Question about Whirlpool Washing Machines
Dirty marks on clothing - not every wash - could it be fabric softner build up?? & how to solve thanks
    Problem Solver:
  • 8 Answers
Try running vinegar through your machine without a load and this should solve your problem.
Posted on Jun 04, 2009
My clothes are coming out dirty. dirt is settling on my clothes from the rinse.
Put a cup of vinegar in an empty washing machine fill with water and wash without clothing in it. Should sort the grime caused by fabric softner.
Feb 04, 2016 | Kenmore 24032\24036 Top Load Washer
How do I remove crud from inside a washing machine?
12 WASH PERFORMANCE INFORMATION
12.1 Creasing
Creasing can be caused by over loading SmartDrive or the dryer. Permanent Press or Delicate
cycles have been designed to minimise creasing as they use a lower spin speed. Do not leave wet
clothes to sit in the washer or laundry basket.
12.2 Soiling
Soiling is the result of insufficient detergent for the load. White clothes are better washed
separately. Separate lightly and heavily soiled items, as clothes can pick up soil from dirty wash
water. Cold water below 20oC does not wash effectively. Select the wash temperature according
to soil type. For example, blood and mud are better washed in cold water, while sweat and oil
based soil wash better in warmer water. Loads made up of articles of varying sizes will wash
better (e.g. full loads of sheets may not wash that well). Hard water requires more detergent than
soft water.
12.3 Linting
Wash lint givers (eg. towels, flannelette sheets) separately from lint collectors (eg. synthetic
fabrics). Over loading SmartDrive can increase the likelihood of linting. Insufficient detergent for
the load can increase linting as there will not be enough detergent to hold the lint in suspension.
Over drying synthetic fabrics in a dryer can cause a build-up of static electricity and result in the
fabrics attracting lint.
12.4 Detergent Residue
Over loading SmartDrive can result in detergent residue being caught in the creases of the
fabrics. If this occurs, decrease the load size. Some detergents need to be pre-dissolved. Check
the instructions for the detergent. Cold ambient temperatures, cold washes or short agitation times
may not let the detergent dissolve properly. In these cases pre-dissolve the detergent.
Overdosing of detergent can also cause residue when foam breaks down and will show as white
specs on the clothing. Poor quality detergents can result in residue.
12.5 Black Marks on Clothes
A build up caused by the interaction of fabric softener and detergent (scrud) can flake off and mark
clothes. Do not use too much fabric softener, maximum 75cc. If this is a problem, it is
recommended that SmartDrive is periodically filled with hot water, plus 1-2 cups of dishwasher
powder and left to soak.
12.6 Grey Marks on Clothes
Not enough detergent for the amount of soil on the clothes can result in grey marks on clothes. If
this is a problem it is recommended that SmartDrive is periodically filled with hot water, plus
detergent and left to soak.
12.7 Dye Transfer
Wash and dry non-colourfast clothes separately. Non colourfast clothes left sitting in a washer or
laundry basket can transfer dye to other clothes.
12.8 Tangling
Washing with too much water (i.e. under loading) can cause the clothes to tangle around each
other. Do not load SmartDrive by wrapping clothes around the agitator.
Dec 19, 2012 | Fisher and Paykel Washing Machines
My washer leaves black marks on my clothes. I do not use fabric softners
Do you mean Black, really black marks? Perhaps dark brown.
Some marks comes from moldy seals, other marks comes from leaking gears from the machine. Examine the marks, check if those marks are oily or not.
Nov 27, 2009 | Fisher Paykel EcoSmart GWL15
FTF530FS Front Load washing machine. Clothes smell.
all front load washers have the problem. Mold and a build up or dirt and soap and fabric softner cause s old musty smell. The low water use makes the machine dirty and build up inside. Run a few Hot water washes with out clothing, Run it empty ,(run your hot water neer your washer to get the cold water out of the house pipes) hot water and pour bleach in side, 2 or more cups. Keep doing it. When your not using washer leave the door open so air can get inside. Hot wash,es with bleach will keep it clean, also dont use fab softner.
Nov 11, 2009 | Frigidaire FTF530FS Front Load Washer
Clothes are left with a residue on them. I use
Do you use a liquid fabric softner also ? Marks are usually left on clothes from undisolved fabric softner . Try using dryer sheets instead of washer softner .
Jul 16, 2009 | Washing Machines
Dark spots on my clean clothes
do you use a lot of fabric softner? If you do this might be your problem try to change soaps and stop useing fabric softner. try useing powder detergent and make sure that it is HE. let me know how it goes thanks
Jun 02, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
"fabric softner staining the clothes"
make sure you delute it with water. yes fabric softner will start to stain your clothes if you use too much of it. I would recomend stop useing it for a while. so you can clean the washer out. There is a product called Washer magic or Affresh that cleans out residues built up in your washer. or you can just run several loads of HOT water and bleach to clean it out. The hot water will melt the left over fabric softner in your washer. Fabric softner is kind of like hardend bacon fat thats what it looks like in your washer after time and if you do not clean your washer it builds up and builds up.
Also i do recomend alternating liquid detergent and powdered detergent. The reason why is powder leaves a residue that liquid takes away and vise versa. try this and let me know how it goes
Feb 12, 2009 | Maytag PAV2300 Top Load Washer
Fabric softner is building up in dispenser
Same deal - I have to soak up all the residual water in the softener dispenser between washes. (The detergent and bleach compartments are fine).
Jun 13, 2008 | GE WSXH208A Front Load Washer
Mile 864 front loader - clothes come out with new grease marks
Problem will be the use of fabric softner or too much detergent. The stain you are seeing is generally to animal fat that is present in fabric softner, Best solution is to cut back on the amount of softner being used, same with powder.
Sep 18, 2006 | Miele W864 Front Load Washer
Washing Machines Logo
109 people viewed this question
Dan Webster
Dan Webster
Sal De
