Question about Philips Magnavox 42MF521D/37 Television
Where is the location of power board in a magnavox 37mf321d37 i need to replace a capacitor . the tv will only blink a green power light and the screen will flash but not come on
  • Philips Master
  • 1,216 Answers
After removing the back cover. Look to the left below. Remove the foil tape. That is the board is the one with the problem. Take the five [i believe] screws out and flip the board. You will see a black and gold capacitor with the top bulged and maybe some tar oozing out. It is a 25volt 2200mf cap that is bad. replace with newone, be sure it is rated at 105 degrees. Also, just maybe, the next cap is 35volt 1200mf 105 dgree should be replaced. Remember just maybe. But for certain the 25volt 2200mf 105degree is to be replaced. These are very easy to locate. How much is this repair......its priceless.
Posted on Jul 02, 2009
  • matt martin
    matt martin Jul 08, 2009
    Always be sure the polarity of the capacitors are installed correctly
  • 10,515 Answers
When you open rear cover, you would see power board.
If you want a picture :-
http://e-techsiliconvalley.com/store/images/DSC00536.jpg
The above one would show how the power board looks like.
Thanks.
Posted on Jun 04, 2009
Does the Blinking Light on the Asic Main logic board mean bad Logic Board?
Check all the capacitors one might be bad find out if it is bad it should bulge on top of the capacitors
Nov 04, 2017 | Magnavox Televison & Video
Magnavox 37" model 37mf231d-37 wont tun on when i hit power button the screen lights up for a secongd and turns right back to black and the power button green light comes on and right back off I found
Your power supply is weak. If you think you can repair this I will tell you how. If you cannot do this,find someone who works electronics and share this repair. Two capacitors are bad. When pulling the back cover off, you may see one or two capacitors bulged. Even if they look good....replace these capacitors. The locations are numbered and, the capacitor having a value and temperature of 105 degrees.. Location of the first capacitor is 2074, value 25volts @ 2200 mf @ 105 degrees and will most certainly be bulged. The next capacitor may look fine....replace it. That capacitor location is 2066, value is 35 volts @ 1200mf @ 105 degrees. When you replace these, please be sure to get the polarity (positive leg and negative leg) of these capacitors seated correctly...this is a must. This will correct your TV. You will save lots of money, because you asked. Thanks for listening ..good luck...we will be here for your next repair.
Jan 02, 2013 | Toymax Magnavox 37MF231D 37 in. LCD TV
Magnavox 37MF321D/37. suddenly just shut off and would not turn back on, no blinking green light nothing!
Price the board first and then decide, I fix these in our shop but do not like or enjoy working on them at all.
Dec 20, 2012 | Toymax Magnavox 37MF231D 37 in. LCD TV
Green power light keeps blinking
hi friend,
Repairing It Yourself
If you decide to repair the TV yourself, I recommend that you obtain a copy of the repair manual for your Mitsubishi TV from the Techlore website by going to Mitsubishi Service Manual. It will provide some direction, however it is technically written and may be difficult for the NOVICE to understand. If you are unable to locate the the service manual for your specific Model at the above Techlore link, you may need to purchase the service manual online at ServiceManuals.net.
If you decide to have a service technician do the repair, insist that the "DM" module is removed from the TV and ONLY the four 1000uF, 16V Capacitors (Caps) located on the DM Module are replaced. MOST techincians will INSIST on replacing the entire DM Module and not simply the capacitors. The cost is about $200 for a technician to replace the capacitors and $1000 for replacement of the DM Module. As you will read below, doing the repair yourself will cost less than $4.00 for the 4 Caps.
A Few "Cautions"
  1. Keep yourself "grounded" when working with the circuit board. Static electricity will destroy electronic components.
  2. When replacing the Capacitors, press them "down" onto the circuit board as far as they will go, hold them down, solder into place and clip the excess terminal lengths flush with solder. Only by doing this will the metal shield (little silver box) slide down and over the circuit board during re-assembly. There is not a lot of clearance when doing this, as the 105C Capacitors are slightly longer that the originals. With minimal effort everything does fit back together.
  3. Use ONLY 105º C capacitors with a voltage rating of 35 V.
  4. Re-insert the DM circuit board into the Mother board; press virmly and ensure a proper seat of the DM board. Next, slide the metal case down and over the DM circuit board. Refer to my "Lesson Learned."
Basic Troubleshooting
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
hope this helps u
please rate me.....................
thank u for using fixya
regards
sivaranjini
Nov 24, 2009 | Insignia IS-LCDTV32 32 in. Television
Green power light blinking all the time on TV
After changing a defective capacitor, my TV still would not power up. After using a solution I found on this site, I held the power and volume up button down on the TV itself for several seconds, the TV powered up normally. I did notice that you had to do this while the timer light was flashing. Doing so after it went out was not effective. I initially only replaced one capacitor which was noticeably defective, and the flashing green timer light eventually returned. I will be replacing all 7 capacitors and resetting the TV. As mentioned above, the capacitors may look good but in fact may be defective. These are high temp caps which breakdown under a load but function normally when cold. Several people have mentioned replacing the capacitors didn't fix the problem. It appears that you must replace and reset using this method to repair some of these TVs.
Jun 06, 2009 | Mitsubishi WS-65615 65" TV
Magnavox 32mf231d - Just a blinking green light, No Power
I had this problem, but saw other places that it was a cheesy capacitor on the power supply circuit board causing this. I opened it up and took the power supply board out and it was obvious which capacitor was bad...top was bulging and had black stuff on it. It was rated 2200 uF @ 25V...got a new one @ Radio Shack that was 2200 uF @ 35v. Soldered it in (I stink @ soldering, but gave it a shot and it was EZ). Watching the first weekend of college football w/o waiting on a flashing green light for up to an hour so the TV would start! I'm going to try to find the other websites that directed me to this to say THANK YOU...BTW my brother used to have fits with several Magnovox TV's and thier power supplies back in the old tube style TV days. I thought I didn't need to worry about this with an HD flatscreen, but was wrong. I will think twice before buying a Phillips/Magnavox/Funai/whatever else they are again. They have a long list of complaints and I believe a class action lawsuit to refer to about this problem. They should have stepped up and done something!
Mar 19, 2009 | Toymax Magnavox 37MF337B 37 in. LCD TV
Red blinking light on a Magnavox Plasma TV
Here is the solution. For less that 100$ your Magnavox Plasma TV. Model # 50MF2310/37 will be running like a champ.
Issue:
Magnavox Plasma TV. Model # 50MF2310/37 screen has no picture. There is no sound, TV comes on and then after a few seconds clicks and screen remains blank.
Cause:
On the main power circuit board to Capacitors are prone to failure from over load. The caps are 3300uf 10v 105+c capacitors located to the left of the AC power input.
Service:
Magnavox will refer you to a service center. They will advise $$$ for an inspection. They will also want to charge upwards of 500$ to replace the entire board.
Solution:
1. Unplug your TV
2. Disconnect all connections from your TV
3. With assistance lay your TV on its face on a non-scratching service
4. Remove the back panel screws.
5. Lift back panel off
6. The central board is your main power board.
7. Remove all wire harnesses from the main board.
8. Remove all screws that are holding the main board in place.
9. Lift the main board out and carefully place it into a non electromagnetic pouch.
10. Take the board to a Circuit Board repair shop.
11. Have them replace the the above mentioned Caps.
12. Re-install the board in your TV.
NOTE: Replace the caps with 3300uf 16v 105+ high temp caps(preferrably Japanese caps)
This fix cost me 80$ and my time to search for other who had the same issue. Try searching for Magnavox Plasma TV. Model # 50MF2310/37 bad circuit board or Magnavox Plasma TV bad capacitors or Magnavox Plasma TV bad ciruit board.
Hope this all help, Magnavox is should take ownership for this problem and recall any tv's that have these caps in them. The worst part about this is that teh **** from the repair center that was paid 100$ to check the TV, stripped out the screw holes and damaged the case for the TV.
Portland Laptop Repair was awesome. They repaired the board and it looked like new. Check them out at http://www.laptopportland.com/
Jeff G
Portland, OR
Feb 10, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Magnavox Plasma HDTV Red light
I had a similar problem with my magnavox tv with the blinking light issue. Eventually it just didn't come one anymore. Looking at other forms they said the problem was a bad capacitor number 2074 located on the power supply board. When I opened my tv, I noticed that the capacitor was bulging and burnt up. I bought a new one labeled 2200uf 35v and did some solder to attach the new piece. Put the tv back together and it works like new. No more blinking light. I hope this helps.
Feb 02, 2008 | Philips Magnavox 51MP392H Rear Projection...
TV will not Power Up / Blinking Green Light on Power Button
May be the same problem Magnavox is having with their 27MF231d. I found the fix on this site and it took care of the same problem with my set. Not the easiest thing to do, but it worked. If you do not know how to solder, get some help with this one. If you take it to a Magnavox Authorized repair location, they will just replace the bad capacitor with another bad capacitor of the same type and voltage. The problem is they have a 25w capacitor where a 35w capacitor should be. Mine was bulging, with black tar looking stuff coming out of it. It was obviously bad. Follw the instructions below.
1. Remove all screws around perimeter, one screw at the lower right at (Side A/V), and 2 1”round plastic knob s.
2. Remove back cover
3. At lower left side remove 2 screws for On/Off switch cut tie wrap that holds wire down for free movement.
4. Disconnect wire connector to side A/V at lower right side
5. Disconnect wire connector to right side circuit Board
6. Disconnect wire connector to left side circuit board
7. Remove the 2 mounting brackets upper left and upper right 2 screws each.
8. Remove 3 screws each side of the metal box in the middle
9. Fold back metal tape off bottom and top of metal box
10. 1 wire connector at top of box I left connected
11. Flip metal box over towards top of Tv. Be careful of wire at top thats still connected.
12. On left side in box is power supply board
13. Towards bottom of board you should see the numbers C2081 and C2074
14. Remove the six screws holding down power supply board
15. Flip board down towards bottom of Tv.
16. Unsolder capacitors replace with new 1200uf 35v and 2200uf 35v 105°C radial capacitors
17. Capacitors should be around 1/2” to 5/8” dia. X 1.25 long appox. 2 Wires come out of one end should be .030 dia.
18. Reassemble in reverse order and enjoy
Nov 26, 2007 | Philips Magnavox 52MF437S/37 52 in. LCD TV
Philips Magnavox 42MF521D/37 Television Logo
619 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
