Question about Bosch Brute Breaker Hammer 11304
Bosch Brute hammer, how to change brush set?
The outside cover (Bearing Housing (#4 in diagram) does not come out because it is partially blocked by the Slide Housing Cover (#52).
Would appreciate any suggestions.
  • manooch Jun 04, 2009
    thank you. Your #s are different from my diagram. I have the following two diagrams (for model 0611304034 and model 0611304139).
    The nameplate on my hammer is missing, so I can not tell for sure what model I have.
    Would you please post the link to the diagram you are using?
  • 154 Answers
If you remove the cover (#53)(4 bolts #104) then the the bearing end plate will come out,but the armature will also come out as the bearing is pressed onto the armature.If you want to get the two apart you will have to unthread the bearing cover(#6), then remove the nut below it(#9) then press the armature out of the bearing.
Posted on Jun 04, 2009
Was using my Bosch brute 70lbs jackhammer and it quit working. It only makes a humming sound when I press trigger.
Beware Time for service something does blocking the armature if that happens a bearing or other broken part.
Apr 17, 2017 | Bosch Hammering
How do you change the brushes on a bosch 36 v-li
Once you have removed the 4 screws holding the gearbox to the main body take off the right hand half of the housing leaving the left half on the work bench. Unscrew the 2 screws that hold the brush holders down and remove the old brushes and refit with new ones. Rebuild in reverse.
Oct 24, 2012 | Rotary Bosch 11536vsr 36v Sds+ Roto Hammer...
My jackhammer will not run, the cord and switch are good
Check your brushes. The brushes on the Brute breaker have a spring loaded, non-conductive pin in them. When either brush wears down far enough the pin pops out and prevents damage to the expensive armature. If by chance the brushes are OK you may have to have your armature tested.
Sep 22, 2012 | Bosch Brute Breaker Hammer 11304
@runs hot motor feels slow doesnt hit hard
Bosch brute is made to work all day every day and will continue to do so if it is not over or under powered and properly lubed. If not powered correctly, motor will not turn at full rpm, get very hot and burn brushes to point that auto stop feature will stop motor (brush will push away from armature, or burn switch). The hammer will overheat if too long or wrong gauge of cord is used. Also if run on generator with voltage /cycles incorrect. Under normal use, motor will not get very hot. Another problem with overheating is that the grease will melt out of range to do any proper lubrication. If you are sure that it is getting proper voltage /amps then may need lubrication or bearing work. Remove bearing cover and turn armature by hand. It should be easy to turn. If stiff, suspect bearing/grease. With amp meter connected, check amp draw and compare to rated amps.
Mar 26, 2011 | Bosch Brute Breaker Hammer 11304
I have a bosch brute hammer drill, that just stopped working after 2 hours of breaking up concrete and rock. It is brand new, and worked fine to start with, but then gradually took longer and longer to...
Take it back as it is still under warranty. If there was anything you could do other than letting it cool down it would be in the instructions.( which you have since it is brand new.)
Mar 14, 2011 | Bosch Brute Breaker Hammer 11304
Purchased a brute hammer at a garage sale and it is missing 1 of the 3 springs from the area where bits attach. Is this an easy fix and or expensive Thanks Mark
Parts are easily available for your hammer. Check on ebay or www.toolpartsdirect.com. There is a service kit available # 1617000050 that includes set of bolts, orings, grease, brushes etc. After the service kit is installed your hammer will be ready for serious work . This kit does not include springs (#3614640501 each, uses three ). Good luck ~ greatest electric hammer ever made!
Nov 10, 2010 | Bosch Brute Breaker Hammer 11304
How do i change the carbon brushes on my bosch breaker hammer? I need step-by-step instructions
go to www.boschtoolsservice.com and request the information on diagram and/or instructions for replacing brushes. Also, instructions should be included with parts.
Oct 27, 2010 | Bosch Brute Breaker Hammer 11304
Bolts snapped piston came out can i repair
should be able to, they make a service kit with new bolts and a diagram for this tool, If this is the Bosch Brute hammer the kit is 1617000426 and you should be able to buy that locally at any tool repair shop. If not let me know and I will find an online source.
Oct 28, 2009 | Bosch Brute Breaker Hammer 11304
Bosch Brute Breaker Hammer 11304 Logo
1,824 people viewed this question
Top Bosch Hammering Experts
John Trevino
snowycreek
Are you a Bosch Hammering Expert? Answer questions, earn points and help others
