Question about Toshiba 36A40 36" TV
No blue color
Tv makes good picture, just no blue color
  • 129 Answers
Good day.
The problem may have been caused by loose terminals of parts. Yuo can have resoldered.
chris
Posted on Mar 23, 2008
What is a good Microwave Leak detector - make  absolute measurements? Can a cell phone be used to detects leaks from Microwave ovens.?
I replaced two convergence chips the resistors were all fine. This took care of the 3D look. I also replaced the coolant in the blue and green although it was the blue which was badly contaminated. The picture is now clearer than before but I am unable to get color. I can see vibrant colors when I pull up the TV's menu. I can see the colors in the convergence menu as well but no color in the picture. The color controls only make the picture brighter or darker. It is sepia in color not black and white. What could this be?
Feb 22, 2010 | Philips 51PW9303 51" Rear Projection...
Picture flashing, weak color. whenflashing stops
I have the same problem with a WD 73732. After about an hour fleshtones go blue / purple, and picture flashes. I gutted the set, and ran it on the bench, and found that a sensor on the color wheel (a small external board), acts up when it gets hot. Cooling the board fixed the picture. I'm going to try to find a replacement part, and then make vents in the color wheel cover so it doesn't get so hot in there.
Jan 22, 2010 | Mitsubishi WD-73827 73" HDTV DLP TV
No Red color at all. The convergence feature does not work either. Lots of green and blue RCA Model D52W59
Red color gun has failed, which will make the picture over saturated with the other two colors(blue,green) the bad news is the three color guns need to be replace in a set(all at the same time) because if you only replace the red it will over saturate the older blue, green guns then your picture will be mostly red.Unfortunently in most cases it's not worth the investment, better off to purchase a new tv. Good luck !
Nov 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have sound but no picture on the screen.. What did i do wrong
Hello sir, hi, please check the video cable. If you are using the three color audio/video cable, the yellow one goes to the yellow input of the TV to the yellow output of the DVD recorder. Then check the TVs audio video settings, the TV should be in the video channel, if there are several video channel, check where the video is coming in. Make sure that the yellow cable is good. you can swap several cables to check.
If your TV is component input, put the red green and blue wires to their respective color port, one end is on the DVD recorder, and the other on the TV. make sure your cables are good. Do the same thing with the S-video and HDMI cable. if your TV has this.
Nov 21, 2009 | Daewoo DVRS05 DVD Recorder/VCR
My componet/av only shows black and white on my vizio vp422
The 37" Vizio I just bought has a very confusing feature where the same input can be used as either the Y channel of the component or the full video channel for composite. If you plug a component source into the TV and then select the composite input ("AV" on the remote), you will see a black and white version of the full component signal (makes sense as the Y channel is just the luminance component). As sad as it is, I was stumped by this for a while until I happened to hit "COMP" and got full color. FWIW, the manual warns about this, but it really doesn't emphasize the point. I wonder how many returns they get because of this.
Mar 16, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Yellowish picture everything else is good
That model had lots of problems, it sounds like your loosing blue. Try putting up a color bar chart and see if you have blue. Color bar is availible on most cable systems. ggod luck
Feb 28, 2009 | Samsung PCK520R TV
Yellowish monitor display
You have no blue gun transmission. Check your work around the tube and make sure you have good connections. Ohterwise it's in the blue gun circuitry.
Feb 13, 2009 | Toshiba 36A40 36" TV
Color of people's faces in movies played via DVD is now blue since connected to LCD TV
The reason the picture is blue on the DVD is because you have poor video cables running the feed, probably RCA yellow cable im guessing. Get some nice component cables for the DVD feed and it will fix you right up.
Dec 26, 2007 | Televison & Video
Sony bravia lcd tv-
If you are using a HD cable box or satelite with component outputs, be sure that all 3 cables ( green, red, and blue ) are making good connection.A loss of red or blue will cause color shift. Usually,if the tv menu comes up as the correct color but the picture dose'nt, it is most likely a signal problem.
Jul 01, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Toshiba 36A40 36" TV Logo
26 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
