Question about Logitech QuickCam Pro 4000 Webcam
I have a pro 4000 logitech webcam
When plug into the usb port the cam lights on but computer isnt recognising it can you help me please email is xtrememobiles@bigpond.com
  • azzurroman Oct 25, 2007
    i eliminated all the above as i plugged another cam in and it works fine is there a way i can pull this cam apart or reset it
  • 589 Answers
You need to be more specific on your setup. Logitechs are very picky when it comes to installations. You MUST install the Logitech software FIRST (before plugging it in). Also, do NOT use a USB hub with ANY Logitech webcam.
Posted on Jan 08, 2008
  • 1,006 Answers
Possibilities:
1) One of your USB devices have faulted, or is causing a resource conflict (or similar)
-- Remove all USB devices, and reboot.
2) Your USB chip/ports have been damaged.
-- Find a spare HardDisk or bacjup your data and re-install Windows and see how that goes.
3) Your Power Supply Unit (PSU) isnt supplying enough power to your PC (usually caused by a Video card upgrade). Try a more powerful PSU ... 400watts should do the trick
4) Bad memory (RAM) can cause wierd problems. run memtest for an hour to make sure your memory is ok
Posted on Oct 24, 2007
  • arben pllana
    arben pllana Oct 24, 2007
    save ur information or use a second hard drive and reinstall Windows - Just for testing - And see if the USB problem is solved.
    If it is not solved, then you know for (almost) certain it is a hardware problem. That would at least help you get started in the right direction, because at this point it may be very time consuming to figure out.
  • arben pllana
    arben pllana Oct 25, 2007
    Then ur cam is damanged!!!Just buy new sir
Yahoo does not recognise my logitech pro 4000 web cam
YOU NEED TO SET CAM UP
IF DOES'NT HELP THEN UNINSTALL YAHOO AND RESTART AND REINSTALL AND GO THROUGH SETUP AGAIN
Go to Messenger at the top left and click on it.
Next go down to Preferences and click on it.
Next Calling and Devices on the right and
set the Microphone and Speakers to the computer Audio Card.
Next go to the Test Audio section and in blue writing click
on “Open the call setup assistant” and follow the instructions
on the left window.
LET ME KNOW IF SOLVED AND PLEASE DON'T FORGET TO RATE THANX
Feb 02, 2009 | Logitech Webcam
Logitech Quick cam Pro 4000
May I Ask What Do You Require Help With Besides The Driver Email Me At XDeadandsoulessx@aol.com And I Will Send You A Copy Of The Driver That You Are Requesting Please Vote At The Bottom Of This It Will Be Very Much Apreciated!
Jan 27, 2008 | Logitech QuickCam Pro 4000 Webcam
No video - cam checked, audio checked.
hi.
install drivers for quickcam 4000 v10.51
rob
Dec 10, 2007 | Logitech QuickCam Pro 5000 Webcam
downlod web cam Logitech Quick cam Pro 4000 winxp
Dec 08, 2007 | Logitech QuickCam Pro 4000 Webcam
Logitech quickpro 4000 install in windows vista home premium
MAKE SURE CAM IS NOT PLUGGED IN!!
Go to www.logitech.com
Click on "support" at the top
Click on "downloads + parts"
Choose "webcams" from the "product type" dropdown box.
Choose "Quickcam PRO 4000" from the "product name" dropdown box.
Click the blue arrow
Click "get software"
Choose your Operating System
Download / install it
NOTE: Do NOT for ANY reason plug the cam in before it asks you to do so!
You should be good from here! Good luck!
Oct 07, 2007 | Logitech QuickCam Pro 4000 Webcam
Logitec Pro 5000 not being recognised by USB Port
Hi .
Had same problem:
uninstall quickcam 5000 v11.50 drivers.
install quickcam 4000 v10.51 .
There is few files missing ( /removed) from version 11.50.
rob
Aug 28, 2007 | Logitech QuickCam Pro 5000 Webcam
Usb extention lead doesn't work with webcam
So you know the cam is ok and the cable, so you will have to point to the usb port not being able to push enough power through the cable to the camera as it must take a higher voltage than the other cam. Make sure that the other cam software is uninstalled and you have done registry clean in case of conflicts and also try using a different usb port but install the camera with the driver again using the extension in it, aplogies if you did, i am assuming you may have installed the camera directly without the extension cable.
Apr 29, 2007 | Logitech QuickCam Pro 5000 Webcam
Logitech QuickCam Pro 4000 Webcam Logo
94 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
