Question about Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television
BLUE IMAGE ON FLAT SCREEN
Hello, I  have a 46" new flat screen. My daughter was trying to show us something and poked at the screen. We then noticed that there is a blue spot where she poked at the screen, it has not gone away. I know there isnt anything broken or cracked. Is there a way this blue image can be removed. I NEED help!!!
  • 85 Answers
You could try resetting tv to factory default ie new instilation or disconnect frpm power outlet for 24 hrs and reconnect sounds daft but did this on an old samsung that had a carboard box against the screen and was suprised that it cleared the problem
Posted on Dec 04, 2012
    Champion:
  • 208 Answers
As I'm sure you will notice that you rub your finger accross the lcd panel when it is on and you will see a blue trail as you cross the screen. I would simply try to wipe the spot with a soft dry cloth while the unit is on and see if that corrects the problem. If not I'm sorry to say that the lcd panel has been damaged.
Posted on Feb 07, 2008
SOURCE:
Horizontal lines showing behind tv menu
Normally the menu is generated in the LCD Control Unit. If your menu looks good, but the defect is behind the menu, I would suspect the Main PCB. Good luck to you. Part# is DUNTKD934FM01-V1.
Jun 17, 2016 | Sharp Aquos LC46D62U 46-Inch 1080p LCD...
TV powers on and goes black.
first i'd say try all the normal things...
swap sources, check to see if the osd comes up, etcetera. it might just be that the tv isnt receiving a signal from the source its tuned to. see if theres a way to factory reset the tv, try it.
if no matter what you do nothing shows up...
maybe the backlight burned out or maybe something on the mb burned out. go over and sniff the tv, notice any smell? if this is the case, i dont suggest trying to fix it new screen.
Jul 06, 2015 | Sony KDL60EX700 60 in. TV
Blue screen no image
Main board fault. Contact any service technician. Gopakumar Gopalan Google
Feb 22, 2014 | Samsung LN-S4692D 46 in. LCD HDTV
Vizio 46" Gallevia Flat Screen
any display in the corners of channel number av etc ?? if you turn the volume up and down does that show on the display if not likely to be a dead panel
Dec 09, 2010 | Vizio Televison & Video
The screen is always blue, and gives no image.
Hello, the blue screen could be a sign of a defective tuner. If you are using a video input for your DVD or VCR player, do you get the blue screen then? If you do there might be a problem in the color processing circuit.
Dec 01, 2010 | Maxent Televison & Video
No picture screen is blue
If you use RF cable, need to change brand new cable.
But, before that need chck the status of cable connector.
Feb 01, 2009 | Samsung LN-T4665F 46 in. LCD Television
Burn-ins?
It sounds like your light engine is on it way out. I would have this verified by a service center. Very costly to replace. They will probably try a new lamp first.
Jan 21, 2009 | Sony KDF46E2000 46" Projection HDTV
Astar flat screen monitor
i need help getting my astar flat screen tv to power on. the blue light is on in the center of the tv
Dec 24, 2007 | Astar LTV-2701 27 in. HD-Ready LCD...
Blue shading problem
2 months old? I'd call the dealer..it's under warentee. You have a problem that will not get better.
Jul 14, 2007 | Samsung PS42P4AX 42 in. HD-Ready Plasma...
Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television Logo
270 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
