Question about Dell W4201C 42 in. Plasma HDTV
Where to connect cable for Dell W4201C when cable becomes digital
There are 2 coax inputs to the W4201C. One is for analog (NTSC) and the other is for digital antenna (ATSC). My local cable will go to digital signal in the near future and turn off analog signal. Currently the cable company is combining both digital and analog signal. If I connect the cable to the ATSC input, I can on get channels 1-13 and the input menu defaults to "antenna". If I connect the cable to NTSC, I get the analog channels. How should I connect to get all of the channels?
    President:
  • 3,085 Answers
NTSC
Posted on Jun 13, 2009
How do I hook up Coby 5" black & white TV to my digital converter box ?
You will need a digital to analog converter which you can get at Radio Shack, Best Buy and most big box retail outlets or online. Your Coby is most likely analog and will require the digital signal to be converted to an analog signal from the digital converter box to the TV. UNLESS the digital converter box has analog (round connectors on the back) then you just need an analog RCA cable (which you can also get almost anywhere even your local CVS/Walgreens) to make the connection.
Nov 24, 2014 | Coby Televison & Video
How to set up vhs taping
Most VCRs need to be connected in a daisy chain or a splitter from your input source. (You may need a tuner with some VCRs these days; either a digital to analog converter for a VCR with an NTSC tuner or a different tuner source.)
If you have analog cable or a cable box with coax out and a VCR with an NTSC tuner, use the daisy chain method. Connect the incoming cable or the coax out from the cable box to the VCR's coax input. Then connect the VCR coax out to the TVs coax input.
For a VCR without a tuner, you'll probably find a RCA composite video line in option on the VCR. Connect your cable box or converter box composite output to the VCR composite in. For an OTA source, you'll need a splitter to send the signal to both the TV and the converter box.
Most TVs do not have a video output option.
I hope this helps.
Mar 08, 2012 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Having trouble hooking up vcr
I've never seen a VCR use anything other than Composite, S-video or RF analog outputs. That's because VHS uses the NTSC or PAL analog video standards. (In the US, it is NTSC; in Europe PAL is the old standard.)
To use the Composite output, get a triple RCA cable (red, white and yellow connectors). Connect one end of the cable to Video Out (yellow), Audio Out right (red) and Audio Out (white) on the VCR. The other end of the cable goes to the corresponding Composite Video In jack and the adjacent Audio In jacks on the TV. If you are using S-video, (both units must have S-video jacks), the S-video cable replaces the Composite section of the triple cable, so you only need an audio patch cable (two RCA plugs on each end). Be sure to use the audio input corresponding to the S-video input. Note: S-video is generally better quality than composite, although HD digital is still superior.
If you wish to record from the TV, the TV must have a composite video or S-video output. This is not very common. If you wish to record programs from an RF source (cable or antenna), see the next paragraph.
In the days before digital, a typical connection scheme was to run the cable or antenna RF source to the ANT IN coax connector on the VCR, then run a short coax cable from ANT OUT to ANT IN on the back of the TV. This may not work with a digital source. Pre-HD VCR tuners would not be HD compatible, and may even filter out the digital signal in bypass mode (VCR off). You would need an HD to analog converter box at the VCR input to retain this setup. I have no information on your TV's support for NTSC video through the tuner (especially since you did not mention the model : /).
Jun 21, 2011 | LG Televison & Video
I have lost the manual and would like to hook up the VCR to my TV in order to record programs. Can you help? JVC Video Cassette Recorder HR-D18OU Thank you.
Is the incoming signal OTA or cable? (If cable, is it analog (CATV) or digital (QAM)?)
Most TV's do not have a video out but you should check your TV. Assuming the usual TV with no video out, then you will need a set top box to record any program other than analog signals (CATV or a low power OTA option). The VCR only has an NTSC (analog) tuner.
For an OTA signal, take the coax from the antenna to a digital-to-analog converter coax in, then coax out of the converter to the coax in (tuner) of the VCR. Then set the VCR to channel 3 or 4. Set the switch on the converter. (Some VCRs will record Line In or Input, so you could use the composite out of the converter to the VCR.) Then coax out from the VCR to the coax in on the TV and set the TV to Channel 3 or 4 as well. Set the switch on the VCR. (Alternatively use the composite (A/V) out on the VCR to the composite In on the TV and set the input to AV1 (or whatever the TV calls the input). Digital cable will be set up like the OTA, except for using a cable set top box instead. You may want a splitter to allow for watching one program while recording another. In that case, put the splitter before the set top box if the TV has the digital tuner. Otherwise put it after the set top box. In both cases, you will need to use the AV (composite out) on the VCR to the TV.
For analog cable, take the coax cable and connect it to the VCR's coax in. Then connect the coax out or AV out to TV.
Set the VCR to the desired station and press REC. For timed record, enter the menu and set the time to start and end the recording as well as the channel. If you are using a set top box, set that to the desired station and then press record. (Leave the VCR set to Line in or channel 3 (4) as needed.)
Manuals for some JVC vcrs are here: http://support.jvc.com/consumer/product.jsp?categoryId=CATG0002&productId=PRD4600001&archive=true . A manual for a similar model will help since they all connect the same way. However the HR-D18OU is not in the list.
I hope this helps.
Feb 10, 2011 | Computers & Internet
I need to connect my vcr/dvd combo unit to an Emerson HD TV so that I can record shows. Can you help me?
Most TVs only have audio out and several audio/video in connections. Unless you have an unusual tv, there is no option for a coax connection from the TV to a recorder.
Since this DVD recorder only has an analog tuner, you need to connect it to a set top box to record signals unless you are looking only at analog channel sources. If you are getting OTA, then a OTA digital-to-analog tuner is needed for most channels. (Only low power stations are still broadcasting in analog.) The cheaper ones that were available with the government coupon were SD tuners. HD content will need a separate tuner. If you have cable or satellite, check the signal (QAM is digital cable).
Next connect the coax from your analog source to the DVD recorder coax in and another coax cable to the coax out and the TVs coax in (if you want to - the pass through doesn't work with a set-top box for non-analog signals). Set the channel to the appropriate one (3 or 4 for the OTA d-t-a boxes; desired channel to watch for analog OTA or cable). Set the TV to channel 2, 3 or 4. Alternatively, use composite A/V cables from the set top box to the A/V Input of the DVD recorder and set the recording channel to Input 1.
Next connect A/V cables (composite or S-video) to the recorder's matching out to the TV A/V or S-video In. Set the TV to A/V 1 or Video 1 depending on the Emerson TV. You can watch tapes or DVDs. For better video quality on DVD playback, also connect component video cables from the DVD recorder Out to the TV's component in (if it is available). Then set the TV to the appropriate component video input when watching DVDs.
I hope this helps.
Dec 05, 2010 | RCA DRC8300N DVD Recorder/VCR
Im trying to connect my unit to my tv to record shows and i having trouble doing so please help i am hooking it up wrong
For OTA or CATV signals, you need to daisy chain the coax from the source (antenna for OTA) to the coax input on DVD recorder and then the coax out to the coax input of the TV. If you have a set-top cable box with an incoming CATV signal, it should be connected between the DVD recorder and the TV.
The unit can tune in and record 480i (SD) ATSC (OTA digital), NTSC (OTA analog), analog CATV and digital CATV channels.
A satellite receiver or a non-CATV cable box should get the incoming signal first and then have their composite video output (A/V) connected to the DVD recorder composite video input and then their coax (RF) output (if present) gets connected to the TV. For these, you would record from the IN1 or IN2 (press Select Input) instead of selecting a channel. Then connect the composite video out on the recorder to the TV's composite video in.
Digital signals are either enough to tune in or give no signal. So check that your antenna is correctly oriented for OTA.
Separately, you can connect the video signal when playing DVDs via composite (good signal) out and component out (better signal) out to the TV's matching input. For the component video, the sound is carried on a separate cable. Then set the TV to the input source.
In the case of wanting to watch a VHS tape while taping to a DVD, do not use the Component video source, set the TV to Input 1 (composite).
I hope this helps.
(you can get a copy of the manual here: http://tv.manualsonline.com/manuals/mfg/panasonic/dmrez47v_dmrez475v.html )
Nov 25, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
I have a 2 tuner tv. When Cablevision installed my digital cable box, I lost the 2 tuner capability. Is there a special way it needs to be hooked up to get back the 2 tuner capability?
Your cable system is probably QAM (digital cable). The tuners built into the TV are analog and digital OTA tuners (ATSC and NTSC). If you connect the Cablevision box to the component video input (and connect the audio out of the box to the appropriate audio in) on the TV and an appropriate antenna to the coax (antenna) input, you will be able to swap use the tuners in the TV. (See tvfool.com for antenna types and direction or antennaweb.org for directions of the most likely stations to be received at your location. antennaweb assumes an external antenna and is conservative in the list it provides.)
I hope this helps.
(please note, you probably need to get the component video cables. These have 3 RCA plugs on each end (red, green and blue). To carry the audio you need a cable with 2 RCA plugs on each end (red and white). Match the colors as you connect them.)
Nov 05, 2010 | Proview PA-32JK1A 32 in. LCD Television
I have an analog tv (coax cable) and a new dvd (av plugs) player. How do I inexpensively connect them? i saw the solution posted about the rf modulator. I have a digital to analog tv convertor. Is this...
NO. An RF modulator and your digital-to-analog (DAC) TV converter are 2 different devices. The DAC will convert over-the-air (OTA) digital television signals from your antenna to analog NTSC format so your older analog TV can receive OTA broadcasts. The RF modulator converts base-band video (composite cable/RCA connector, or S-Video cable connector) to channel 3 or 4, so you can watch video/audio on your set. To use both the RF mod. and the DAC converter to the same TV, use an A/B switch for F-connector coax, or follow the directions for the RF modulator to make the correct connections.
Jun 12, 2010 | Televison & Video
Converter box
1) Connect the coax cable from the antenna to the converter box input.
2) Connect the coax cable output of converter box to the input of the VCR.
This is the only way it will work but you will have many limitations such as using the programming features of your VCR.
The boxes are fine if you want to play prerecorded DVDs or tapes. If you want to record tapes you have to leave the box on and have it set to the station you want to record.
May 27, 2008 | Insignia Digital-to-Analog Converter for...
Vsx-d511 digital coax input
in dvd menu cheak output audio settings whats it on pcm or bitrate 5.1 ? how sthe cable cond does it work on other coxal units
Jan 07, 2008 | Pioneer VSX-D511 Receiver
Dell W4201C 42 in. Plasma HDTV Logo
152 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
