Question about HP Officejet Pro L7780 All-In-One InkJet Printer
We have an HP L7780 and have problems rec. faxes - error 232
We have an HP L7780 all-in-one. Recently it has been having trouble receiving faxes. Sending hasn't been a problem. It is not connected to a dedicated fax line. It is connected with a network cable and we use a Cisco ATA 186 analog telephone adapter. We have rec'd the error code 232 a couple of times. I have powered down the L7780 and the ATA 186 and then we can receive faxes. I downloaded the latest updates for the L7780 and still happening. I have a feeling it is the ATA 186, but see others have had the error code 232. What exactly does that error code mean?
Thank you!!!
    Sergeant:
  • 213 Answers
Hate to say it, but it means "Don't buy HP printers". You'll be a whole lot happier with Canon or Epson. I had no end of trouble with more than HP all-in-one. They just get flaky after awhile, and the software (particularly scanning) is terrible.
Posted on Apr 18, 2017
5 Suggested Answers
SOURCE: Receiving faxes with a Cisco ATA 186
More investigation implies that faxing over VoIP, as I am doing, requires setting the fax BAUD rate to 9600 bps or slower. So does anyone know if it is possible to set the BAUD rate on the Dell MFP 1600n multifunction printers?
Posted on Feb 23, 2008
  • 5 Answers
SOURCE: Error 232 receiving fax
fax error 232 indicates a communication failure between the sending and receiving units. I'd check for line noise on the phone (you can hear it as cracks and pops) If your fax line is not dedicated, any noise from another phone pickup or an answwering machine can cause the failure.
Posted on Sep 08, 2008
leroyal
  • 2120 Answers
SOURCE: cannot send or receive fax's with hp laserjet m1319f
Fax machines are ANALOG devices.
Posted on Jan 10, 2009
SOURCE: Error codes 283 and 232 in received Faxes
basically error 232 indicates that a communication failure has occurred between the two machines
Following these steps may help resolving your issue
1. Make sure that the phone cord is plugged directly from the wall jack into the back port of the fax machine that is marked "Line" or "To Wall Jack", or that has a wall-jack symbol.
2. Verify that the line interface unit (LIU) (the box that the phone cord plugs into) is seated fully into the back of the fax.
3. Remove any other device from the line such as splitters, credit card machines, or telephone answering machines, and retry the fax communication.
4. Try sending and receiving faxes on a different fax line.
5.Try using a different telephone cord.
6. Have the phone company test your line for static or noise problems.
7. Disable Error Correction Mode (ECM) if the same error occurs repeatedly.
Hope this helps.
thx
Posted on Jun 02, 2009
I have an HP L7780. We are having an issue receiving faxing. The pages are often only 1/4 complete. There is no reported error. It doesn't happen all the time.
Send a fax on this number
1-888 HP FAX ME (1-888-473-2963)
and see whether you receive a fax from hp or not whenever HP receives a fax from any number it sends back a fax to prove the functionality you can say.
the reason behind reviving the 1/4th fax can be fault at sender's end
Apr 21, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
Fax rec 2-3 pgs OK, then disconnects and gives Comm Error
These errors mean that the communications have failed, and can mean that the receiver at the other end has terminated the call prematurely.
If the problem occurs with the same destination, then the receiver fax may be the problem.
If the error persists try disabling ECM
Feb 04, 2010 | HP LaserJet 3055 All-In-One Printer
Fax comm error 232 problem
Hello sir ; Why don't try to replace a phone cable or check the wall jack.
Aug 28, 2009 | HP LaserJet 3050 All-In-One Printer
Can't receive a fax
There are some settings that you need to change.
You need to turn off the following:
Auto Reduction
to get to these options you need to go to the setup menu by pressing the setup button
then scroll to advanced fax settings and select it and you will find the options listed under it
You also need to check the fax speed under Advanced fax settings.
set it to medium.
hope this will help you :)
Aug 09, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
HP office jet 6210 All - in- one /error message 232
Please consult this page for links to fax error codes for your printer.
In particular, Error 232 yields this info:
Error Code: 232, 233, 234, 235 ECM, 236 ECM, 237
Definitions
A communication failure occurred between the two machines.
The user at the remote machine might have pressed the Stop key.
The call waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line. Do not use call waiting on a line with a fax machine.
The power at the remote machine was interrupted, or deliberately turned off causing the fax session to be interrupted.
Solutions
If the error persists, and error correction is in use for the fax session, disable ECM. Fax quality might be degraded. Click here for instructions on enabling and disabling ECM (c00060802) (in English).
Set the host machine to receive at a slower transmission speed.
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power brownouts and other power-related problems.
You can also access the home support page for your printer here., in case you should have further troubles.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 24, 2009 | HP PSC 2410 All-In-One InkJet Printer
Hope this helps.
thx
Jun 02, 2009 | HP LaserJet M1522nf Multifunction Printer...
Comm error 232 & no fax detected when receiving
Sam here. Anyone have a solution?? We use a voip setup for phones. Wondering if its related. We have signal converter boxes installed.
Oct 21, 2008 | HP LaserJet 3055 All-In-One Printer
Laserjet 3330 is resulting in fax Comm Errors 327, 232, 442, 356, 421 Comm Error 327 is always with fax # 780.467.6516. i can not fax to this number and when i receive from it, it always prints a Fax...
232-A communication failure has occurred between the two machines.
327-*Reattempt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
356-The remote user has pressed the Stop key, causing the session to be aborted.
442-An error occurred during transmission after one or more partial pages had been sent. The transmitting machine was unable to restart the control channel (handshaking) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page but can also occur if the receiving fax is using a fax format that is incompatible with the HP fax machine (usually during color faxing).
Aug 15, 2008 | HP Computers & Internet
Jul 17, 2008 | HP PSC 2410 All-In-One InkJet Printer
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
229 people viewed this question
Seeker5211
Seeker5211
