Question about Invicta Spring Bar Removal Tool
I cannot remove the watch bracelet bcz the spring bar is stuck
The spring bar inside the steel bracelet has very little room to move. The spring bar will not budge because the length is so long that the force with which it is held in place is stronger than any force that can be applied to remove it. In other words, I cannot squeeze it because the outward force exerted by the spring inside is so strong. The remover tool simply cannot get a foothold -- it just keeps slipping.
I do not want to remove it by force, by yanking the bracelet off and breaking the spring bar.
SOURCE: tissot stainles steel bracelet
you should take it to a qualified jeweler
Posted on Oct 14, 2007
SOURCE: want to reduce length of omega watch bracelet take out the pins
how to take out a link in a seamaster profesional
Posted on Nov 18, 2008
matt2414
  • 247 Answers
SOURCE: Alfred Dunhill stainless steel watch bracelets
This might help:
http://www.info.com/stainless%20steel%20bracelets?cb=27&cmp=4089&gclid=CLmY5aWk1aACFWV75QodumH8uQ
Posted on Mar 26, 2010
gemineye61
  • 831 Answers
SOURCE: How do I adjust the
  • Select a clean, flat work surface where you can perform your watch band adjustment. Put down a piece of felt to protect the face of your Casio. Turn on a lamp near your workspace to better illuminate the watch components with which you will be working.
  • Lay your Casio face down on the protective felt. Look for the small arrows on the back of some of the watch links; these arrows indicate the removable watch links and the direction their pins should be removed.
  • Locate the pin hole above the arrow on the removable watch links. Insert the tip of a watch pin removal tool, or push pin, into the pin hole. Apply pressure to the link pin, in the direction indicated by the arrow, to free the pin and remove the link. A pair of needle-nose watch or jewelry pliers can be used to help pull out stubborn link pins. Remove as many links as necessary for your watch to fit perfectly.
  • Reserve the links and link pins that you remove from your Casio Edifice watch. Store the removed watch components in a small, clear, plastic zipper bag. These components can be used when repairing or expanding your Casio watch band.
  • WARNING:Casio recommends that customers have their watch bands sized by an authorized Casio watch dealer. Sizing the band of your Casio Edifice yourself may void the manufacturer's warranty on your watch. Contact Casio customer support for more warranty information.
  • Posted on Aug 21, 2010
    • 5 Answers
    SOURCE: the large sweep hand is stuck in the 12\r\noclock
    It should never move unless you initiate the timing with the upper right hand button.
    Posted on Sep 29, 2010
    Omega 196.0167 cal 1342
    The watch part number and a knowledgeable watch maker will provide the correct bracelet. If you WANT a leather strap most models can accept one - unless the case is sculpted to integrate seamlessly with the bracelet, in which case you may not be able to insert the spring bars that are necessary to mount the strap.
    Sep 09, 2012 | Omega Watches
    How do I remove links from a Seiko watch band?
    Follow these steps and it will help u resize your watch.
    1-Take a good look at the watch bracelet. Seiko watch bands are equipped with one of two different types of pins holding the links in place. One type is a simple, nail-shaped pushpin that's inserted into the joint between two links. The second is a flat, L-shaped piece of metal that slides into the center of a link and locks it into place. Both pins are removed using the same process. If the nail-shaped pushpin is present, you'll see the tiny screw heads in the joints. If the L-shaped pin is present, the links will be open-sided and you'll be able to see a strip of metal inserted in each links.
    2-
    Look for the arrows on the inside of the watch bracelet links. The arrows indicate the direction the pins and links need to be slid off of the band. Any attempt to go against the arrows could break or warp the links.
    3-Remove the spring bar from the clasp with the small pin-removal tool. Set the watch up on it's side so that the top of the spring bar is facing up and the bottom is flush against the table. Put moderate pressure on the top of the spring bar and tilt the watch just a bit sideways so that the spring bar can slide out. Ease out the bar slowly and carefully; the spring bar is spring-loaded and will shoot away from the watch if you're not careful (make sure that the bottom of the watch is pointed away from you at all times). Put the spring bar in a small dish so it doesn't get lost.
    4-Line up a small pin-removal tool with the top of the pin and push in the direction of the arrow until it slides out completely. Slide off the link. Place the pin and the link in the small dish. You'll want to save them in case the watch needs to be re-sized again at a later date. Continue removing links, alternating sides of the band to keep it even, until the watch reaches the desired size.
    5-Reconnect the watch. On the side opposite where the spring bar was removed, line up the link connected to the clasp and the second link on the band. Slide the pin in the opposite direction of the arrow, using a flat-headed pin inserter to push it into the joint. Use the pin-removal tool to give it a final push, listening for the click.
    6-
    Reinsert the spring bar slowly, using the pin inserter. Make sure the spring bar is lined up and tightly in place to avoid injury.
    Try this and it you cant manage it then you need to get it to a watch repair shop specializing in that brand.
    Jan 09, 2011 | Watches
    I want to shorten my watch band on my new Casio MTG900DA-8WC It has a metal band
    In order to remove the links of your Mtg930 watch you will need a couple of tools . It is recommended to have a watch pin pusher and a spring bar remover tool in order to do so. If you do not you can use a small precision flat head screw driver , the size that is usually used to fix glasses or smaller.
    First you need to lay a cloth down at a table . Lay the watch on top of cloth to prevent scratching . flip the watch upside down and have a good at the back of the watch bracelet.
    If you look carefully you are going to see notches on the back of each link with an arrow pointing in. This is where the spring bars are accessible and can be pushed in to remove the link.
    You need to place your spring bar remover, pin pusher or precision screw drive in the notch against the edge.
    Mean while push the opposite side of the watch link up so you can see the most of the spring bar inside the notch.
    The spring bar is going to look like a pink with a notch on the the top then gets smaller. As shown below on the left side of the picture. If you are looking at the notch on the spring bar, that is where you need to get our tool ontop of . So you can push down the spring bar.
    Once you push down on that notch on the spring bar the link will be able to slip out . Without a spring bar remover it will be more difficult and you will need to be patient as you try to work your flat head screw driver into the notch and be able to push down . Once the pin is push down you need to pull the link from the rest of the bracelet.
    Do not be surprised to take anywhere from 5 to 30 minutes if you have no experience and not have a spring bar remover.
    Once you removed all the links you desire , You will need to put the spring bars back into the links and close the watch bracelet up.
    The easiest way is to slip spring bar into middle of link. Bring the other end of the bracelet over so it the bottom covers the other link with the spring bar head out. Push the spring bar down with your tool as you slide the links back together.
    Oct 17, 2010 | Casio G-Shock Atomic MTG930DA 8VCR watch
    Where are the model number and serial number on a rolex
    Thank you for contacting FixYa.
  • Look at the side of your watchcase. On the watchcase lugs, located where the watch bracelet is attached, you may see one small hole on each lug where the spring bar is located. This means your Rolex has the traditional pierced lug style. If your Rolex does not have the pierced lug style, turn the watch over, and look for the long spring bar in the space where the bracelet meets the watchcase. The spring bar attaches the bracelet to the watchcase. The directions for removing the spring bar on both watch styles is slightly different.
  • 2
    Use your thumb to press down on the link where the band meets the watchcase if your Rolex has the pierced lug style.. If your Rolex does not have pierced lugs, turn the Rolex over, and press down on the link where the band meets the case. Either way, you are applying gentle pressure to the same link, just different sides of it. Remember, you are only removing the side of the band at the bottom of the watch, so press on the link below the 6. Maintain gentle pressure on the link while performing the next step.
  • 3
    Insert the tip of your spring bar tool into the lug holes, and push the spring bar inward. When done correctly, you will feel the spring bar fall into the case, rather than pop back out. Repeat this step on the other side of the spring bar.
    For a nonpierced lug watch, place the tip of your spring bar tool on one edge of the spring bar, and push inward, until the spring bar falls into the case. Repeat this step on the other side of the spring bar.
  • 4
    Pull the band gently away from the watchcase. It should remove easily. You can now see the serial number on the watchcase.
  • The reference or model number of a Rolex is located between the lugs at the 12' position. It is also listed on the certificates Rolex issues.
    Hope this helps. Jewel
    Oct 07, 2010 | Rolex Oyster Perpetual Submariner Date...
    Unclear as to how you adjust the rubber band strap
    1. Remove the deployant clasp from the watchband. The clasp is attached using spring bars on each end of the clasp. The method of spring bar removal varies but is usually performed by pushing a small pointed tool (one end of a spring bar tool) into a hole at the end of the clasp. While depressing the spring rod, pull the buckle away from the bracelet to detach. Repeat this for both sides of the buckle.
    2. Step 2 Measure the watchband to determine proper sizing. Use the scissors to cut along the inner grooves to remove needed sections (each section of the rubber will contain a new set of holes for the bracelet spring bars). Cut carefully and conservatively, as this step cannot be undone.
    3. Step 3 Reattach the buckle to the band after resizing. Reverse Step 1, pushing the spring bar in while sliding the buckle back into place.
    jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
    Aug 16, 2010 | Tissot T Race Case Stainlesssteel carbon...
    How do I remove pins to size an Invicta Sea Spider model #0140
    mcdevito75 here, Aren"t the spring bars (pins) built into Invictas Strap?? Look on the back of the Strap real close to where ot attches to the watch, see a little tab you can move with your fimger, this tab should compress the spring bar (pin) and allow you to remove the strap.
    Jul 03, 2010 | Invicta Sea Spider Chronograph...
    Main spring repair
    A professional watchmaker can replace the mainspring and clean and lubricate your watch for you.
    Hope this helps,
    Ken
    Yellowstone Watch, Inc.
    www.yellowstonewatch.com
    May 20, 2010 | ORIS TT1 Diver Date Steel 44mm Bracelet...
    How to remove a Rolex jubilee bracelet
    if its a real rolex, take it to a store dont play around with perfection. but the way a rolex bracelet is held on is by spring bars. look at the back of the watch and put a small screw driver in the lots and push down on the spring bar. then start to ease the bracelet out, now dow the same on the other side the end should come out
    Oct 06, 2009 | Rolex Datejust SS
    Need extra bracelet lings for a Tag Heuer Indy 500
    Hi.  I just received the Tag Heuer Indy 500 with steel bracelet today for christmas from my wife.  I'm a smaller man and had to take out 3 links.  I'd never sell this watch so if you would like them...just write. croscow@comcast.net
    Charles Roscow Silver Spring, MD
    May 02, 2008 | Tag Heuer F1 Indy 500 CAC111B.BA0850
    Invicta Spring Bar Removal Tool Logo
    322 people viewed this question
    Top Invicta Watches Experts
    Ansel Alberto
    Ansel Alberto
    Jimmy Accardi
    Are you an Invicta Watch Expert? Answer questions, earn points and help others
