Question about Garmin Nuvi 660 GPS Receiver
Garmin GPS short battery life
I have the same batter problem as described by
pawnpower . I can't believe the batter life of a Garmin GPS is only 15 months?! Is that true? That seems awfully short for an expensive tech gadget.
I'm not clever enough to replace the lithium battery myself. Are there alternatives other than buying a new GPS?
SOURCE: Garmin StreetPilot C330 GPS Battery
I had this problem recenly and it had to do with the cigarette power connector. It wasn't working. When I pluggged the Garmin into my laptop with the special connector to upgrade software, etc. It charged the battery. In my case the fuse and the metal end of the cigarette plug fell out. I imagine the fuse might also blow out. If you can power up the GPS using the USB connector, check the cigarette power connection. Is the metal end still on it? If you unscrew the end and pull out the fuse, it the fuse OK? Replacement connectors can be found on the internet.
Posted on Aug 21, 2008
ginko
  • 19396 Answers
SOURCE: replace battery garmin 255
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Posted on Apr 10, 2009
landsend
  • 1066 Answers
SOURCE: I need a new memory battery in my Garmin gps 75
try planetbattery.com
Posted on Apr 29, 2009
SOURCE: remove and replace the lithium coin batt from a Garmin gpsmap185
The battery is a Panasonic BR2032-1F2; the suffix desinates that it has two flat tabs for soldering into the unit horizontally. Once you remove tha back of the unit, you'll see the battery next to a resistor that's siliconed in place. You'll need to knife the silicone loose so you can gently move the resistor aside to reach the soldered tab underneath it. Just heat the solder on each tab with a small soldering iron until it melts and the tab pops loose.
Install the new battery with the unmarked side up (the other side has type) and solder in place. Reinstall the power and antenna connections in the cover, replace the cover, power up the unit and start re-creating all your lost waypoints.
Batteries can be ordered online from Allied Electronics at $2.42ea (www.alliedelec.com)
blackcatjim
Posted on Jul 20, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Short Battery Life in Garmin Edge 305 Cadence
Hello there:
you might want to remove the battery and inspect the connection pins if one of them are bent or loose they will cause this also a loose connection internally will cause this. if this is a warranteed item you might consider using it ok?
best regards michael
Posted on Sep 18, 2009
How do the 4 batterys install
Remove the battery cover by turning the thumb loop at the bottom of the GPS 1/4 turn counter clock wise. Insert the batteries and replace the batter cover.
For more info view the manual, page 1: http://www8.garmin.com/manuals/GPS12CX_OwnersManual.pdf
You will need Adobe Reader to view the file: http://get.adobe.com/reader/
Feb 03, 2011 | Garmin 12CX GPS Receiver
NO life in my Forerunner 305
Try first changing the battery if you have but if not better call Garmin and let them repair or replace it if its still under warranty..
Hope that helps..........
Aug 04, 2008 | Garmin Forerunner 305 GPS Receiver
I have a 200 nuvi gps, it always takes me the long way to my destinaotion, how do I update it?
If you are willing to spend $89.00 you can purchase a lifetime maps update/upgrade through the Garmin website. All you have to do is log into their website - www.garmin.com - connect your Garmin to your computer with the USB cable and purchase the upgrade. You might want to consider purchasing a new Garmin that comes with lifetime maps as your 200 is an older unit and its life may be short. A new unit, like a 1300LM, runs $139.99 at Best B**, as of 01/30/11, will come with a new fresh battery and the newest maps pre-loaded and it will allow you to update those maps FREE for the life of the unit. These ideas might help you wayward travels. GOOD LUCK
Jan 17, 2011 | Garmin nuvi 200W GPS Receiver
IS THERE A PROBLEM WITH THE BATTERY
Battery life according to Garmin is about four hours with the rechargeable Lithium battery. During the use, it last anywhere from three hours and fifteen minutes to three and half hours.It does happened that sometimes the batter die and won't let the GPS to function properly.
Sep 05, 2010 | Garmin nuvi 255W GPS Receiver
I have a Garmin i5. I have used it for years but on a recent trip it just stopped working. By this, I mean it won't turn on. I tried switching batteries several times, and the reset described by holding...
try plugging it in to the usb port on your computer, then if it starts, install the batteries.
if you did not get a usb cord with your gps, pretty much any usb to mini usb cord will work.
bill
Oct 12, 2009 | Garmin StreetPilot i5 GPS Receiver
Hello there:
Sep 18, 2009 | Garmin Edge 305 GPS Receiver
Battery life
yes take your garmin to any radioshack store as they have devices that allow you to add an exterior battery source
Apr 16, 2009 | Garmin iQue 3600 GPS Receiver
Screen shuts off within 10 seconds after turnon, if power not connected to car
replaced battery. works fine now. holds charge for some six hours or more.
Oct 07, 2008 | Garmin Nuvi 660 GPS Receiver
First time use / battery charge
The Nuvi units are short on battery life and therefore Garmin has given you a connector other then USB to power your unit while in a car. You need to carry that. It's just a design flaw. If you try to rely on the battery of your Garmin Nuvi, you have less than 2 hours even on a full charge. And carrying the USB adapter which plugs into the cigarette lighter socket won't allow your unit to run while charging. so you need to take the adapter charger bracket that comes with the unit if you need it for longer trips.
Jul 10, 2008 | Garmin nuvi 200W GPS Receiver
Street pilot
There is a reset button on the unit
Aug 14, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
410 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
