Question about Whirlpool Duet GHW9150P Front Load Washer
Will not spin out
Hi my duet washer attempts to start the spin cycle.  the tub spins once or twice, the lights flash across the front, and shuts down. please offer advice
    Scholar:
  • 146 Answers
Is the machine draining the water out? The machine will not spin unless the water is pumped out.
Posted on Nov 06, 2007
What do i do when the washer starts to fill up and shuts off on me completely?
Drian water out place blocks under all four corners laying down w/flash lite inspect belts under washer.with it off try to spin tub. Trun nob to spin and c if tub turns
Jun 17, 2014 | Whirlpool Duet GHW9150P Front Load Washer
The tub is very wobbly and the machine was loud and moved across the floor when the spin cycle was on
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Apr 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Noisy on spin cycle "rattling"
heatman101
Mar 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet steam washer knocking noise when in spin cycle.
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
heatman101
Feb 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9400 PT4 on any of the cycles, runs 1/4 of the way through the was cycle and stops and starts flashing F 06, pushed cancel once then started the cycle again this worked for awhile. Then...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Remove, reseat and reconnect every connector at least 3 times. Remove the motor control board, spray it down with electronic cleaner along with all connections by disconnecting them, spraying them down. Disconnect and connect a few times to ensure good contact.. It appears that spraying the board and connectors work.
Pl give me a ‘very helpful’ rating for the free help, thanks.
Jun 16, 2009 | Whirlpool GHW9400 Duet Washer
We get an F2 error and the machine shuts off.
to long to drain,,,press pause/cancel twice..that should it ...happy new year
Jan 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have WP Duet HT front laod washer. Model #-GHW9250ML1 Type 199 080 SC/WG Problems - 1. while the tub is spinning it makes a knocking sound. When the tub slows it knocks louder. What is the problem and...
COULD BE LOOSE BASKET OR REAR BEARING LEAKING OR SIMPLY SUSPENSION SHOCKS BROKEN ,, EVEN SHOWS 1 MINUTE JUST ESTIMATE TIME NOT READY TO SHUT DOWN NORMAL ON DUET MACHINES
Nov 29, 2008 | Washing Machines
Flashing time lights...pressed cxl button...not working
Flashed f ...time light flash...pump starts to work...doesn't spin...doesn't cycle...
Oct 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
247 people viewed this question
Dan Webster
Dan Webster
Sal De
