I HAVE A SAMSUNG PS-42P2SB 42INCH PLASMA BUT IT WONT TURN ON THE POWER LIGHT AT THE BOTTOM IS ON BUT NOTHING HAPPENS PLEASE COULD YOU ADVISE ME ON WHICH PART I NEED AND WERE TO GET IT THANKS
SOURCE: tv samsung plasma
From the specifications here - http://www.samsung.com/he/products/tvplasmadisplay/plasmatv/ps42p2sb.asp?page=Specifications
it comes with a HD digital tuner. It may have an analog tuner aswell, but is unclear from the information (2 tuners, so allows picture-in-picture).
From the Picture, it appears that the tuner may be built into the seperate box, which comes with the plasma.
SOURCE: Horizontal green bar on plasma tv, please help!
There is a fault on the processing board that is now causeing the only signal to be sent to the panel to be that green bar. Most likely a capacitor has failed. This may be a relatively simple repair or more expenmsive. In either case, the most expensive part (the panel) is OK. This is not a DIY repair. Please seek assistance at a service center. It is worth the estimate cost to get a complete diagnosis as without seeing the actual unit, I can;t say for sure whether or not the board is repairable.
Thanks,
Dan
Testimonial: "Thanks so much, I'll take it to get a quote. Really helpful!!"
SOURCE: SSP-R4232 Plasma TV, blue light on, but tv wont turn on.
At this point it appears that your main board is probably bad. You most likely have a 5 volt scource going to the main board but its not powering up the set. The main board is part number BN94-00796A.
You might want to have a technician look at the TV to verify this as the issue before purchasing it. Please take a few moments to rate my answer. Thank you.
Testimonial: "I was extremely grateful to have a response in such a short amount of time, as soon as I replace the part that was suggested as bad to me, Ill post."
SOURCE: 32'' Samsung LCD HDTV - will not turn on
needs power supply board replaced. VERY common problem, can call 1-800-samsung for nearest service center.
SOURCE: my samsung LN32A330J1 won't power
You need the capacitors on the power supply board replaced. Samsung is covering the cost to repair this problem on your model. Just call 1-800-samsung and they should set you up for repair.
