Question about SIIG 2.4G Rf Wireless Presenter with Laser Pointer
Siig Rf Wireless Presenter
My Macbook Pro keeps trying to configure it as a keyboard. It worked on an older Mac, but not my current one
Keybored repair macbook pro 15
Try to check your USB port .
Try to check your keyboard with other Mac System.
If still not working than replace your keyboard with the help of technicians and need more help follow Mac Tech Support .
Apr 24, 2014 | Apple MacBook Pro Notebook
Brand new apple dvd drive will not accept dvd
The DVD works by just pushing it in far enough till you get resistance, then the drive pulls the DVD in by itself. If after it pulls the DVD in, it just ejects it, The DVD drive thinks you are using an incompatible disk.
You can also try resetting the SMC.
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
sad mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Jan 24, 2014 | Apple MacBook PC Notebook
Macbook pro dark screen
Close the lid, attach an external monitor, reopen lid.
Your display should now show on that monitr. If it is, your display on the MacBook Pro may be bad. I would try resetting the PRAM and the SMC before going to an Apple store. The SMC controls the MacBook's power founcts (see below)
Resetting the PRAM may do the trick:
You reset the PRAM by rebooting a Mac and then immediately hold down the Command+Option+P+R keys, you will then hear the Mac reboot sound again, signifying your PRAM has been reset. You must hit the key combination before the grey screen appears otherwise it won't work.
you've tried rebooting, you've reset the PRAM, you've done it all, but your Mac is still behaving strangely. What next? In certain circumstances, resetting your Mac's System Management Controller (SMC) can be a solution. This is sometimes necessary to restore normal lower level system functionality to your Mac.
Here's how to reset the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
When & Why Reset SMC on a Mac? Some Common Hardware Reasons
Typically it's power and hardware related issues that can be helped or resolved by resetting a Mac SMC, particularly if you're having these types of problems:
* Issues with your Mac's cooling fans and fan management: fans run constantly at high speed, fans run high despite low CPU usage and adequate ventilation, fans not working at all, etc
* Power management and battery problems: Mac isn't turning on, sleep isn't working, random shutdowns and reboots, battery isn't charging, Mac won't wake from sleep etc
* Light problems and improper lighting management: battery indicator lights aren't working, display backlighting isn't adjusting to ambient light changes, keyboard backlights not working, etc
* Video and external displays not working: display brightness functionality not working properly, target video mode isn't working properly, external display isn't working, etc
* General performance and functionality problems: abnormally sluggish behavior despite no CPU or disk usage, external ports not working, airport & bluetooth aren't showing up, external devices are not being found, etc
So now that you've concluded you need to reset your SMC (Note that the SMC is on Intel Mac's only), here's how to do it on MacBook's, MacBook Pro's, iMac's, Mac Mini's, and Mac Pro's. Notice that the reset instructions are different for MacBook and MacBook Pro's if you have an internal or detachable battery.
Reset SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro's with an internal non-removable battery
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Jan 12, 2014 | Apple Computers & Internet
Keyboard not working
If you were using a bluetooth keyboard, it may still be looking for that keyboard.
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Nov 22, 2012 | Apple MacBook Air
Keyboard Backlit not coming on at all
Set your backlighting in
Apple menu
System Preferences
Keyboard.
otherwise try:
Resetting the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Jul 08, 2012 | Apple MacBook Air
How to set up and use HP RF 2.4G Presenter ? T.K. balaji
Press the receiver button until it flashing, then press the "right button mouse" on your transmitter for about 5 seconds. Both action should be done in 8 seconds time frame.
Oct 08, 2010 | SIIG 2.4G Rf Wireless Presenter with Laser...
I have bought an Apple Mac notebook but am having problems accessing the internet. I think I have inadvertently changed the password to the wireless router as I have succesfully conected my main computer...
This is a confusing report. If you are successfully connecting two other computers to the router using the original router password, why can't you connect your MacBook Pro to the router using the same password? Or is it that the other two computers "know" the original password but you don't?
If one of the other two computers is a Mac, use the Keychain Access utility to look up the stored password for the router.
If not, use one of the other two computers to access the router's configuration screens directly and obtain the password that way.
Nov 15, 2009 | Apple MacBook Pro Laptop Computer with...
The keyboard of my macbook pro stopped working it
Once it turns on, use the mouse and either try updating keyboard drivers from device manager under the control panel, or last resort, try system restore
Aug 25, 2009 | Apple MacBook Pro Notebook
My new macbook white does not configure.
Can you connect hardwired?
If so, try selecting "Software Update" from under the Apple in the upper Left hand corner. There have been a number of updates that effect wireless connectivity.
Additionally try repairing permissions Application / Utilities / Disk Utility
Dec 16, 2008 | Apple MacBook Pro Laptop Computer with...
SIIG 2.4G Rf Wireless Presenter with Laser Pointer  Logo
Top SIIG Computers & Internet Experts
k24674
PC Tech101
Level 1 Expert
tony wahlman
tony wahlman
Are you a SIIG Computer and Internet Expert? Answer questions, earn points and help others
