Question about Panasonic DMR-E55 DVD Recorder
Recording starts to record then stops getting message u99 on display case
Mine too. i found a firmware update that seems to have helped (i tried recording about 10x after this update and it's ok so far).
http://www2.panasonic.com/consumer-electronics/support/Drivers-and-Downloads/list-DVD+Recorders
Posted on Nov 04, 2007
Panasonic dmr ez28 fails to record
Thanks Dan, I found a local guy who was wiling to try. He repaired it and I am very satisfied. I don't know why Panasonic and others do not sell dvd recorders with tuners. They could make a bundle.
Jun 08, 2018 | Panasonic Televison & Video
How do I fix my Panasonic DVD Recorder DMR-XW380
U99 Hi. This indicates a communication error between the timer and main processor unit. Try unplugging from the wall for a minute or two, and plugging it in again, to reset everything.
Sep 12, 2014 | Televison & Video
DVD Recorder MODEL no.DMR-EZ27EB has U99 on screen unable to operate it
Hi.
U99 is a general communication failure between processor and timer, and there may be different causes. Common cause is a defective disk. Removing disk from the drive sometimes may fix the problem.
The first reset that you can attempt is disconnecting power for two minutes.
I quote below a post that was originally published in the MyCe forum (here):
"According to the service manual the U99 error is specifically a "hang up" displayed when there is a communication error that has occured between the main microprocessor and the timer microprocessor.
With more than twenty Panasonics (including four DMR-ES15 models) I'll offer my own observations:
There can be any number of causes for the U99 error, including a culmination of reading, writing, finalizing errors--sometimes appearing after U61 or U88 reading errors. The U99 error might also be associated with unusual DVD Drive noises, "grinding" indicating a dirty rubber hub and spindle; "clunking," "chugging" or "errrp" noises indicating a dirty lens or a failed laser assembly (the "optical pick-up").
Initial remedial measures include the routine DVD Drive lens, rubber hub and spindle area cleaning described in other CDFreaks/MyCE and AVS Forum threads. If that does not correct the problem(s) laser assembly or DVD Drive swapping with a direct replacement may be indicated. Also check for a disturbance to a ribbon cable or ribbon cable contact, correct or repair as necessary.
If the Digital PCB has become problematic, model-specific replacement is indicated. If the DVD Drive on-board contoller (if so equipped) has become problematic, model-specific replacement is indicated. In most cases "model-specific" means the same model year DVD Drive and, with problematic Digital PCBs or DVD Drive controller boards, replacements should be from the same model year and the same or very similar model recorder. Laser assemblies should only be replaced with the same model, i.e., 3331A and 3332A "optical pick-ups" might not interchange satisfactorily.
The U99 error may also be displayed when inferior media is in use. (Beginning in 2008 I've used nothing but Taiyo Yuden 8x Premium Line DVD-R media in my Panasonic, Philips and Magnavox DVD Recorders and HDD/DVD Recorders.)
The U99 error may also be displayed when there is an operating system "time out" occasioned when the user attempts to move too quickly between digital and analog channels (in 2007 and newer EZ series models)."
Apr 26, 2011 | Music
Display reads slf check and u99 whichIthink is a fault code.The unit is apanasonic DMR-ES30VEB dvd recorder/vhs.Any ideas?
Hi
U99 is a fault code, from memory i believe it is a communication error between the dvd drive and its controller, either way the machine needs to be serviced.
regards
TechSupp12
Dec 12, 2010 | Panasonic DMRES30V DVD Recorder/VCR Combo
I am getting a U99 error code. The only function
The "U99" error code signifies a "general communications failure."
It is not associated with one specific problem.
It can be related to the version of firmware your DVD recorder is currently using and it has been associated with the TV Guide on screen guide.
If your unit displays U99, turn the power off-unplug the
unit for 5 minutes, and reconnect the power.
If U99 reoccurs, please contact the Global Service Center Network for assistance.
Feb 26, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
U99
A U99 error code signifies a general communications failure and is not associated with any specific problem. It could even be related to the firmware version of your DVD recorder.
Try turning off the power and unplugging off-unplug for at least five minutes before reconnecting.
If U99 reoccurs, you should contact the Global Service Center Network for assistance.
Jan 27, 2009 | Panasonic DMR-ES10 DVD Recorder
Dvd would not work displays u99
Dvd recorder doesn't not work. Displays error code U99. Any suggestion please?
Jun 21, 2008 | Panasonic DMR-E85H DVD Recorder
Start up u99 message
Hi there, this is what Panasonic say.... The "U99" error code signifies a "general communications failure."
Feb 17, 2008 | Panasonic DMR-E20 DVD Recorder
U99
Feb 12, 2008 | Panasonic DMR-ES10 DVD Recorder
U99 code and tray won't open
Thats a reset code # its on page67 of your owners manual. Unplug the unit for a bit(5minutes) plug in turn on the power then turn off again then back on. If this dosent clear the code, contact panasonic at 800-211-PANA Good luck
May 09, 2006 | Panasonic DMR-ES30 DVD Recorder/VCR
Panasonic DMR-E55 DVD Recorder Logo
216 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
