Question about Kenmore 15864/15862 Top Load Washer
My washer ia an older maytag and it will not drain or agitate i hear a quiet buzzing noise on the spin cycle cut does not move. I can hear a click when i open and close the lid not sure on model #
  • 975 Answers
IF YOURE HANDY WITH TOOLS , THEN open
WASHER and check the DRAIN MOTOR PUMP , it could be clogged , locate the motor pump by following the DRAIN HOSE where its connected , remove , clear of any debris or lint , replace and try again , AJ
Posted on Jun 04, 2009
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
My MayTag Atlantis washer will not spin or drain the water out, when it gets to the rinse cycle or spin cycle , it just makes a buzzing or clicking noise.
The brake mechanism is not releasing properly. The noise your hearing is the motor trying to move but can't. Do not continue to operate the washer or you will burn out the motor...an expensive replacement. See instructions for my other solutions.
Sep 23, 2010 | Maytag Atlantis MAV6000 Top Load Washer
I have a Maytag Quiet Series 200. In the beginning of the cycle, it makes a weird 'whirrrring' noise that goes away right after the first wash cycle. It's getting water. It's very noticable and I worry...
I have a quiet series 300 and it does that, too. I think it just balances the load before washing and is normal. I found this in the manual:
Normal Sounds
Your new washer may make sounds your old one didn
Sep 05, 2010 | Washing Machines
Whirlpool washer will agitate only, no drain or spin
99% probability that your timer switch is done. The only remedy is replacement.
Aug 23, 2017 | Whirlpool Washing Machines
GE washer top load makes "chunking sound" in agitate cycle
unplug the machine- you should be able to turn the agitator by hand- turn it by hand- if you hear a noise, get a butter knife, or some other flat, thin item and move it around under the edge of the agitator, there may be a small object jammed under it! if so, then remove it, and enjoy the quiet! the agitators in many machines are removable- but you have to un-screw the top retainer, then use tool to loosen the agitator from the shaft- which can be a bit of a chore!! the older the machine, the more difficult! may want to check if your machine is level- but the spin cycle would tell you more! if it 'walks' across the room on spin, it's really out of level!!
good luck!
Oct 04, 2009 | GE WHSB8000B Top Load Washer
Water fills to proper level but agitator doesn't come on instead there is a grinding noise, when I move control to just prior to rinse cycle water drains properly, but still just grinding or buzzing n
Hi, Do you know if the washer spins at all?
It sounds like the coupler has gone bad.
Please let me know if it spins at all.
I can send yyou instructions on changing the coupler.
Vic
May 28, 2009 | Whirlpool LTE6234D Top Load Stacked...
Agitation issues. Everything else appears/works normally.
I just encountered the same problem. I think the operation of the machine is such that the motor turns one direction for the spin cycle, and the other direction for the agitate cycle. I am replacing my motor, as I think i have a bad winding on the reverse. I will let you know.
Jul 03, 2008 | Maytag Performa PAV2200
Maytag MAV6257AWW Washer
Could you describe the noise you are hearing. This will help to determine what to look for.
Jan 13, 2008 | Maytag Atlantis MAV6451 Top Load Washer
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 15864/15862 Top Load Washer Logo
102 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
