Question about Dell Latitude C610 Notebook
I ran a utilities test and it said I need to change the internal battery for the BIOS. Where is it located and what size is it and what P/n?
    Sergeant:
  • 157 Answers
It is a Coin Cell battery and which looks like this
http://images.google.co.in/imgres?imgurl=http://www.onlybatteries.com/webimages/images/15293.jpg&imgrefurl=http://www.onlybatteries.com/%3Fcat1%3D70&usg=__TDpQphbmyjhYFW8UplUsSkBPahI=&h=300&w=400&sz=91&hl=en&start=7&um=1&tbnid=_GA5U-5_Fk48AM:&tbnh=93&tbnw=124&prev=/images%3Fq%3Dcoin%2Bcell%2Bbattery%2Bfor%2Bdell%26hl%3Den%26sa%3DN%26um%3D1
Posted on Jun 04, 2009
How to disable the video on a A780L motherboard
North Bridge Co nfig uration
BIOS SETUP UTILITY
Chipset
vxx.xx (C)Copyright 1985-200x, American Megatrends, Inc.
Select Screen
Select Item
Go to Sub Screen
General Help
Save and Exit
Exit
Enter
F1
F10
ESC
NB Chipset Configuration
NB CIMx Version : 4.4.0
> PCI Express Configuration
Primary Video Controller [PCI-GFX0-GPP-IGFX]
NB Power Management Features [Auto]
> Internal Graphics
Internal Graphics Conf
Internal Graphics Configuration
BIOS SETUP UTILITY
Chipset
Select Screen
Select Item
Change Option
General Help
Save and Exit
Exit
F1
F10
ESC
Internal Graphics
UMA Frame Buffer Size [Auto]
FB Location [Above 4G]
AMD 780L HD Audio [Enable]
Internal Graphics Mode [UMA]
Surround View [Disabled]
Options
Disable
UMA
T his item allows you to select the memory mode used for internal graphi cs device.
Options: UMA (Default) / Disable
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwiwq5ik2rXQAhWKP48KHU--AYMQFggcMAA&url=http%3A%2F%2Fmediapool.getthespec.com%2Fmedia.pdf%3Fm%3DQNJ2kCQfmVPhBYToYbwEQw%253D%253D%26v%3DPD&usg=AFQjCNGEH6Nge9c54_Uk8domc9vJiL0eTw
Nov 19, 2016 | Computers & Internet
After turn on the computer (DELL OPTIPLEX GX240) it stoped on BIOS revision
Seems to be an internal hardware problem and probably there is an easy solution to your problem.
  1. Open your case/cabinet.
  2. Disconnect the battery plugged on motherboard. (probably its size is similar to a coin)
  3. Disconnect SATA cables. (optional)
  4. Plug everything back in.
  5. Restart your computer.
Disconnecting the battery/cell actually resets the BiOS, making it easier to get rid of a few BiOS problems.
P.S. : You can take your RAM out. Plug one out (If you have two RAM Chips) or simply change-exchange their location.
If this doesn't work, it is recommended that you visit a service shop.
Feb 14, 2013 | Dell Computers & Internet
Hi i have an intel DG31PR M/B and it sticks before entering bios.I can only see the intel background and when it asks me to press F2 it does nothing.After several tests i entered the bios menu by changing...
Try reseating your memory dimms in the motherboard.
pop out the battery for the bios and boot the machine minus the battery. The machine should boot but bios changes wont be saved. If it works then reseat the battery again.
Good Luck
May 05, 2011 | Intel Computers & Internet
Dell inspirion bios pasword problem
The link below might help to reset your BIOS by selecting the option which suits you best!
http://www.tech-faq.com/reset-dell-bios-password.html
Mar 22, 2011 | Dell Computers & Internet
I forgot my password for Phoenix BIOS utility
hi try to cut off any power source and remove the battery and have the jumper in the position of discharge (Discharge bios you find on themotherboard near the battery), wait 10 minutes and starting.
Feb 16, 2011 | Computers & Internet
Lost bios password which was the serial and dont have it is there a way to bypass
Hello
First, remove the case to look at the motherboard, so we can try resetting the CMOS battery. This battery looks a shiny little disk the size of a nickel. Pry the battery free gently, and reinsert the battery after 10 minutes. If this worked and you don't see the password prompt, you don't need any more steps; the problem is fixed. In my experience, two or more additional steps might be necessary depending on the make of the BIOS. Unfortunately, they don't all respond to the same tricks.
Next, now that the case is already removed, locate the jumpers near the edge of the board or near the CPU or the CMOS battery. Once located, find the label that will say clear CMOS, or clear password, etc. Place the jumper over the pins and boot. If this works, no more steps are needed. If it doesn't work, read on.
The third step to try is to enter a password. When you receive the password prompt, try one of the following passwords. If you have an Award BIOS, try these; AWARD PW, ALFAROME, or _award. If you have Phoenix BIOS try, CMOS, PHOENIX, or BIOS.
If none of these things have worked, as a last resort, try a software utility that resets system passwords. These utilities can be found online.
Nov 05, 2010 | WYSE WINTERM 9150SE
How to change cmos battery . or at least I presume its that. POST reports time error each boot despite resetting
You are correct, the BIOS battery is flat and needs to be replaces.
The BIOS battery maybe behind one of the panels on the bottom of the laptop or it maybe under the keyboard. The most common BIOS batteries in laptops are button 3v lithium batteries. You need to locate, remove to identify the type and size of the battery.
Oct 28, 2009 | Acer TravelMate 242LC Notebook
When I turn my computer on it says internal battery low, but its a desktop, it doesn't have a battery does it? Then it moves to a black screen and stays there. What's wrong with it? How do I fix it?
It has internal CMOs battery .It is Round shape, size of Us "quarter" coin, located on motheboard.
Try changing that. If that is weak, you might loose your BIOs setting and computer may not boot.
Jul 10, 2009 | Dell OptiPlex 170L PC Desktop
Bios password forgotten on toshiba 2180cdt please help
Remove the battery, open the chassis and locate the internal backup battery (size of a small coin), disconnect it and let it stay disconnected for 24-48 hours.
Reassemble and you are ready to go!
Apr 19, 2009 | Toshiba Satellite 2180CDT Notebook
TECHNICAL SUPPORT
One of three ways, usually;
1) Unplug the power, remove the battery, hold the power button on for a good 10 seconds. Plug the battery in and test.
2) Open the laptop up and locate the CMOS battery. It'll be a small lithium battery... similar to those in watches. Remove battery for 10 seconds, put it back in, and test.
3) Use a BIOS cracking utility... this might very well break your laptop completely, and I can't recommend any utility that will definitely work. This is a last resort. =-]
Aug 20, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Dell Latitude C610 Notebook Logo
Alun Cox
