Question about Hobart Dishwashers
Looking for a hobart amx dishwasher wiring diagram from 3 phase converting to single phase
Sr. we are using Hobart dish /w but not working this properly .when i start d/w display red light coming but not green light also heater working water coming can you help me
Posted on Jan 15, 2012
3 Suggested Answers
handygirl911
  • 65 Answers
SOURCE: Need to convert 3 phase Hobart dishwasher to single phase
It will not be inexpensive to convert your dishmachine over to three phase. With everything that you will need to replace, depending on the model if converyor or not it may run close to what it costs to have 3phase run to the building that you plan to move into.
Posted on Jun 09, 2009
  • 760 Answers
SOURCE: can I change the 3 phase to a single phase?
Not practical. You would have to change the pump motor to single phase, you'd have to chage the heating element most likely depending on what size is in it now. Also does it require an auxiliary water heater? it's probably 3 phase also. Changing phases is not like changing voltages.
Posted on Jul 24, 2010
What is hobart h600, single phase or 3 phase?
Not sure if you are asking if an H600 is automatically a single phase or a 3 phase and the answer is NO. Depending on the motor it will be 1 phase or 3 phase application. It will have 4 wires versus 3 wires -- hope that makes sense 3 of the wires are "HOT" on a 3 phase and only 2 are "HOT" on a single phase Motor.
Jul 09, 2014 | Hobart H600 Stand Mixer
Bof fault code
The display of "BoF" on the display is simply a confirmation code to commence the next operation on the dishwasher. It is not a fault code.
Refer manual of a AMX model Hobart dishwasher. If your model is different the general codes are same.
http://www.dishwashers-direct.com/uploads/Operating%20instructions/Hobart/AMX%20RANGE%20OP%20MANUAL.pdf
Apr 19, 2014 | Hobart Dishwashers
Electric Phases for Hobart Oven
you must understand this : your electric oven must be indicate if it is a single phase( use 3 wires for 230 2 hot wires + 1 Neutral see the diagram like dryer? you must sure about this. Normally any appliance for home are single phase NOT 3 phase.
2) If you electric oven, say 3 PHASES( use 4 WIRES, 3 hot wires+1 Neutral wires) this for industrial application +comercial 270266c5-a0ad-44dc-9f40-e963255d47f5.jpgNOT for home
However if you system is 3 phase you must need to install 3phase transformer.ba1c9d4d-85e3-4744-8ce5-2f25c6e34ad3.jpg
Jul 18, 2013 | Hobart HEC501-240V Electric Oven
Hobart am-12 manual and wiring
need to know if the motor on a hobart dishwasher model # am12 can be changed from 3 phase to single phase ? If so how ? I have no diagram on unit .
Jul 09, 2012 | Food Mixers
Taking my P660 out out a building with 3 phase power and into one with only single phase. Converter says motor will run on 2/3 power. Good or bad idea????
Good!
MOTOR:
21?2 H.P., Hobart designed, high torque ball bearing,
ventilated within mixer enclosure. Single-phase is
capacitor-start, induction-run type.
Three-phase is
polyphase squirrel cage, induction-run type.
Single Phase 208V 20.0 Amps
240V 17.0 Amps
Three Phase 208-240V 8.6 Amps
Nov 26, 2010 | Hobart P660 Stand Mixer
I need a wiring diagram for the Hobart H600 which has a multi tap motor on and i would like to change the voltage on the motor to 200volt single phase 120/208 or even 120208 3phase. The wiring diagram is...
You cannot wire a three phase motor for single phase and you cannot wire a single phase motor for three phase. If you have a three phase dual voltage motor your options are 220 or 440 volts. If you have a single phase dual voltage motor your options are 120 or 240 volts. A 208 volt Hobart motor will only function correctly on 208 volts and is not dual voltage.
Aug 05, 2010 | Hobart H600 Stand Mixer
Can I change the 3 phase to a single phase?
Jul 24, 2010 | Hobart AM14C-155 Dishwasher
Jun 08, 2009 | Dishwashers
Incorrect wiring on a heater element for a hobart am14
Is this single or 3 phase? What happened?I'm a hobart tech.
Jan 24, 2009 | Hobart 29 in. AM15-1 Free-Standing...
Dishwashers Logo
546 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
