Hi, my bike dash comes on and on pressing the button it turns over but it just wont start. neutral light is on and all fuses seem ok. battery seems fine it just wont fire up. also I have no running lights, no side lights, head lights, tail lights, or indicators. the brake light and pass light are fine tho. I started the bike last week and it was fine with none of the above problems and it hasent moved since. Helppppp
SOURCE: pw50 problems stating bike
hey there matey,, just to run a few things with,, have u taken the spark plug out and cleaned it up,,try a new plug 1st,, to be sure, or if u have a new plug,, take out the spark plug place it back in its cap and rest it on the cylinder head and either elec start it or kick it over and make sure u have a spark ,, if all is ok on the above,, then turn to fuel and carburetta, make sure fuel is gettin to the carb 1st,, but u say u do eventually gettin it goin ,,then theres a blockage in jets ,,undu the bottom of the carb clean out the bowl, ,in the carb u will see a brass jet, un screw that and the needle guide that the jets screwed in to and using a pin or needle,poke the small hole clean so u can see light threw them,, bung it all back together and pray,, if no joy il get back to ,, ok m8, enjoy
SOURCE: I have a 2005 yamaha venture royal star and i just
If it wont do anything then it is likely that youve popped a fuse
But it sounds like the battery isnt being charged properly. Make sure the voltage across the batt terminals is at least 13.5v at tickover rising to no more than 15.5v at higher revs
Ride-Safe
Bike-Doc
Please mark this as helpful (if it has been!!)
Testimonial: "thanks, I will try what you reccommended"
SOURCE: Starter does not turn
chec fuses-bad ones can appear normal-inspec if connecs r tite at starter n solenoid area-n also relays--starter may be bad ur bike is 10yrs-test it--that electric clutch may be malfunctionin too
SOURCE: FUSE IS GOOD BATTERY HAS LIFE BRAKE LIGHT IS ON. YAMAHA BWS 2004
Yes instrument lights at least should come on.
Power goes from the battery to the ignition switch via the main fuse, & then splits to ignition & lights (via auxiliary fuses if present) which are separate circuits.
The problem could be an auxiliary fuse (if fitted) then contacts inside the ignition switch or wiring/connections from the ignition switch out to the ignition circuit
That is presuming the cluster light bulbs work!
Hope this helps ( if so please mark as very helpful)
Ride Safe
Bike-Doc
SOURCE: Hello, My Yamaha YZF600 motorcycle wont start.
Hi there jfdnet! Yeah if you hear the relay operating and the starter is getting no juies then you need to replace the realy. First i would check you see if you get power to the starter. Use a light tester to check the hot wire on the starter and if you do have power the starter is bad. If you have power going to the relay but not going to the starter then the relay needs to be replaced. It is always good to use a light tester of multimeter to back track from the problem to find the source. Example: You turn the ign. switch but the starter wont turn, start with the tester at the stater them back track up to the ign. switch. Eventually you will find where the power hits a "brick wall" of a faulty part. I hope that this helps you out. Post any more questions you may have.
i put in a new ignition. now my fuel pump wont ingage and my neutral
light wont come on. for some reason my bike will not start or turn over.
what is wrong and how do i fix it?
Posted by
sgaffigan on Feb 10, 2009
