I'm trying to print A9 envelopes (5.75 x 8.75) using a HP Officejet Pro 8600 Plus using the Stamps.com software. I keep getting a mismatch error (sound familiar). I even tried using the paper size A5 and that doesn't work either! It doesn't make sense why HP would not have included the envelope size, when it's a popular size and most commonly used.
SOURCE: I am trying to receive a fax and am getting a paper to narrow mes
I not really sure on this machine if it has these setting, but most fax do. There is a setting that allows you to automatic choose reduction of a fax if the one sent was larger than 8 1/2 x 11. Good Luck
SOURCE: I get a paper mismatch when trying to print
SPENT THREE HOURS DOING THE INSANE OVER AND OVER AGAIN. THEN I DECIDED TO TELL THE STAMPS.COM CONFIGURE THAT IT PRINTED A TRIANGE WHEN IF FACT THE PRINTER ERROR MESSAGE"Paper mismatch.” SHOWED UP ON THE HP MESAGE MONITOR.
I THEN CONTINUED THRU THE PROMPTS ON STAMPS.COM SOFTWARE AND CONFIRED THAT "ALL FOUR" ITEMS PRINTED ON THE ENVELOPE WHILE IN FACT IT DID NOT. THIS GET YOU THRU THE "CONFIGURE PRINTER" SETUP. THEN I SELECTED "PRINT PREVIEW" AND PRINT TEST ENVELOPE AND IT WORKED!! HOPE THIS HELPS. I HAVE NOW PRINTED 30 ENVELOPES,ALL OK.
HP J6480 ALL IN ONE PRINTER
SOURCE: HP Photosmart Premium c309a series will not print
Try This :
Try printing from micrsoft word; Click on tools;
Click on Envelopes and Labels
Click on "OPTION"
Under the TAB Envelope Option you will get Evelope Size;
Scroll Down to the bottom you will get an option "Custom Size " Select it;
Set the accurate size of the envelope;
Click on Printing Options
Select the Feed method and make sure you do it the same way;
And then try to print this should resolve your Issue
otherwise let me know
Regards Soumajit
Testimonial: "Still not working. Great idea, tho."
SOURCE: Print Envelopes with hp c309a "Paper Mismatch" error
Even though the icon on the printer shows the envelopes entering the printer narrow side first, you have to set the printer up for, and feed the envelopes through, wide side first.
Print labels and envelopes
With the HP ENVY 110 series, you can print on a single envelope, a group of envelopes, or label sheets
designed for inkjet printers.
To print a group of addresses on labels or envelopes
1. Print a test page on plain paper first.
2. Place the test page on top of the label sheet or envelope, and hold both up to the light. Check the spacing for
each block of text. Make adjustments as needed.
3. Load the labels or envelopes into the paper tray.
CAUTION: Do not use envelopes with clasps or windows. They can get stuck in the rollers and cause
paper jams.
4. Slide paper-width guides inward against the stack of labels or envelopes until the guides stop.
5. Select the appropriate options.
• On -Paper/Quality- tab select a Plain paper type.
• Click the [Advanced] button, and select the appropriate envelope size from the Paper Size drop down
menu.
6. Click [OK], and then click [Print] or [OK] in the Print dialog box.
If you print from within a program that DOES have that listed (like M$ Word,) then you don't need the limited printer driver to specify the paper size.
Tallon41
