Question about Crown XLS 802 D Amplifier
I have 2 xls 802's one has no sound from channel 1 and one has no sound from channel 2 front indicators are fine
  • 73 Answers
Individual (1 and 2) audio power amp sections bad.
Paul
Posted on Jun 13, 2009
How do you connect pre amp to crown xls802
Sounds like the hi voltage input.. should have 2 sets of RCA plugs on it to run from head unit .
Mar 02, 2013 | Crown XLS 802 D Amplifier
Got a crown amplifier XLS 602 its powering up the relays are clicking, all voltages seems ok the signal led's are on but there's no sound output on both channels. I manage to trace the signal
Check your input or output cables might be dirty I had the same problem
and 1 of my output wire was dirty so i sprayed tha electric cleaner and its all good now
Aloha
May 21, 2012 | Crown XLS 602 2-Channel Amplifier
Crown XLS 602 Amplifier - Channels sound different
you are riight there exist several amps like that they having different frequency on each side i supose its not properly made like that or better they wanted a pasty sound on one side and a thin on the other many times it happened to me - in older days specially lots of european amps the solution is a equalizer on the front and equilze it smoth how u want it
Apr 15, 2012 | Crown XLS 602 2-Channel Amplifier
Crown xls 802 service manual
Here you are. On the Crown web site.
Crown XLS 602
Jan 01, 2012 | Crown XLS 802 D Amplifier
I have a Crown XLS 802 amp that works fine but the fans do not work. They, however, are not frozen. Any help is appreciated. Jim
It is capable of detecting cooling fan failure so I would presume it hasn't decided to engage the fans yet.
Jul 21, 2011 | Crown XLS 602 2-Channel Amplifier
How can i setup mu xenyx 802 with my pc? i also hve fca202...
You can do it one of two ways when coupled with the FCA202. First, You can just come out of the main outs on the 802 via 1/4 in to the 202s 1/L in and 2/R in. Second, you could do two separate channels (ie. Vocal channel and Guitar Channel) using the L/R out on the 802. Use the pan knob to send the instrument to the selected channel. So, If your Guitar is on channel 1 pan hard left and you will only get it out of the left channel sending to channel 1 of the 202, and your vocal is in channel 2 pan hard right and you will only get it out of the left channel sending to channel 2 on the 202. Good Luck, Cody J.
Dec 17, 2010 | Behringer Xenyx 802 8-input 2-bus Mixer W/...
Crown XLS 802 D Amplifier Transformer!
You will need AC to AC converter that will accomodate US to UK mains. Look for power requirements of your amp on name plate and match with available converters online. Make sure power line frequencies match in/out requiremnts
Apr 17, 2008 | Crown XLS 802 D Amplifier
Hooking up 2 speakers to 1 speakon output
Power Output (1 kHz*) Stereo Bridge-Mono 8 Ohm 4 Ohm 8 Ohm XLS 802 500W 800W 1600W XLS 602 380W 600W 1200W XLS 402 300W 450W 900W XLS 202 200W 300W 600W *1 kHz Power: refers to maximum average power in watts at 1 kHz with 0.5% THD. It depends on the impedence of the speakers. Carfull as you could burn up this amp if you exceed the resistance rating on it. Go here on all of the specs of this model of crown amps. http://www.crownaudio.com/amp_htm/xlsspec.htm Good Luck
Mar 27, 2007 | Crown XLS202A 2-Channel Amplifier
Crown XLS 802 D Amplifier Logo
293 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
