Question about SanDisk Sansa e260 MP3 Player
Help please my sansa e260 after i switch to recovery mode it says to enter USB2. 0 MSD mode then LUN0 locked then LUN0 unlocked. then it alternates like that can someone please help with it.
  • Anonymous May 11, 2008
    I went to recovery mode now it says USB cable cord connected Enter USB2.0 MSD mode. HOW DO I DO THIS????
  • tweety11 May 11, 2008
    my e 260 says welcome to recovery mode and under that is say
    usb cable conected
    enter usb 2.0 msd mode then it do show or say nothing else how can i fix this
  • 8,596 Answers
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Posted on May 23, 2008
It say's welcome to recovery mode first
download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software if it doesn't start automatic goto /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa hope this works.... Please rate
Jun 02, 2009 | SanDisk Sansa e260 MP3 Player
Cant get passed recovery mode
this came from another post on fix ya.
For me the solution was this:
After entering the recovery mode (turn off the player, move the hold button to the right, and press the on and rec button, then connecting to the computer).
when the 16 mb folder opens create a NEW FOLDER (not a text document) called "Sansa.fmt". then disconec the usb and it was fixed.
Pc not showing sansa
You may need to use a labtop which has 2.0usb.. I had to use my labtop first then it updated and my pc recognized it
Apr 24, 2009 | SanDisk Sansa e260 MP3 Player
SANSA E260 ENTER USB 2.0 MSD MODE
if you go into the setting section of the menu you can select the USB mode back again, if this fails to solve the problem, take the back of the player off via 4 very small phillips screws and remove the battery for at least 30 seconds then put it back in and it should be good.
Mar 21, 2009 | SanDisk Sansa e260 MP3 Player
WHAT DOSE ENTER USB2.0 MSD MODE MEAN?
The usb2.0 is the connector for usb on most computers.
It's the fastest usb drive to this date!
Feb 07, 2009 | SanDisk Sansa e260 MP3 Player
Please help
i would try entering usb2.0 mode, then test with the computer if it senses any problems
Aug 09, 2008 | SanDisk Sansa e260 MP3 Player
Error in sandisk e260 mp3 player
Your player is locked - there is a lock switch on the sign that needs to be disengaged.
Jun 27, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e260 mp3 won't work
try uninstalling "MTP Device" in your computer's hardware device manager - add/remove hardware in control panel
May 03, 2008 | SanDisk Sansa e260 MP3 Player
My sansa e260
Change the USB port on your computer.
If that doesnt resolve it, check the HOLD switch to make sure it is sliding over all the way.
Best of Luck.
Oct 24, 2007 | SanDisk Sansa e260 MP3 Player
My sansa e280 rhapsody says switch to recovery mode
Recovery mode is used to recover from a fatal error.
Follow these steps and youll be back in business.
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Oct 22, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
130 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
