Question about Amana ACS3350 Gas Kitchen Range
Self clean oven door wouldn't unlock!
I set oven to self clean and cancelled it after 2 hours .After about 1/2 hour oven began to beep and flashed F9 code ? Can anyone help? According to manual says to turn off circuit breaker for 3 minutes and reset breaker. Don't solve the problem.
  • 10,515 Answers
Try a trick that was given by an expert :-
All I needed to do was unscrew the 2 screws holding the lock assembly and it released it!! I screwed it back in and set the oven to self clean and it worked!!
Unless , F9 refers to slave micro not working. A condition in which you might need to replace control board.
Thanks.
Posted on Jun 04, 2009
Need self-cleaning instructions....missing manual.
To Self-Clean: 1. Close the oven door. 2. Move the door lock lever to the right to the locked position. 3. Press CLEAN. 4. Press the "up" or "down" arrow pad. CL-M (Clean - Medium soil, 3 hours) appears in the display. If the door is not closed, beeps will sound and "door" will appear in the display until the door is closed and the Clean pad is pressed again. If the door is not closed within 45 seconds, the self-cleaning operation will be canceled and the display will return to the time of day. If more than 5 seconds elapse between pressing the Clean pad and the "up" or "down" arrow pad, the program will automatically return to the previous display
5. To choose a clean setting other then Medium, press the "up" or "down" arrow pads to scroll through the self-cleaning settings. CL-H (Clean - Heavy soil, 4 hours) CL-M (Clean - Medium soil, 3 hours) CL-L (Clean - Light soil, 2 hours) Choosing a cleaning level automatically programs the selfcleaning time. 6. After 4 seconds, the oven will start cleaning. "LOCK" and "CLEAN" will appear in the display. The cleaning time will count down in the display. To Delay Start Self-Clean: Before delay starting Self-Clean, make sure the door is closed completely or it will not lock and the cycle will not begin. 1. Press DELAY. "DELAY" will flash and "00:00" will appear in the display. 2. Press the "up" or "down" arrow pads to enter the amount of time you want to delay the cycle. Delay time can be set from 10 minutes (00:10) to 11 hours and 59 minutes (11:59). 3. While "DELAY" is flashing, press the CLEAN pad. "CLEAN" will flash in the display. 4. Press the "up" or "down" arrow pad. CL-M (Clean - Medium soil, 3 hours) appears in the display. 5. To choose a clean setting other then Medium, press the "up" or "down" arrow pads to scroll through the self-cleaning settings. CL-H (Clean - Heavy soil, 4 hours) CL-M (Clean - Medium soil, 3 hours) CL-L (Clean - Light soil, 2 hours) Choosing a cleaning level automatically programs the selfcleaning time. After 4 seconds, "CLEAN," "DELAY," and "LOCK" will appear in the display to show that the oven is set for a delayed clean operation. The delay time is displayed
Apr 21, 2015 | Kitchen Ranges
Frigidaire smooth top electric range flashes f9 after cleaning
The "F9" error code means the EOC (electronic oven control) has found the lock motor switches to be out of sequence or shorted.
Test switches and if there is nothing wrong then replace the EOC.
What is the model number?
Nov 28, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
My GE drop electric range will not turn on the self cleaning unit. I set the time and push start and it flashes clean oven, door lock, however, the door will not lock. I hear a clicking sounds, it beeps...
You will need to press the stop/cancel button, next press the self clean button, you do not have to set the time the cleaning cycle takes approx 3-1/2 to 4 hours and the cool down takes another 45 minutes to one hour, it will clean and cool down and you do not need to interrupt this cycle, it will let you know when it is complete.
Nov 14, 2009 | GE Profile JTP18 Electric Single Oven
I stared to self clean by Frigidaire FEF355ASE oven. I got the beeping and the F1 note. I pressed clear and then I got beeping and F9. I pressed clear and got F9 again. I tried clearing it again and it...
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$%$%$%
Jul 06, 2009 | Frigidaire FEF352 Electric Kitchen Range
Stove door locked and continues to beep and flash code F9
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$%^^%$
Mar 27, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Door locks and F9 fault codes
Feb 24, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Does not go into self clean only beeps
here is a link for your owners manual click here
To set Self-Clean:
2. Press the appropriate Clean pad.
• CLEAN flashes.
• SET and UPPER or LOWER flash in the display.
3. Press the Autoset pad.
• “MEd” (Medium Soil, 3 hours) is displayed.
4. Press the Autoset pad to scroll through the self-cleaning
settings.
“HVy” (Heavy Soil, 4 hours)
“MEd” (Medium soil, 3 hours)
“LITE” ( Light Soil, 2 hours)
Choosing the soil level of the oven automatically programs
the self-cleaning time.
5. After four seconds, the oven will start cleaning.
• If the door is not closed, beeps will sound and ‘door’ will
display. If the door is not closed within 30 seconds, the
• CLEAN will appear in the display.
• LOCK will flash in the display. Once the door locks,
LOCK will remain steady.
• The cleaning time will start counting down in the
display.
Please take the time to rate this solution
Jan 30, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Cancelled self-clean, F9 code came up, door lock light flashing, can't use oven
HI,
your model number confirms that your range was manufactured by WCI (Frigidaire). although this doesn't help you now, it may help if parts are needed.
now, there is an indepth guide online to fixing this common problem and I would like you to go through it and see if it helps you solve your problem.
http://www.applianceaid.com/clean-lock.html
If you have found this site previously then I apologise, if you still need help, by all means post again and someone more qualified may help.
Hope this is of use to you ;)
Phil
Oct 25, 2008 | Kitchen Ranges
Oven door won't unlock
I asked for help with an Amana F9 code problem earlier today .I had set self clean oven on and then after 2 hours cancelled it. After 1/2 hr it began to beep and displaideda F9 code and I couldn't get it to unlock. Tried manual tip to turn off circuit breaker for 3 minuetes then turn back on. Did this 3 times to no avail.Tried 20 minutes also zip.Contacted Amana and all they would tell was to call a service rep. I gave her apiece of my mind that I wouln't do that because I wasn't going be paying for such an issue.
Your site was my salvation.( STP685) Suggested I push bake and once I did the oven started to heat and unlocked itself.! Thank you,thank you,thank you.
Jul 18, 2008 | Amana ACS3350 Gas Kitchen Range
Self cleaning oven not working right
shut the power off and see if it resets.
Jan 09, 2008 | Ovens
Amana ACS3350 Gas Kitchen Range Logo
463 people viewed this question
Top Amana Kitchen Ranges Experts
Sal De
Ismael Rodriguez...
Oloyede Monsuru
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
