Question about NetGear WGR614 Wireless Router
I lost my pass phrase and cant hook up my new laptop without it ,my router is working fine on the other computers but I just moved and can't find my notebook with password or phrase in it.....how can I recover it or change it
  • 33 Answers
Are you saying you cannot access your router page like 192.168.0.1 or are you saying your forget your WEP key for wireless?
If you cannot Access your Router page Then a hard reset in order and there should be a black button somewhere on the back you can press and it should reset to system defaults, the password should be admin
If you dont remember your Wep key, go to your Router Page open it up And turn off the Internet security then Turn it back on while changing the password
Posted on Jun 04, 2009
Wireless pass key view
LOST WIFI SECURITY KEY WORD
If you have lost your WEP/WAP wifi key phrase there is no way to recover it except go into the router administration settings and see if it is in plain text there. If not then you will have to make up a new key phase and apply it to ALL your connected devices.
In future, write the key phrase down on a piece of tape and apply it to the bottom of your router. You can use a hint instead of the actual phrase.
I use the memo function of my cell phone to keep all my passwords and keys.
Apr 11, 2014 | Microsoft XP Computers & Internet
I cannot find the netgear router security code so that I can use my laptop in my house. Where would I find this on my router?
Open a new internet window and go to "192.168.0.1" without the quotes You should be prompted for a username and password.
  • Username = admin
  • Password = password
    • For older devices, password = 1234
If this does not work, you should reset the router to factory settings by pushing a pin in the button located in the back of the router.
May 29, 2011 | Computers & Internet
How i can setup Wifi to Thomson (DCM305R) modem?
Hello, Thanks for the opportunity to help you.
First off you modem there is not wifi but cant be hooked up to a wifi router that you can purchase from any computer store.
The modem would hook up to the router directly instead of hooking to the computer via RJ45 "ethernet cable"
The wifi router would then share that connection. You would need to set that up with some security I recommend WPA 2 encryption you will need to select a password/ or pass phrase.
In order for me to give you the How To's we would need some more information such as:
1. Brand name of router
2. Model number
Click here for some basic information on how to hook up a cable modem to a wifi router.
Thanks for using Fixya.com , We hope your found this Very Helpful.
Jan 25, 2011 | RCA Thomson Digital Cable Modem (DCM305R)
How do i recover a wep key for a cisco router model wrt310n and thanks
WEP keys are created by the user in the setup or in the security setting inside the router.
You will want to enter into the router via the ip 192.168.1.1 for this model
and check the "key renewal" instruction for the WPA pass-phrase.
this is where you do changes for router security. This pass-phrase is usually 63 characters.
Here are some additional instructions:
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP a dresses.
5. Set the laptop up in the router by WPA KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Jun 18, 2010 | Linksys Computers & Internet
I GOT A NET GEAR WIRELESS ROUGHTER AND LOST THE BOOKLET AND CANT GET IT TO PICK UP A SIGNSAL OR PASS WORD FOR I POD TOUCH
netgear www.router.com www.router.net 129.168.1.1
any above addresses to get into the router put in the password and user name defualt is admin and password is password.
Go into the wiress security on the left hane pane select that create a pass key or phrase make sure its set for 64 bits and you should be fine.
Thanks please do rate.
Jan 13, 2010 | Apple iPod touch
I have internet with time warner so have linksys router wireless'but when a try to connect to other computer don,t work
First, check to make sure that you can get Internet through a wired connection, if you can't then wireless won't work either. Second, if you can, then try connecting to the wireless without using WEP or any security. You can turn this off by going to 192.168.1.1 in your web browser while wired to the router from your PC and go under wireless security. If you can connect from an unsecured access point then set up a WEP key with a pass-phrase and when you are asked for the pass-phrase from the PC use the the hex key 1 that is generated by the router instead of the pass-phrase. You should have no problem connecting. Thye wizard that comes on the configuration CD will not set up your wireless correctly, you really have to configure the system using the IP.
Oct 01, 2009 | Linksys Wireless-G Broadband Router
I can't access my wireless internet, asking for a pass phrase
the D Link router is what is causing the issue - Cut your losses and get a linksys ( netgears are ok so maybe one of those ) but avoid D Link and Belkin equipment as far as wireless or networking goes.
An apple airport extreme ( although a bit more expensive ) are very good.
Jun 28, 2009 | D-Link DI 514 Wireless Router (DI-514)
Lost softwera
You don't need any special software, only a browser. Just type the following URL:
http://192.168.1.1
You need to be wired to the router (unless your WiFi setup is working OK).
Feb 03, 2009 | Linksys Wireless-G WRT54G Router
I'm having problems getting my 2nd computer hooked up on my wrt54g router. please help
Try it wired first, if doesn't work its your basic configuration if it does try removing WEP and running unsecured. If you can connect focus on your WEP settings, if you can't connect focus on the antennae, hardware, and radio settings. If you connect without WEP and can't connect with, use the 64bit hex key it generates instead of your pass phrase. Many wireless cards have trouble using the passphrase.
Dec 31, 2008 | Linksys Wireless-G WRT54G Router
Laptop cannot connect to router with WPA-PSK security
What I believe here is you are not typing in the pass-phrase(wireless password) correctly.
Go to 192.168.1.1 log on to the router ,in wireless section you will find the pass phrase,, create a new one and then try to connect.
Jun 09, 2008 | Intel 2915ABG 802.11a, 802.11g/b Wireless...
NetGear WGR614 Wireless Router Logo
175 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
