Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
I have no possibility to get cabled DSL internet connection but only through local AP. IS it possible to connect my desktop to the AP through D-Link AirPlus Xtreme G DI-624 Wireless Router. Thanks
Internet from someone elses wireless AP, you will need a wireless bridge.
Posted on Jun 04, 2009
Is it possible to connect a standard DSL modem - without Wi-Fi (with 1 Ethernet port) and a DSL modem - Wi-Fi (with 4 Ethernet port) to broadcast Wi-Fi singles
Does the non wifi modem give out DHCP addresses?
Can the wifi modem be set up to receive it's IP address from DHCP?
If the answer to both these questions is Yes then that's what to do as a first step. Make sure the wifi modem DHCP service is disabled as it must NOT give out DHCP addresses.
Connect the ethernet port of the non wifi modem to one of the LAN ports of the wifi modem and NOT the DSL/WAN port. The wifi modem is not participating in any DSL connectivity at all so it's DSL light will remain off. The non wifi modem is doing the DSL duty so it's DSL light should be correctly illuminated.
May 01, 2015 | Computers & Internet
Ni wifi connection on the router itself, what could be the possible cause of it.
IT MAKES A DIFFERENCE IF YOU ARE HOOKING UP FROM DSL OR CABLE
IF DSL MAKE SURE ARE YOUR PHONES HAVE FILTERS
IF CABLE MAKE SURE THAT IS CONNECTED RIGHT
UNPLUG EVERYTHING
INSERT CABLE OR DSL INTO INTERNET SLOT ON ROUTER
THEN PLUG THE ROUTER IN LET ALL THE LIGHTS COME ON
THEN TURN YOUR COMPUTER ON AND SEE IF IT REQ THE CONNECTION IF THE LIGHTS ARE ON THE ROUTER MOST LIKELY COMPTER IS NOT CONNECTING TRY CONNECTING WITH ETHERNET CABLE
Feb 15, 2011 | D-Link DIR-300 Wireless Router
2004 Emachine- when desktop comes up on lower right there's a flashing icon when clicked on says "Network Connections", Local Area Connection, Network Cable Unplugged, Intel{R} PRO/100 VE...
If the local area connection icon specifies as network cable unplugged, then the computer has not sensed the connection between the computer to the cable modem / DSL modem, please reseat the cable behind the cable / dsl modem to the computer. If the icon still shows unplugged, then change the network cable between the two.
If the issue still persists, please revert with more details lik the kind of internet connection used and the reason for reinstalling.
Jan 04, 2011 | E-Machines eMachines Desktop PC
D-Link DSL-2640-T. After power outage, I have a good wireless connection BUT no internet access. LAN line does not work either. Please suggest possible solutions.
chack your DSL settings may your not conacted with your sevice provider
chack your locale settings in modem try folowing setups
1. If you have a modem, connect the modem to the router(make sure modem should be connected to the port on which LAN, Internet, WAN is mentioned. It would be a separate one port on the router) and router to the computer.
2. Insert the disk that came with the router, inside the computer.
3. Follow the on screen instructions.
4.No, connect to the wireless
Apr 22, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Getting 169.254...
possibly cat5 cable problem or your DWL - 2100AP is only on wireless mode.
please check and put on mixed mode also.
Mar 08, 2010 | D-Link AirPlus Xtreme G DWL-2100AP...
Premium Entertainment Pc Medion Akoya P7700D internet connection has to be by phone connection can you help
is phone the only way you have to connect to the internet? there are other possible ways to get internet to where you can have your phone line free. such as DSL, and CABLE.
Dec 06, 2009 | Computers & Internet
I have a used compacq 530 but do not know what is missing because i cannot get it to hook up to the internet
Possibly if you gave more information .....does it have a network card installed, is the network card "enabled" in the hardware settings, does the network card have correct drivers ? ( no yellow question mark beside it ) Do you have an internet provider and account ? Is your internet high speed or dialup, if it is dialup, do you have a modem installed - with correct drivers ? Is it working - do a modem query to see if it responds ?
If using a network card and cable or DSL internet, is the cable connected from the PC to the cable or dsl modem ? Is the cable or dsl modem plugged in and the power and wan light on ? With the little bit of information you have given, it is not really possible to give an exact answer to what the problem is.
Aug 30, 2009 | HP Compaq d530 SFF PC Desktop
Connecting DSL/Router to DIR-628 internet router.
it is possible but the routers have to be on separate channels
Jan 14, 2009 | 2wire HomePortal® 1800HW Router...
Got wireless signal but no internet connection
You can try to power cycle your entire network (refresh).
This often happens when you have a large network.
  1. power down ALL Computers and disconnect the desktop from the D-Link Switch.
  2. turn off all SLAVE AP's first.
  3. Turn off the Master AP and disconnect one end of the Ethernet.
  4. Turn off the D-Link Switch and disconnect one end of the Ethernet.
  5. Now, turn off your modem.
Leave them for about 10 to 15 minutes, depending on your urgency.
Turn on and connect all devices in the EXACT order.
  1. Turn on the modem. wait 2 minutes.
  2. Turn on the D-Link Switch and wait 1 minute. Then connect the Ethernet to the MODEM.
  3. Turn on the Master AP and wait 1 minute. Then connect the Ethernet to the D-Link Switch.
  4. Turn ONE of the Slave AP's. Turn on your Laptop. try to connect to the Internet. If successful, Disconnect from the network on the computer and proceed to turn on the rest of the Slave AP's, Laptops, and Desktop. If its NOT successful, power on the Desktop and try to connect to the internet.
  • If the desktop connects to the Internet, Check your D-Link's homepage "192.168.1.1" (default) for any wrong settings. If it does not connect, check your DSL Modem's settings.
If the above does not work, post what you did the day before this happened. Probably something small might have messed with the network.
Aug 15, 2008 | D-Link AirPlus DI-524 Wireless Router
D-Link DSL-2640
First I will need to know the type of ISP service you have, T1 - DSL - ADSL - CABLE - etc. And the connection type, STATIC IP - DYNAMIC IP - PPPOE - etc. BPCS
Dec 11, 2007 | D-Link ADSL2/2+ Modem/Wireless Router...
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
463 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
