Question about Admiral AW22 Top Load Washer
Admiral top load 10.1 Kg 4 speed Combo has become
Admiral top load 10.1 Kg 4 speed Combo has become very noisy when spinning : quite a high pitched noise.All other features working well
Water does not stay in drum goes straight out?
Posted on Jul 17, 2011
It drains very slowly and it makes a high pitch sound when it does spin...sometimes you hear something tapping or slapping, likesomething is stuck.
To me it sounds like you have something stuck in your pump. I would check that first. I had the high pitched sound during the spin cycle on my machine and it turned out to be the drum bearings. That part used to be covered by a 10 year warranty but not anymore. My machine was less than ten years old and it cost me around 300.00 to fix it. I have paid for my machine 3 times over in repairs. My next washer will NOT be HE and probably an old school Speed Queen
Apr 08, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
Admiral AW22 top loader
Hi
a couple of suggestions, either a spring has broken at the base of the drum, there are 6-8 of these used to keep the drum central, remove the front panel to take a look.
or
The machine is not getting up to full spin speed causing it to wobble, try reducing the load or could be slipping belt.
Dec 14, 2013 | Admiral AW22 Top Load Washer
ADMIRAL 4 SPEED COMBO 10/1 K.G CAPACITY. NOISY ON SPIN
noise will be drain pump or spin bearings.
Feb 09, 2013 | Washing Machines
Machine making loud noise on spins cycle
Well, the only time the washer (speedqueen) is noisy on spin is if one or both the bearings are faulty. Normally when you get a leak, it means the hub/flange and seal kit need replacement and this also includes the top bearing because when soap suds leak past the seal assembly it drips directly onto the bearing. The acidic properties in the soap suds eats the grease in the bearing which ends up becoming defective. One can also get an anoying squeek if a bottom base gasket is worn or removed. This would be audible even on wash cycle.Conclusion, check the bearing on top of gearbox.
Jul 21, 2010 | Speed Queen AWS44NW Top Load Washer
The washing machine makes a high-pitched squeking
No, not if the noise is only when rinsing, if it makes the noise when spinning generally then possibly but if only noisy when rinsing sounds like a filter blockage on the waste pipe. clean out the filter behind the flap on the bottom of the front panel
Aug 21, 2009 | Maytag Bravos MTW6600T Top Load Washer
The washer quits at rinse and spin dry cycle
I've had the same experience with my Speed Queen washer. Approached the accredited Speed Queen agents for assistance, when tech support was deployed to diagnose the problem.
In the end, I was told that the "timer" went bust. So the wash cycle seems to work 100%, but when it comes to rinse and spin the contacts on the timer don't make contact, and the motor waits in anticipation for it's next command, and that the high pitch noise heard.
Jul 04, 2009 | Speed Queen AWS52NW Top Load Washer
Car droning noise
While you are driving, get up to roughly 40 MPH on a road with little or no traffic. Once at this speed, whip the steering wheel left and right as if you were making rapid lane changes. If you notice a change in the pitch or intensity of the sound, it is quite likely that you have a pending wheel bearing failure. The reason that the change will be noticed is because there is a rapid change in load placed on the bearings during lateral moves. Outside of the, the tires alone, can be quite noisy. I drive an old 1981 Mercedes 300TD wagon. I never realized how much road noise was coming from my tires until I replaced them with new ones!
Apr 06, 2009 | 2006 Kia Optima
Kenmore washer/dryer combo (Model# 41792702200)
I cannot remove the dryer drum from my Kenmore washer/dryer combo in order to remove the bearing, how do I do this???
Jan 31, 2009 | Kenmore 24032\24036 Top Load Washer
Admiral AW22 Top Load Washer Logo
230 people viewed this question
Top Admiral Washing Machines Experts
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
