Question about AT&T Blackberry Curve 8300 Smartphone
Blackberry keeps turning off
My blackberry keeps turning off on its own. I have to take the battery out and put it back in to start it back up. It will let me make calls and end my call halfway through a conversation. It shuts off and turns back on. The end call (red button) doesn't seem to want to work anymore so I have to hit the blackberr button to actually end a call that I want to end and select it with the tracball. The camera also doesn't work on it, it says that too many applications are running and to close them down before trying the camera again, I have a memory card in the phone already. I can't get a new one because my warranty ended in December and when I bought the phone I couldn't purchase insurance. I have to wait until October to get a new one. I don't know what to doo and I really really want to get this powering on and off thing figured out. It's driving me nuts. Thanks.
    Habit-Forming:
    New Friend:
  • 23 Answers
It has told you what to do.
"The camera also doesn't work on it, it says that too many applications are running and to close them down before trying the camera again"
I believe it is telling you that you have used too much of the memory with apps you have installed and/or have running so it fails.
Try uninstalling one or more apps that you do not use frequently and see if that makes a difference.
Phones/tablets/PDAs, etc. need a certain minimum amount of free memory to operate. Older devices have less memory than newer ones and the operating system is subject to constant bloat, as well as users constantly installing apps (and seldom removing unused ones) so the free memory constantly shrinks. When those devices no longer have enough free memory they display symptoms similar to what you describe.
I hope this helps.
Posted on Mar 13, 2017
J Kitch
  • 84 Answers
SOURCE: Blackberry Curve 8300 Camera Problems
The two solutions to this issue are to add a micro SD/SDHC memory card to the device, or to wipe the device (after prefoming a backup in Desktop Manager) to see if that works.
To wipe the device you will go to Options > Security Options > General Settings. Press the menu key, then select wipe handheld.
Posted on Oct 07, 2008
SOURCE: Blackberry camera
turn off ur bb mobile by disconnection the battery from mobile phone and put the battery after 1 min and start the hand set
Posted on Feb 12, 2009
SOURCE: My camera on my blackberry says the same thing
this just happened to me--I took the battery out for 5 minutes, put it back in (the hour glass was spinning for a LONG time) and when the phone turned back on, the camera worked. try this before all the other suggestinos.
Posted on Jul 04, 2009
  • 77 Answers
SOURCE: blackberry curve 8320 camera
Take the battery cover off. Take your finger and press on the lens area (below the flash) you should hear a "snap". Don;t over do it though.
Posted on Jul 28, 2009
bahratt
  • 561 Answers
SOURCE: My camera application on my blackberry is not working.
First, I reccomend to download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues.
If the issue is still present, then it could be hardware related, and may need to be repaired or replaced. I would then suggest contacting your Provider for Hardware Support.
Posted on Jan 15, 2010
HOW DO I RESET MY BLACKBERRY 9770 BOLD BACK TO DEFAULT FACTORY SETTINGS
To reset the Blackberry Bold 9000 / 9700 with three methods. In the first method you hold down the Alt key, the Caps lock key and hit Delete. Your Blackberry will start resetting. This process will take about 2 minutes to complete. The second method is the double reset. Hold down the Alt key, the Caps lock key and hit Delete twice. This method is helpful if your Blackberry is frozen. The third method is called the battery pull method. Remove the battery and keep it out for about 30 seconds and then put it back and power on. It will reset in 2 to 3 minutes. You resort to this method if the first two methods don't work.
Nov 05, 2014 | Cell Phones
When I turn my blackberry on it only goes to 83% then turns off then it will not start again
Almost all OS and/ or software related issues on the BlackBerry can be resolved by removing its battery, leaving the battery out for at least three minutes (the interval the battery is out of the BlackBerry is crucial to the clearing of memory/ registers/ etc.), and then putting the battery back in. The BlackBerry should start now. If it doesn't start you may need to re-install the BlackBerry's OS, click on the link below for detailed instructions on recovering a bricked or nuked BlackBerry.
http://crackberry.com/blackberry-101-lecture-12-how-reload-operating-system-nuked-blackberry
The CrackBerry.com site is the first place I go when I'm looking for BlackBerry information or I encounter a BlackBerry issue I can't solve. I've been using it since 2009 and it has my highest recommendation.
May 26, 2014 | Research In Motion BlackBerry Q5 SQR100-2...
How can i fix my blackberry 9320 for keeping on starting itself
take the battery out for 20 seconds then turn it on, if this doesn't work you should do a hard reset
Mar 15, 2014 | RIM Blackberry Curve 9320 Smartphone -...
Could not start the camera, Close other applications and try opening the camera again. Its a blackberry 9550
I'd suggest, as with most problems a BlackBerry has, turning off the phone, pulling out the battery, putting the battery back in then restarting the phone. If that doesn't work let me know =)
May 12, 2011 | RIM BlackBerry Bold 9700 Smartphone
Blackberry Curve 8330 won't turn back on
Pull the battery out and put back in. Then hit the reset button on back panel.
Sep 05, 2009 | AT&T Blackberry Curve 8300 Smartphone
Phone wont turn back on
YOU CAN FOLLOW THESE STEPS AND TRY :
1. You first need to charge the battery, Take out the battery and SIM card and reinsert the SIM and put the battery back and try switching it on and check, if still persist to be the same issue then you can press cntrl+shift+del OPTION on your phone Keypad which resets the phone.
2. If its still the same problem you can connect the Blackberry to the computer by using DATA CABLE and check whether the Blackberry device is recognised by computer or not
3. If it is recognising then you can reinstall the operating system and check.
Aug 07, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Blackberry bold suddenly shut down
Lots of battery issues with the Bold. Try taking the battery out, keeping it out and connecting to PC with USB. Do any lights come on? Red light should appear. Put battery in while connected to USB.
Another fix that I found for a friend-leave the battery out of the unit for a day-put it in and plug in power cord or USB. It worked.
Mar 20, 2009 | RIM BlackBerry Bold 9000 Smartphone
How do I turn on the rim blackberry 7250
the button on the top. pusch it in. if that dosent work then just take out the battery an put it back in and it shouls start
Dec 02, 2008 | RIM BlackBerry 7250
Blackberry pearl troubleshooting
My phone does the same and i realized that it seems to have something to do with the yahoo messanger and the facebook mobile apps i have installed. It improved once i deleted any such messaging application even though the problem did not dissappear completely.
Jul 07, 2008 | Verizon Communications BlackBerry Pearl...
AT&T Blackberry Curve 8300 Smartphone Logo
11,902 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
