Perform a Hard Reset
Do these actions first to clear all temporary setting before troubleshooting the problem.
Disconnect
all peripheral devices and remove all USB devices and media cards.
Disconnect
the AC power adapter,
remove
the battery, and then
press and hold
the power button for at least 15 seconds to drain residual charge.
Reconnect
the AC power adapter (do not connect the battery),
press
the Power button and
look
for the LEDs to blink or glow, and
listen
for the sound of a disk drive and fan turning.
Perform each recommended corrective action and then attempt to restart the computer.Symptom 1: LED lights do not glow, display is black, no fan or drive sounds are heard, and computer does not startIf
LEDs do not glow or blink when AC power adapter is attached and power
button is pressed, there is no power available to the notebook Check AC adapter wiring and power connection to the notebook Connect a different AC power adapter and remove battery, then restart notebook.Connect a different battery and disconnect AC power adapter, then restart notebook
Symptom 2: LEDs blink or computer beeps but does not start Blinking LEDs or beep tones indicate a hardware failure during the pre-start up testing Count number of blinking LEDs or beeping tones to help with diagnostics testing
Symptom 3: LEDs glow, fan noise may be heard briefly, display remains black, and computer fails to startup or boot Usually occurs if a component is installed incorrectly, or there is a device conflict or failure Connect an external monitor to check if the problem is the built-in LCD display or graphics card Remove all CD/DVDs, SD cards, USB devices, peripherals and do a
Hard Reset If memory or hard drive components were replaced, reinstall original component Remove memory modules and replace one-at-a-time Remove and reseat hard drive If possible, turn on power, press
F10
to enter
BIOS
mode, and run
Memory Test
and
Hard Drive Test On newer notebooks, turn on power, press
Esc
to enter
UEFI
mode, and run
Memory Test
and
Hard Drive Test If possible, turn on power, press
F8
to enter
Windows Advanced Boot Options
, and select
Repair Computer
option, or enter
Safe Mode
and run
Memory Diagnostics If all other methods fail
, but computer can boot to BIOS, use recovery disk to recover the computer to original condition
Symptom 4: Computer may display an error message on a black screen during startup or boot Search
www.microsoft.com
for terms in error message Search
www.hp.com
If possible, turn on power, press F10
to enter BIOS
mode, do the corrective actions listed under Symptom 3
to run memory and hard drive tests.Symptom 5: Computer displays a blue screen or continually re-starts
After an error message is displayed, you can usually bypass the error and continue to run the notebook in
Safe mode
to install an updated BIOS or driver.
Search
www.microsoft.com
for terms in error message.
Search
www.hp.com
to enter BIOS
mode, and run diagnostic Memory test
and Hard Drive test
If possible, turn on power, press F8
to enter Windows Advanced Boot Options
, and do one or more of the following:
Select Disable automatic restart on system failure
to view error message.
Run Repair Your Computer
Run Last Known Good Configuration
Select Boot into Safe Mode
and then select Run a Microsoft system restore
and then select Uninstall recently installed programs
and then run Windows Update
Symptom 6: Computer displays the Windows logo screen and stops responding
If no error message displays, turn on power, press
F8
to enter
Windows Advanced boot options
,and select
Disable auto-restart
Search
www.microsoft.com
Search
www.hp.com
to enter BIOS
mode, and select Restore the BIOS defaults (F9)
to enter BIOS
mode, and run Hard Drive Test
, and select Last Known Good Configuration (Advanced)
, and select Boot into Safe Mode
and then Uninstall recently installed programs
Update Computer After Resolving A Problem
When the computer starts into Windows normally, you should install the
latest updates and patches to prevent other start-up problems.
The maodel number is:AVXF 120 FR and not as previously mentioned, sorry if this has caused confusion. The initial problem was an F10 ERROR which after some research on the net informed me that the water pressure sensor switch had a problem, this was checked and found to be working correctly. On reconnecting the machine with electricity, it entered into a mode called 'TEST', this ran for some minutes and I assume came to a finish with end visible and flashing in the display. Attempted to try and run programme 5 which I was able to set into the display, however, when the '!' button is pressed to run the programme, the sreen displays 'END' flashing, each attempt to run this or any other programme results are the same. Switching off the electrics and removing the plug from the wall and then reconnecting results in 'TEST' mode. I am stuck in this perpetual cycle, hope this explains the situation more clearly. Any ideas, solutions would be greatly appreciated.
