Hello sir; try to make a copy without cover then you may easy to watch the mirrow is they moving ,then you can easy to find where does it cause the problem.
On my HP PHotosmart C7280 All in one:
Message appears on Unit.... Ink system has failed Unable to...
(More)
Message appears on Unit.... Ink system has failed Unable to recieve faxes or print.
I replaced all ink cartridges and did a reset... Still the same
Re: PIXMA MX 310 I am not able to install the toner cartridge. They are not sliding into...
(More)
Re: PIXMA MX 310 I am not able to install the toner cartridge. They are not sliding into position
I have a Zinwell converter box and a Radio Shack antenna, both are properly hooked up to the ant...
(More)
I have a Zinwell converter box and a Radio Shack antenna, both are properly hooked up to the ant connection (only 1) in back of tv-vcr unit and the yellow and white connections in frt of unit are connected via a cable with r-y-w to converter box and y-w to frt of tv unit. At the advance record screen..channel 3 is showing in the selection box, if you insert a different channel it will not record that channel/program. Are there any converter companies that had the foresight to know that there are hundreds of tv-vcr combos still in use? I understand the mechanics for a stand alone vcr and I know how to manually record on the combo..but I want to be able to preset and for more than one channel and recording times. Thanx
