Question about Homelite Garden
Motor of Homelite ST 385 reves but string head does not turn??
Motor Homelite ST 385 reves but string head does not turn??
SOURCE: Replacing the bump head on homelite string trimmer
undo the 2 screws on top of the carb. The bulb is part of a 2 piece cap undo that and it fall out.
Posted on May 16, 2009
#1 Taper
  • 1041 Answers
SOURCE: homelite st-175g trimmer
This is for a duel line trimmer. I hope this will help.
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position. Put cap on and GO CRAZY!
Jim
Posted on Jun 19, 2009
#1 Taper
  • 1041 Answers
SOURCE: Installing new line on my string grass trimmer
Jim
Posted on Jul 03, 2009
  • 40 Answers
SOURCE: what is the gas oil mixture on a homelite st-155 string trimmer?
your trimmer should give yu th fuel ratio somewhere close to where you fill it. It will be in this orat- 50:1 forexample
Posted on Sep 12, 2009
  • 279 Answers
SOURCE: Homelite Mighty Lite 26CS Model21004D
Once you have the string wound onto the spool, place the spool onto the shaft and pull the strings out of the slots so that the string feeds through the holes without going through the slots. Good luck...Lee
Posted on Jul 26, 2010
Need two parts for homelite gas trimmer model number st -145 i need the retainer and the string head and the post can i order on line or do you have a dealer in s.c. i live in spartanburg s. c. also...
You'll probably need to just purchase a replacement head for your trimmer. You can buy one from PartsBuggy.com here. You'll need part #385-580.
Please note: The replacement parts shown when you click the link for the item # are replacement parts for the head being sold and may not necessarily fit the original Homelite head that may be on your trimmer.
Aug 29, 2011 | Garden
I have a homelite ST-175G string trimmer. How far out do you turn the two carb adjustment screws so it will start?
I would like you to look at this carburetor tuning tutorial by a major carburetor manufacturer. They answer all your questions here:
http://www.zamacarb.com/tipspage.html
May 01, 2011 | Homelite Garden
Jul 26, 2010 | Homelite Mighty Lite Lawn Trimmer
I have a homelite k-100 the string head was converted to a blade head, I want it back to a string but cant get the head off. is there a trick to this?
Push in on the head then turn after you have turned it about a full round it should just pull right out.
Aug 23, 2009 | Homelite Garden
How do you fix homelite st 185 weedwacker pull start
Here is a link to that weed cutter...
http://www.odref.com/homelite/string-trimmers/ut-15039a.PDF
you need to unscrew part#37 .. it may be on very tight... hope this helps
Tobaz
Jun 17, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite strin trimmer head wont rotate
The only way to access the bottom of the metal shaft is to break it. This is fused on at the factory. It sounds like your flexshaft has twisted in two. Remove the flex shaft from the engine end and see if it is in one whole piece or is damaged in someway. If it rotates at the top but doesn't rotate at the string head this is probably the problem. However, Homelite no longer offers just the flex shaft for purchase. You would probably have to purchase the shaft and the tube as a unit.
But if you are saying the spool and string is not turning at the bottom it could be that the cup which holds the string has worn and can not longer be turned by the shaft. Replace the cup that holds the string.
Another possibility is that the shaft have moved forward, away from the engine and just need to be jammed back in, and retightened (the handle grip and the boom clamp).
May 16, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
186 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
