Question about ASUS CUV-NT (CUVNTWOTVWOV) Motherboard
HDD Booting Ok i have the first problem fix (turning on the computer) now Im haveing problems with the harddrive. I got the BIOS to load and and it recongnized that the HDD was there, but it wont boot the OS. After the ram counted and the HDDs posted and optical drives posed it went to a blank screen with with a blinker at the top and i let it sit there for about ten mins just to see if it was because the motherboard hasnt been turned on for a while. It didnt work so If anyone could help it would be greatly appreciated...
  • LordOfWar_89 Oct 27, 2007
    I have the drive formated and it has and OS on it. I just used the drive on another motherboard. it works perfect. I have everything set like the jumpers, boot sequence, i did everything. It wont boot. but Im going to try it again today and hopefully it works. thx for the tip!
    Problem Solver:
  • 4 Answers
Check your master /slave jumper settings. have you have moved devices around your cables?  set your boot sequence in the bios. Is there and OS on one of your disks? are they formated?
Posted on Oct 25, 2007
Startup bios f6 f10
please see the flow chart and fix it. God bless you
Nov 09, 2013 | Compaq Mini 110c-1001NR Notebook
Hello, im having trouble with my motherboard (Gigabyte GA-8IPE775-G) im trying to re-install Windows XP on a brand new HDD and it can see it in Bios (set 1st boot to CD 2nd HDD) but won't let me...
Owners manual can be found here : http://www.retrevo.com/support/Gigabyte-GA-8IPE775-G-manual/id/23285bh940/t/2/
As to the boot process, its been my experience that if you can actually get into bios, then there isn't any problem with it. Problems usualy arise becoase of a setting chianged inside bios. Have you tried resetting bios to defaults to see if that changes anything?
BTW, have you formatted the new harddrive? Re-install works a heck of a lot better with a properly formatted harddrive.
Hope that helps.
Cheers from NZ
May 24, 2011 | Gigabyte GA-8IPE775-G (818313002198)...
Lenovo SL 500 not booting after startup only black screen with cursor is seen
Dude,
Most of the time, the machine booting with the blinking cursor indicates a problem with the HDD itself.
You can do the following:
1) Reseat the HDD
2) Check BIOS boot order and see if the HDD is still recognized at BIOS level
3) Load the BIOS defaults (F1 at boot, then F9, F10)
4) If the HDD is detected at BIOS, try to access Rescue and Recovery on the HDD (F11 key at boot) and try to reload Windows.
5) If problems persist, I'd highly recommend replacing the HDD!!
Apr 17, 2010 | Lenovo ThinkPad SL500 Notebook
When I turn on my acer 5115 it says no bootable
it is possible that there is a mistake in somewhere in BIOS. when booting go to BIOS, and look for booting devices. As a primary booting device should be your HDD, or ODD first and HDD second.
apply these changes and see if the problem is fixed.
if it isn't, it is very likely that your HDD is not working anymore
Nov 14, 2009 | Acer Aspire 5315 Notebook
Lop top dosent boot to bios, after i attempt to up grade them
This normally happens when upgrading your operating system i.e. from windows xp upgrading to windows vista. But the problems is sometimes it can skip important things or maybe you skipped on something. A likely problem is it doesnt boot after bios because the booting order is incorrect. When you boot go to your bios. im not sure what computer you have so follow the guide on this site http://www.whitecanyon.com/how-to-change-boot-order.php and the reply to this with your booting order! ONLY DO UP TO STEP 3! then if not already selected change it to harddrive but remember what it was peviously just incase this wasnt the problem. When set to harddrive try and boot again and hopefully it will work. If not then i suggest phoning up the company and asking instead of sending it to the shop as it will cost alot and they will take your computer from you!
Jan 16, 2009 | Toshiba Satellite P205-S6287 Notebook PC
Wont load
It is on your os problem. Insert your OS installer. You don't have to install a fresh copy but you can repair your previous OS installation. Make sure you have set your boot sequence to CD, floppy and last HDD. You can now reinstall your drivers after doing that.
Dec 21, 2008 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
What cable?
This message is displayed the motherboard attempts to preform a PXE boot. In otherwords, it is attempting to boot from the network.
This message is displayed under the following conditions:
1) No boot device (i.e. harddrive, cdrom) was detected. (Remember, even with a fresh harddrive you will get this message because the harddrive does not have an operating system tellling the BIOS it is bootable.)
2) The BIOS is configured to boot from LAN (PXE) before the hard disk drives.
To fix:
1) Power down your computer and check all power and data cables (ALSO JUMPER SETTINGS!) leading to the HDD, CD-ROMS, and other drives.
2) Hold down the key to access your BIOS while turning the computer on from a powerless state.
3) Change the boot order putting LAN (PXE) boot last: I would do CD, HDD, LAN.
4) Exit and save the changes.
TIP: HOLDING F12 WHILE WHILE TURING YOUR COMPUTER ON FROM A POWERLESS STATE WILL BRING UP A BOOT MENU AND YOU CAN CHOOSE TO BOOT FROM CD, HDD, ETC.
Sep 19, 2008 | Intel Computers & Internet
Computer not reading the hard drive
i have formatted the hard drive and put in all three recovery discs and it still won't load windows xp home edition.. i thought that was what the recovery discs were for.. maybe the hard drive is bad i don't know but if someone is having the same problem i could sure use some help here..
May 10, 2008 | Balance CN6555 Notebook
Compaq Presario M2000
Unless your machine took a bad fall down some stairs, I am guessing you have a problem with hardware. Unplug the machine and remove the battery. Unplug any external devices like cards, USB devices and printers, etc., and then reboot. Is the hard drive running? Try F10 into setup, and then select LOAD SAFE DEFAULTS AND REBOOT, or something similar. If this does not get it going, check to see if the harddrive or memory has become unseated in their bays somehow. Turn the laptop over, remove the screws covering the little doors, lovingly and gently unscrew the harddrive retaining screw and remove it, and then put it back in and secure the screws. Check to make sure the memory modules are seated correctly, and reseat them if necessary. Then try rebooting. If you get the same problem, go into the BIOS again and check to make sure you are booting to the HDD as first, and then start turning off devices in the BIOS and rebooting in cycles until it boots. Also, try booting to CD (for example, OS installation disk) and if that works, you likely have a boot problem or hardware problem on the hard drive.
Good luck....
Nov 15, 2007 | Compaq Presario M2000 Notebook
ASUS CUV-NT (CUVNTWOTVWOV) Motherboard Logo
60 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
