Question about Edirol UA-20 External Sound System
Have been using Edirol UA-20 successfully with Sonar Home Studio 6xl. All of a sudden, it won't recognize the UA-20's midi driver, and defaults to built in sound card (Soundmax) so midi in Sonar no longer works. I've restored to dates when it worked, reloaded drivers, nothing works!
Where did i can find 4PM266PM multimedia audio controller driver..
Tq
Posted on Jun 06, 2009
Do not get MIDI signal via EDIROL UA25
Midi is data only, there is no actual sound to the midi tracks themselves. They need to be assigned to either a software synth or an external synth to actually make the sounds you want to hear.
For instance if you load a demo of a midi sequance you will need to add a software synth such as the TTS-1 or Roland sound canvas which are general midi compatable and will play the instruments sounds assigned to the demo's midi channels. Use the Synth Rack feature in Sonar to open one of them. Then you will need to assign the output of each of the midi tracks to that particular synth and you will get sound. Make sure to assing the synth's audio track to you UA-25 as its audio output.
I would suggest reading in the manual and following the tutorials included in the manual to get yourself familier with how this is all done. spacer.gif
May 25, 2008 | Edirol UA-25 External Sound System
Cakewalk Sonar - Edirol UA-1000 crackles on playback!
That's a latency issue it sounds like.
There's a slider under "Audio" .
Move it in increments towards "slow", test it as you go.
Leave it at the highest setting possible that doesn't crackle.
I've heard this so bad that it sounds like a gun going off.
It scares the Hell out of you when it happens !
Jan 20, 2009 | Edirol UA-1000 External Sound System
Sonar LE: no playback b/c "NO MIDI OUTPUT" selected
You have to go in to the Sonar configuration and select what the default MIDI and WAV input and output devices are. That is usually handled by the ASIO driver. In your case you would select the USB mic for input, and for output you need to select your sound card. For midi you need to configure the midi controllers and the software synth or soft instrument you are using.
If you need any more detailed help I need to know what version of Sonar LE it is and what sound card. I am guessing it detected the mic and just needs the output device configured as I mentioned.
Dec 31, 2008 | Edirol UA-4FX External Sound System
No midi sound
In sonar go to the options menu and select: Audio -->advance. and from the list select the "Asio" driver, then you'll have a new midi output (synthe sw...) select it to have a sound while playing MIDI files.
Sep 21, 2008 | Edirol UA-25 External Sound System
Recordin audio problems (drop out)
cheak msconfig start ups eating ram that needs alot ram be nice to add 1 gb more run cc cleaner.com tool get junk out update your software form webite fl latest flash adobe shockwave and java run spyware clean up close out all other programs when u work in studio program
Mar 17, 2008 | Edirol UA-4FX External Sound System
Edirol ua-25 not detecting midi but audio works fine
**** THIS IS THE SOLUTION ****
On the back of the UA25 there's a switch called "Advance" - this needs to be set to ON for the device to work as a MIDI interface.
LC (UK).
Feb 27, 2008 | Edirol UA-25 External Sound System
Edirol UA 4FX _Short Audio Signal dropout
try runing a cleaner ccleaner and ace utituies ok that stop those hickups give a atry make pc run alsot faster
Jan 28, 2008 | Edirol UA-4FX External Sound System
Problem with stability
Celeron CPU's will struggle with making music and limit what you can do with audio. Celerons are ok to play music but nor really for making music. Firewire is a better option for making music as it's really fast unlike USB. An option would be to get a faster CPU and try the soundcard again. But i would not use USB audio and would use an Audiophile 2496 soundcard as they are really cheap. Also midi is data and not audio, midi just works virtual instruments and is able to control keyboards through midi out. But first try a better CPU as a celeron isant that good for makign music. I know becouse i've been there done that and go really upset with the same problems your having at the moment. I played the midi files on cuabse and recorded it onto an audio chanel.
Aug 29, 2006 | Edirol UA-4FX External Sound System
Edirol UA-20 External Sound System Logo
141 people viewed this question
Top Edirol Computers & Internet Experts
David
David
Ben Armstrong
KG John Justin
KG John Justin
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
