Question about HP (D7580-60003) Motherboard
I WAS CHANGING MY CASE NOW I HAVE A PROBLEM CONNECTING MY MOTHER BOARD CABLES
  • 59 Answers
Dear user,
pl found front panel pins on your motherboard,
and pins around area write in very small letter and see pins with making on your cable and fitted in that board.
Regards,
Ravindra Shah
Posted on Jun 04, 2009
Method of connecting cables
You say power cables, is this regarding the main power cable goign to the power box inside the server tower, or is this regarding the power cable that hook up the Hard Drives on the mother board? Pleas re-ask and clarify your question for us.
Mar 22, 2014 | MSI 848p neo2-v intel 848p socket 775 atx...
The power won't come on. The blue light comes on for a second-no sounds-then nothing. Have changed power cords, outlets.
i can understand the amount of inconvenience that you are facing.
Please check if the fan of the power supply if it is running or not, if it is not then remove the biggest connector from the mother-board which is coming out from the power supply. then check if the fan runs or not, if it is not then replace the power supply.
If the fan starts to run then please make sure that all the cables coming out from the power supply are properly plugged in the mother-board. Then try changing the slots of the memory(RAM), if you have more than 1 memory stick installed then remove the memory sticks one by one to see if it works.
In case all of this doesn't work then the issue is with the mother board and you need to go to a local technician for further support so that they can check if it can be repaired.
Regards
Anand Sachan
Nov 02, 2010 | HP PAVILION A6230N DESKTOP PC
No lights no power no fan
Please check if all the power cables are plugged in properly and check whether the fan in power supply is running after powering the system.
1. If the power supply fan is running then remove the memory( RAM) installed in your system, try changing the slot and if the issue still persists then the issue is with the motherboard and then you would need to check with the local technician.
2. In case the power supply fan is not running then removed the main power connector (the biggest one coming out from the power supply and going into the mother board) from the mother board. Check if the power supply fan runs or not, if it does then perform 'step 1' and if it doesn't then replace the power supply.
Regards
Anand Sachan
Nov 02, 2010 | Dell (1K529) Motherboard
Hp 873n desktop opened case to clean, was very dirty (alot of dust bunnys) unpluged and took outside to blow it out with canned air cleaned all fans and entire case pluged in all and fired it off and got 1...
Wow...did you use a vacume anyware near the mother board? the static on the end of a vacume hose is REALLY BAD NEWS TO A MOTHER BOARD.
Try to reseat all cables and plug's. try to boot again.
If that doesn't work try this.
Remove all PCI DEVICES. Try to boot with just the power cable... bare bone mother board....will it post?
If not remove the board from the case...try booting again...if she doesn't boot ast this point , the board took a static hit...she's toast...sry..:)
Please leave feed back
Thanks
Feb 23, 2010 | HP Media Center PC 873n (P9875A#ABA) PC...
How to connect power led ,HDD,Reset,power SW cables in ESYS 865gv/775 Mother board. Thank you
Here is the link to read and find out where you connect power led & etc.:
A tip where you can recognize also in your motherboard.
Rhis is where you will hook in the connections from your case. These are mostly the different lights on your case, such as power on, hard drive activity etc.
Open this browser:
www.yboyandrei.com/865GV
If i am helpful to you, please rate me.
Thank you.
Yboyandrei
Aug 25, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
MY COMPUTER WONT TURN ON !!!
for connecting these sw
just see on mother board there you see nearabout 16 pins on right hand bottem of mother board
there you have an integation of connectorfrom right hand corner i.e 1-3 for reset sw, 2-4 for power sw and last switches for front usb and audio
if you have p-3 then you dont attech audio and usb cables on *********** board
Apr 07, 2009 | Computers & Internet
Connecting the wires
>>>>User Manual Download<<<<
Here is the user manual of your MB. Look for ports and were to connect cables. The more hard are those little cables from the front panel chassis. Take a look and you would find the right combination. In computers everything goes one way just don't try to force anything. Let us Know....
Sep 18, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
HP (D7580-60003) Motherboard Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
