Home | Routers | Accessing encrypted wir...
Routers
Problem for Routers
Generic problem for all Routers
Accessing encrypted wireless network
By Mike Ludd on Oct 24, 2007
Encryption problem:
I recently set up a wireless network to connect a new Sony Vaio lap top to the internet via a cable modem. The router I bought is a D-link rangebooster N 650 router.
When I set this up it was encrypted with a password. Every time I have used this link via the sony I have not had to type in the password, it has been done automatically.
I installed a D-Link USB wireless adapter (model not DWL- G122) on my old PC to enable that computer to communicate with the internet via the D-link router.
I followed the installation instructions on the CD and book supplied. It appears to have installed correctly.
I then went to connect to my router and selected my wireless network by name. I then followed the windows XP instructions for configuring to my wireless network.
When I typed in what I thought was the password into the space saying "network key"  a diologue box popped up that told me the network key was only 5 characters long and I had typed 8.
Is the "Network key" the password that I used for the router?
If it is I have forgotten my password.
Is there a way of finding out what the forgotten encryption password is, or does it have to be reset? My concern is that if the router has to be reset, I might risk losing the internet connection via the Sony Vaio and will have no internet.
Any ideas?
Thanks.
Mike Ludd
Same Problem
May 29, 2008
-   Really sorry but I think I have the same problem. The web interface you have posted doesnt open anything if I put it in my browser. I have switched from a PC to a MacPro and after having set up Zoom have lost all the Zoom information. It is set to a password so although I can get online on my Mac, but cant connect wirelessly from my PC laptop. Help?-   juliandavies
Solution #1
posted on Oct 25, 2007
Somewhat Helpful)
Benimur
Rank: Guru
Rating: 88%, 3768 votes
Hi Mike,
The password is only used in conjunction with the username when accessing the router via its web interface at 192.168.0.1. At default, the username is "admin" and the password is
none/blank. Initially, to acces some ISPs, the DLink would also ask for a password but once set will never ask again except when a reset is done.
On the old PC with the D-Link DWL -G122:
1. there is no need for a network key since you are not using one (as you posted) and therefore should be set to Open/Disabled/Not used;
2. When you installed the software from the CD that came with  the D-Link USB wireless adapter on the old PC, other than the usual driver, it is highly possible that another software was installed. This is the DLink Configuration Utility which should be used to configure/connect the G122 rather than the built-in Windows WiFi Configuration. You can verify if this was installed under your Start/All Programs/D-Link Air USB/D-Link Air Utility. If present, use this to initially configure the G122.
hope this be of some help/idea. Pls post back how things turned up or should you need further information.
Good luck and kind regards.
Was this helpful?
Yes
No
Popular Solutions for Routers
Questions and Unsolved Problems for Routers
Answer
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas,... (More)
Answer
I set up my laptop using a Belkin wireless router, and it is o.k. thro ethernet by does not... (More)
Answer
Dynamode BR6004W G2M all LEDs flashing at the same time. I can connect vis the modem directly but... (More)
Answer
change my nat from strict to open
Answer
I bought a used ADTRAN 612 - I have no idea as to what the ID/PASSWORD combo is. How do I resest... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Routers:
Top Router Experts
Rank: Guru Guru
Solutions: 1342
Experience: I have owned a computer networking sales and service company.
Ask Me
Find more Router Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
