Question about Panasonic NV-GS27 Mini DV Digital Camcorder
Which battery charger is required for this camera?
  • 975 Answers
Http://www.atbatt.com/product/5473.asp click on this link to get your charger , thanks , AJ
Posted on Jun 04, 2009
I have bought a charger for camera but it wont seem to charge
check the voltage and current rating mah for the battery there is a probability that the battery may be of high current rating and your charger of low so it will definetely not charge the battery of the camera or will take too long to charge it..
Jan 19, 2011 | Samsung NV3 Digital Camera
My kodak easyshare camera isn't charging.....we already bought a new battery...and it still wont charge?? The charger is still good and working?
My kodak camera requires taking out the battery pack and charging outside of the camera. My batteries have a generic charger I got off of amazon that has a red and green light on it that tells you whent he batteries are fully charged.
If the charger is blown, that might explain why they are not charging.
Are you trying to use AA batteries instead of the recommended battery pack? I would use the recommended battery packs available through amazon.com.
Jun 25, 2010 | Cameras
Can the BC-NH01 battery charger also charge AAA
In reality, yes. The AAA batteries are to short for the charger, so some fiddling is required. I'd recommend you buy a suitable multicharger instead.
Apr 13, 2010 | Fuji FinePix E550 Digital Camera
The manual says "your camera comes with a compatible charger, your only required to put the battery into the charger and charge the lithium battery directly from the outlet" The camera came with an AC...
You put the battery into the camera. Put the USB end from your computer cord into the end of the AC adapter hook it up to your camera. Ta-da! Everything should be working smoothly in the battery/charger department. :)
Dec 26, 2009 | Vivitar ViviCam 8025 Digital Camera
Trouble with my Canon 5D
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Nov 14, 2009 | Canon EOS-5D Digital Camera
My camera pentax optio wp wont turn on. though is
If possible, check the charger output or the charge status of the batteries with a voltmeter. That will narrow the field for you. If the charger and batteries seem OK, your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
Oct 21, 2009 | Pentax Optio E40 Digital Camera
I plug in my charger and the camera shuts down, including the time. I unplug the charger and the time returns. I cannot charge the battery or run the camera with the charger plugged in. The camera and...
Disconnect the charger from the Camcorder and remove the battery.
Next, clean the metal contact of the battery and the battery compartment.
Then, insert the Battery in the Camcorder and turn it ON then press and hold the power button for 30 seconds.
After resetting the Camcorder to the default settings, connect the AC adaptor to check its operation.
If the issue persists then the DC in jack requires to be serviced.
Sep 15, 2009 | Sony Handycam CCD-TRV108 Camcorder
The red led of the charger is blinking.Is the
I assume you charging battery in charger when it blinks.
This means the charger cannot charge the battery, as the battery has been left too long discharged & annodised inside...new battery required i'm affraid!
Aug 07, 2009 | Olympus FE-220 Digital Camera
Charger needed for both camera and battery???
Greetings AK86,
From what I have gathered, you only need to charge the battery. I believe you can charge the battery in the camera or on a seperate battery charger.
I hope this helps.
Dorothy
Go Ahead. Use Us.
Jun 14, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
I purchased a olympus digital camera FE-220/X-785. When I came home I found there was no battery charger. Where can I obtain a charger from and what sort do I require. I cannot return it to the store...
You can buy a battery charger for radio shack for you camera battery ask them for a universal camera battery charger I got one for 39.99 from them or goto ritz camera they are about the same price. if you want it cheaper ebay is your answer.
Apr 18, 2008 | Cameras
Panasonic NV-GS27 Mini DV Digital Camcorder Logo
48 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
