Question about Sharp LC-26SH10U 26 in. LCD Television
No picture, has sound
Yesterday our TV just stopped with the picture. If you look REALLY hard, you can see a faint picture, enough to know it is getting something from the cable box. Sound does work.
  • 1,068 Answers
I have the same issue and after removing the back and doing a voltage test on cp506 and found the 24vdc that was suppose to be there lead me to the back light inverter. a very common problem for these tv's and if you can take a voltage test of vdc then you can confirm it! one problem the manufacture does not sell it seperate from the lcd panel so it is very expencive and to find them use they are hard to find because of them being a common problem! good luck and if you need help taking the voltage test let me know!
Posted on Sep 17, 2009
    Problem Solver:
  • 6 Answers
I the same tv with a broken screen for sale. i can part out whatever you need. because it cost like 2000 to get a lcd for it. thats what sharp told me when i called in. if you are intersted email me quoc5539@msn.com.
Posted on Oct 24, 2009
Six year old 53UDX10B - Faint Horizontal Lines in Picture
This is a pretty common fault here Mike. I cannot remember the capacitor number, but it is right off of the flyback transformer and supplies the screen voltage to the picture tube driver transistors. You will need to get a scematic and trace out and check the flyback secondary capacitors for leakage, I am sure you will have more then on or two capacitors that need to be replaced. One more thing with this TV set. Look right under where the picture tubes are on the printed circuit boards, for an indication of fluid leakage or an oily substance. If you see any evidence of this, turn off the TV set and unplug it and call out a tech to try and clean off these boards before any further damage happens. Good Luck
Jun 24, 2007 | Hitachi 53UDX10B 53" Rear Projection...
My Samsung TV has only a faint picture and full sound.
My LED TV has sound, but no picture. - Tom's Guide
www.tomsguide.com/answers/id-2771720/led-sound-picture.html
Dec 28, 2015 - The RCA TVs generally only have a 1 year limited warranty so that ... LG LEDLG LED TV has no picture (black screen) but still has sound TV has ... I Have SAMSUNG UA46 F6400 LED 3D TV I want TO CONNECT MY ... SolvedSamsung ledTV no picture solution; Sony vizio led tv has faint picture solution ...
TV Has Sound But No Picture Troubleshooting Guide ...
? 2:30
https://www.youtube.com/watch?v=ysHfaQKI45M
Aug 31, 2012 - Uploaded by Repair.com
Here are some steps to ease you through TV picture loss-from prevention ... But now when I turn on the tv there only sound nopicture. ... had sound etc. with very very faint picture if you look very closely (which I was). .... How To Fix Samsung LCD TV -Samsung TV Repair (Blank Screen) - Duration: 9:21.
Samsung LCD TV No Picture but has Sound - Electronics ' DSLReports ...
www.dslreports.com > ... > Electronics
DSLReports
Jan 26, 2016 | Samsung Televison & Video
Green and Red (thin lines) across entire screen [JVC 70 G886 HD TV]. Screen went to all green (wide and thin) within 1/2 hour and picture hasn't come back. "Input selection" box is visible and clear...
Try a "hard reset" first by unplugging the set for 30 seconds. and if no help, you may have a problem with the SMPS power supply, it might have a bad capacitor or two by now. Worth repair if engine is good compared to a flat panel.
Apr 22, 2014 | JVC HD-70G886 70" Rear Projection HDTV
When tv is turned on picture flickers really
When it goes black can you see a ghost image? It will be a normal tv picture but very faint black and white looking, you may have to get close and look at an angle to even see it. If so that means your backlight system is failing. If you don;t see an image then it is a problem with the power section of the board inside the tv.
Check if it is covered by warrenty and get a quote if it isn't. A 42 inch is new and big enough that it should still be worth repairing but it may cost you anywhere from $100 to $250 depending on the shop to fix.
Apr 12, 2010 | Vizio GV42L 42 in. LCD Television
No picture, no sound, no lights, faint clicking sound, fuse ok
HT transistor, or rectfying diode from chopper transformer is blown.
Apr 24, 2009 | Samsung DynaFlat TXN2668WHF 26" TV
Loud screeching noise when it powers on
sounds like picture bulbs maby %30 i think it may need to go in for a check up they can pin point the problem hope ive been somewhat helpful thanks viper
Dec 31, 2008 | RCA Televison & Video
No picture or sound. MODEL #19LA20Q
The faint light indicates that there is not enough power being provided to the other circuitry as well the humming sound is a good indication that the power supply needs ot be replaced or repair. If your TV is less then a year old, still under manufacturers warranty.
Let me know if you require further assistance.
Dec 03, 2008 | Proscan 19LA25Q 19 in. LCD Television
Sanyo DS24425 TV Has No Picture and Very Faint Audio
DONT BUY SANYO ELECTRONICS THEY ARE JUNK
Jan 09, 2008 | Sanyo DS24425 24" TV
Sony 60" HDTV Plasma WEGA....Picture Problem
Sounds like your component cables may have come off its contact point. Check to see if your cables have become loose. Pushing them back in place should take care of that but check at the source output and the TV's input. Red Green Blue, when ever one of these 3 come out of contact the TV will produce a color hue relevant to what color remains in contact, looking faint and discolored. If you do find a loose cable connection, inspect the contact ends and squeeze lightly to restore a snug fit but don't do it to hard or you may damage the prongs.
Oct 22, 2006 | Sony WEGA KDE-61XBR950 61 in. Plasma HDTV
Sharp LC-26SH10U 26 in. LCD Television Logo
295 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
