No 1920*1080 in directX 10 on ati hd 4850x2
In games running on directX 10 i allways get an error from my tv ''bad signal'' when i choose 1920*1080
in dx 9 with 1920*1080 or dx 10 with other resolutions everything works fine
i can't imagine what's the fail
my graphic card is a Sapphire ATI Radeon HD 4850 X2
(isn't listed)
thanks in advance
  • gzuz1010
    gzuz1010 May 11, 2010
    what kind of cable are you using to connect to yout monitor, which monitor do you have, and can you name some of the games with the problem plz?
thassall4295
  • 91 Answers
SOURCE: Sapphire HD 2600 XT Driver Problems
To get your drivers follow these simply steps below:
First go to this website "CLICK HERE" - once you've done that fill in all the details of your "Graphics Card" then download them.
After you've completed the installation restart your computer just to make everything work correctly.
Note: after you've installed the driver your resolution when you've restarted your computer will be diffrenrent and may need changing.
Good luck. Hope my solution was helpful in someway. Further problems of any kind just leave a message on here and i will get back to you a.s.a.p.
Posted on Dec 02, 2007
sparky1500
  • 1066 Answers
SOURCE: Graphics card support to motherboard Intel D845GBV
should work good
Posted on May 17, 2008
map9966
  • 2351 Answers
Just because you have a new video card with CD drivers does not mean the drivers are the latest. Go to Saffhire directly & download the latest driver software for you're card.
http://www.sapphiretech.com/us/support/drivers.php
Uninstall any older driver software before installing newer. Try not to restart the system between installs.
And update windows before you install the new drivers. You do not need to install WinXP SP3. Unless you want too.
Posted on May 18, 2008
SOURCE: ATI Radeon HD 2400 Pro - PowerDVD DX Not Working
I had the same problem on my Dell Studio Hybrid and solved it by doing a Windows Update. Now I can play Commercial DVD's inside of Media center.
Posted on Jun 24, 2009
  • 117 Answers
SOURCE: Ati Radeon hd 4850 overheating
Hello b ciprian,
The trick to keeping a CPU or Graphics Card from overheating is to be able to supply the largest amount of cool air coming in. I have gone as far as using a Dremel to router holes in the side of a PC case to add more fans.
Typically I like to have (3)three 80mm or 120mm intake fans in the side panel, (2) 80mm or 120mm fans as exhaust fans. I even remove the front panel to see how many and what size of Intake fans I can put there.
With almost every graphics card that I have used or installed, I have always added a 3rd party VGA cooler. Most of the factory VGA Coolers are mediocre at best. When ever I install a 3rd party VGA cooler, I always use Arctic Silver 5 Thermal Compound which is 99.9% Silver, which goes between the VGA Cooler Heatsink and the GPU(graphics processing unit).
You can also buy rather inexspensive heatsink kits(applied with thermal tape) that you can attach to the memory chips on the graphics card itself.
I also replace the factory thermal paste that is used for the CPU heatsink/fan with Arctic SIlver 5.
While I am at it, I buy a heatsink for the southbridge, and sometimes the northbridge, as well. Since this is a VERTICAL application, you really should consider using Thermal Tape or Thermal Adhesive. You can use Thermal Adhesive for the Northbridge and Southbridge Heatsinks ONLY. DO NOT use thermal adhesive on your CPU or VGA Cooler.
Here are some nice VGA memory heatsink kits from Newegg.Com http://www.newegg.com/Product/Product.aspx?Item=N82E16835185083 or http://www.newegg.com/Product/Product.aspx?Item=N82E16835887017
Here is Arctic Silver 5 Thermal Compound: http://www.newegg.com/Product/Product.aspx?Item=N82E16835100007
Here is the link to the CPU heatsinks. Just find the one that is compatible to your motherboard. http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=heatsinks
Here is a HIGHLY RECOMMENDED item. This is the VGA cooler that is compatible with the HD 4850/70/90 http://www.newegg.com/Product/Product.aspx?Item=N82E16835118037
And here is a link for a fairly universal VGA cooler. It costs less but I've had it on my card for one year now and love it. But your card runs A LOT hotter than mine so I would choose the one above. http://www.newegg.com/Product/Product.aspx?Item=N82E16835110015
Here is a link to case fans. You really shouldn't buy any fan that is over $8. http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=case+fans&x=0&y=0
If you order fans for your case, they should come supplied with the 4-pin Molex adapter for the PSU. If not, your local PC repair shop or places such as RadioShack should have them.
I think I covered most of the bases. Hope all goes well for you.
Posted on Jul 13, 2009
I install Burnout paradise the ultimate box and got an error when try to play the game... this machine gpu does not support shader model3 which is required to run this game. I have Intel(R) G33/G31 Express...
you must upgrade your graphic card. the problem as nothing to do with your chipset. This are the minimum requeriments to run the game:
OS: Windows XP/Vista
Processor: Intel Pentium 4 @ 2.8 GHz / AMD Athlon 64 3000+
Memory: 1 Gb
Hard Drive: 4 Gb free
Video Memory: 128 Mb
Video Card: nVidia GeForce 6600 / ATI Radeon X1300
Sound Card: DirectX Compatible
Network: Broadband Internet Connection for Online Multiplayer
DirectX: 9.0c
Keyboard
Mouse
DVD Rom Drive
Recommended System Requirements
Processor: Intel Core 2 DUO @ 2.5 GHz / AMD Athlon 64 X2 5200+
Memory: 2 Gb
Video Memory: 512 Mb
Video Card: nVidia GeForce 8800 / ATI Radeon HD 2900
DirectX: 9.0c
Keyboard
Mouse
DVD Rom Drive
Aug 26, 2012 | Computers & Internet
Rig n Roll has stoped orking error
Does the game run off a CD - if so the CD many need cleaning.
Make sure you computer meets the system requirements:
# Operating System: Windows 2000/XP/Vista/7
# Processor: Intel Pentium 4 2,4 GHz
# Memory: 1.0 GB
# Video card: NVIDIA GeForce 5700 or ATI Radeon X800 with 128 Mb, DirectX 9.0 compatible
# Sound card: DirectX 9.0 compatible
# Hard disc: 10 GB free HD space
If you have met all requirements and the disc is fine then try installing and reinstalling
Mar 02, 2011 | Computers & Internet
Can the Dell Latitude D610 run any of the following games: Age of Conan Star Trek Online Champions Online Aion
Check your system if it meets the following requirements
Age of Conan
Required
OS: Windows Vista/XP
Processor: 3GHz Pentium IV
RAM: 1GB RAM
Video Card: Shader Model 2.0 and 128MB RAM: NVIDIA GeForce 5800 or ATI 9800
Recommended
Processor: Intel Core 2 Duo 2.4 GHz (E6600) or better
Video Card: NVIDIA GeForce 7950GX2 or better
RAM: 2GB or more
Enhanced for: DirectX 10, 64-bit processors, multi-core
Supports Parental Controls on Windows Vista
Start Trek
System Requirements
  • OS: Windows XP SP2 / Windows Vista / Windows 7 (32 or 64-bit)
  • CPU: Intel Core 2 Duo 1.8 Ghz or AMD Athlon X2 3800+
  • Memory: 1GB RAM
  • Video: NVIDIA GeForce 7950 / ATI Radeon X1800 / Intel HD Graphics
  • Sound: DirectX 9.0c Compatible Soundcard
  • DirectX: Version 9.0c or Higher
  • HDD: 8GB Free Disk Space
  • Network: Internet Broadband Connection Required
  • Disc: 6X DVD-ROM
Recommended System Configuration
  • CPU: Intel E8400 Core 2 Duo or AMD Athlon X2 5600+
  • Memory: 2GB RAM+
  • Video: NVIDIA GeForce 8800 / ATI Radeon HD 3850+
  • Disc: 6X DVD-ROM
To check your system hardware> click on start>all programs>accessories>system tools> system information.
Thanks for using Fixya
proton
Mar 27, 2010 | Dell Latitude D610 Notebook
Pixel shader error 06 on my optiplex 330
Graphics Card
Minimum Requirement
VRAM (256 MB)
DirectX 9.0c / Shader 3.0
NVIDIA GeForce 6800 series
Your Dell has an Intel GMA 3000 onboard with up to 256 MB shared memory and isn't listed so probably isn't supported.
Mar 17, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
How can i configure ATI Radeon 9250 with some pc games requiring a video card as like the nvidia geforce ... is this a matter of great conflict of playing a gaming network???
128MB or 256MB of 333MHz DDR memory
accelerates the latest cutting edge 3D applications
Available in both a 128-bit and 64-bit memory data path interface
ATI RADEON™ 9250 VPU operating at 240 MHz
Supports the AGP 8X and AGP 4x standard or PCI Bus, providing a high-speed link between the graphics board and the rest of the PC
Four pixel shader pipeline
Full support for Microsoft® DirectX® 8.1 and DX9 compliance and the latest OpenGL® functionality
VIDEO IMMERSION™ and FULLSTREAM™ technologies which provide for amazing video playback quality.
Integrated DV support for Flat Panel displays
Powered by CATALYST™ -
The industry's most stable unified graphics software
But since its only a 256 mb graphics card.
ATI Radeon™ HD 4770 Graphics is the best if you don't want to buy a costly one. its the most economical graphicss card.
ATI Radeon™ HD 4770DirectX®10.1
512MB, GDDR5
640 Stream Processors
ATI Stream Technology
51.2 GB/s Memory Bandwidth
DVI, DVI, TVO
ATI CrossFireX™ Technology (up to 2 GPUs)
PCI Express 2.0 x 16
since most of the games are compatible with Directx 10 and 11 this would be the one..
Jan 22, 2010 | Video Game Consoles & Games
Computer restarts on game start
Remove all traces of ATI drivers from add/remove programs and reboot before trying to install the newest Catalyst Control Center. The latest - 9.4 - does NOT have your card listed (they list the PCIe version, not AGP).
Recently ATI removed support for many of their "legacy" cards. 9.3 may be of more use to you.
Apr 13, 2009 | ATI RADEON HD 2400 PRO Graphic Card
Inexpensive Graphics Card for Notebook Video Editing?
Definetly the ati one. 120 stream processors is really good and it has
direct x10.
Jan 08, 2009 | HP Pavilion dv6000z Notebook
Program won't run, error message says it can't find 3d software.
If the error message says "Cannot find any compatible Direct 3D devices" it means that you do not have a supported video on your system, and that you need to upgrade your video card.
The Recommended and Minimum System Requirements for the are game mentioned below your system has to meet at least the Minimum System Requirements for the game to launch on your system.
Recommended System Requirements:
- 3 GHz Intel Pentium 4 or equivalent processor
- 1GB System Ram
- ATI Radeon X800 series, NVIDIA GeForce 6800 series or higher video card
1.2. Minimum System Requirements
Minimum System Requirements:
- Windows XP
- 512MB System RAM
- 2 GHz Intel Pentium 4 or equivalent processor
- 128MB Direct3D compatible video card with DirectX 9.0c compatible driver
- CD-ROM or DVD-ROM drive
- 4.6GB free hard disk space
- DirectX 9.0c (included)
- DirectX 8.1 compatible sound card
- Microsoft .NET 2.0 Framework for toolset (included)
- Broadband connection for multiplayer online play
- Keyboard, Mouse
1.3. Supported Video Cards
- ATI Radeon X1900 series
- ATI Radeon X1800 series
- ATI Radeon X1600 series
- ATI Radeon X1300 series
- ATI Radeon X850 series
- ATI Radeon X700 series
- ATI Radeon X600 series
- ATI Radeon X300 series
- ATI Radeon 9800 series
- ATI Radeon 9600 series
- ATI Radeon 9500 series
- NVIDIA GeForce 7900 series
- NVIDIA GeForce 7800 series
- NVIDIA GeForce 7600 series
- NVIDIA GeForce 7300 series
- NVIDIA GeForce 6800 series
- NVIDIA GeForce 6600 series
- NVIDIA GeForce 6500 series
- NVIDIA GeForce 6200 series
- NVIDIA GeForce 6100 series
- NVIDIA GeForce FX 5900 series
- NVIDIA GeForce FX 5700 series
- NVIDIA GeForce FX 5600 series
- NVIDIA GeForce FX 5500 series
Oct 28, 2008 | Video Game Consoles & Games
New Game I Bought
BAD IDEA to post youe email address !!!
May be a video card issue or directX not being at latest version.
What are the specs for you PC?
The min spec to run this game is as follows
OS: Windows® XP, OR Windows Vista™
CPU: Athlon™ 1500+, Pentium® 1.5 GHz, or faster (2200+ or 2.2 GHz for Windows Vista™)
RAM: 512 MB (1 GB for Windows Vista™)
Disc Drive: DVD-ROM
Hard Drive: 8 GB of uncompressed free space
Video: 128 MB video RAM, DirectX® 9.0c-compatible
DirectX® 9 Minimum card: ATI® Radeon® x700 Pro and above
DirectX® 9 Minimum card: NVIDIA® GeForce® 6600 GT and above
Sound: DirectX® 9.0c-compatible
Input: Keyboard and mouse
if your system is not at least at this spec the game probably will not run
Jul 03, 2008 | Video Game Consoles & Games
I just installed rainbowsix/vegas2 the gameis installed the music plays but the game screen remains blank an the music keeps playing my computer is running windows vista.
you need to to check the display settings and the system requirement before installing and running the game
System Requirements
Windows XP/Vista
3GHz Processor (3.5GHz recommended)
1GB RAM
7GB Hard Disk Space
4x speed DVD-ROM Drive
128MB DirectX 9.0c compatible, Shader 3.0 enabled Video Card (256MB DirectX 9.0c compatible Video Card recommended)
Latest DirectX 9.0c compatible Sound Card
DirectX 9.0c (you may need to download the latest drivers for your video and sound card)
Keyboard, mouse / X-box 360 Controller for Windows
Online multiplayer: broadband Connection with 128Kbps or faster.
*Supported Chipsets: ATI Radeon X1600-X1950/HD 2000 series / HD 3000 series / NVIDIA GeForce 6600/6800/7/8 series.
Laptop models of these cards are not supported but may work.
These are the only ones that will run this game. Additional chipsets may be supported. For an up-to-date list please visit http://support.ubi.com.
System Configuration may require minor adjustments to the configuration of your operating system and/or updates to hardware component drivers
Notice: This game contains technology to prevent copying that may conflict with some disk and virtual drives.
May 23, 2008 | Computers & Internet
Computers & Internet Logo
222 people viewed this question
David Payne
David Payne
