try clicking one of the mouse keys, give id 1-2 seconds and try it again.
Feb 19, 2009 | Logitech Cordless TrackMan Optical...
Just installed a microsoftwireless keyboard 4000 and installed software and it worked fine. When I rebooted my computer would not start untill I unpluged the new keyboard. Tried several times to the same...
Hello There,
This problem is not common,
Try these:
1) Re-install the software - see what happens.
2) Un-install the software if 1) doesn't work and try using keyboard.
3) Read about common problems in the software and keyboard:
http://support.microsoft.com/kb/258826
4) If all these fail then call Microsoft about this problem and let them diagnose it. They are the makers so they should know what to do.
Dec 27, 2008 | Microsoft Wireless Laser Desktop 4000...
Keyboard stoppped working
I had the same problem. Some keys on the keyboard would work, others not. It seemed to happen after an update to the SetPoint software. I got it fixed! I tried everything and in the end this is what worked:
1. I started the computer and obviously could not log in.
2. My mouse worked, my standby key worked, but no other keys.
3. I used the mouse to activate the on-board keyboard in Vista (left bottom corner).
4. I put in my password and logged in.
5. I opened up an app (Excel in my case) to try to type something in.
6. As soon as I hit a key a Logitech wizard for encrypted communication came up!!! It asked me to press the connect button and then enter a code it displayed (keyboard worked at this point).
From this point on the keyboard worked!!
Note to Logitech.... great job on the extra security... bad job on the implementation... if your wizard runs after a PC is rebooted that has login passowrd protection.... how are the users supposed to log in??
Note: My logitech upgrade hung... with mouse and keyboard becoming unresponsive so I had to do the hard power off... maybe the wizard was meant to run after the upgrade before I had to force a restart, but this is something that should be taken into account as well.
Mar 14, 2008 | Logitech EasyCall Desktop 967689-0403...
EliteGroup P4VMM2 Motherboard Logo
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
