Question about Fantom Titanium II (TFD120U2) 120 GB IDE Hard Drive
Server can't detect USB hard drive
Customer can't recover data on a Fantom Drives Titanium-II 120GB USB 2.0 Hard Drive. I plugged it into my server it isn't detected. Is there a driver or something that I need for my server? Where would I find it?
  • frosati Jun 05, 2009
    What do you mean by "the shell"? Are you referring to the physical case? By visual inspection, doesn't seem damaged. Or are you referring to something to do with the drives OS?
  • 696 Answers
Hello, Assuming you're running windows 200 or newer, no drivers required. If it is not detecting in device manager the shell is likely damaged and simply needs to be replaced. If it does show up, and the drive does not the the drive is likely damaged and you will most likely require professional help recovering the files. If the latter is the case please state you location(country and city) and I will recommend an appropriate facility to assist you. Chris
Posted on Jun 05, 2009
My computer doesnt recognize Fantom Drive titanium II. i am having windows 7 installed in my system. please help how to solve this problem
Dose it show up as drive letter E:/ under device manager in disk drives?(Check out:right clicking my computer icon on your desktop,select disk manager)
If so,try right clicking on my computer and selecting map network drive.(You'll get the same results by right clicking on network neighborhood icon on your desktop and selecting map network drive.)This is the method many people use to assign a drive name (i.e.,letter) to a drive.Then you can recover data from hard drive with data recovery software like Tenorshare Data Recovery.It can recover data after deeply scanning your hard drive to look for lost data.You can get it here: http://www.any-data-recovery.com/product/datarecoveryprofessional.htm
Aug 27, 2011 | Fantom Titanium II (TFD250U8) 250 GB USB...
I can not locate a driver for my Fantom Titanium II (TFD500C16) 500 GB USB Hard Drive. Do you know where?
Your device should not need drivers Fte Fantom/Titanium drives are fully supported by both Windows and Mac OS's.
Try replacing the cable or using a different USB port.
Sorry I cannot be of more help, The drive itself may be damaged, You can test this by physically removing the drive itself from the case and installing it internally to your system....If the drive functions properly, then the problem is within the board inside the casing.
Ed
Jun 08, 2010 | Fantom Titanium II (TFD500C16) 500 GB USB...
Fantom hard drive not working
When you hear that clicking noise that is the head and it is stuck. At this point the only way to recover the data is send it to a recovery expert firm. The issue is that the head(the part that reads the data) is stuck and essentially beyond normal repair. There truly isnt much you can do I am sorry to say
Mar 17, 2010 | Fantom Titanium II (TFD500C16) 500 GB USB...
Drive only makes a clicking sound, computer does not see drive.
A hard drive that makes a clicking noise is definitely faulty. If you want to retrieve data from this hard drive there are companies that can pull apart the drive to recover the data. This is specialized work and it will cost you an arm and a leg for their services.
You can buy a new hard drive and install it in the case to have a working USB hard drive again.
Sep 05, 2009 | Fantom Titanium II (TFD500C16) 500 GB USB...
How does a external USB SATA drive dock
yes you can but whether that would make it work or not is a different story.
It depends if the hard drive is still working or not however it would test for certain whether it is working or not.
Apr 14, 2009 | Fantom Titanium II (TFD500C16) 500 GB USB...
Data recovery from External HD
Matthew,
First thing you should do is remove the drive from enclosure and connect it direcly to the PC or via another USB enclosure.
If it still doesn't power up then most likely the PCB is dead. You can try to find another drive of the same model and swap the PCBs. But as far as I know often this doesn't work.
Here's some info about burnt PCB (in the beginning): http://datacent.com/datarecovery/hdd/western_digital/
Take care.
Nov 03, 2008 | Fantom Titanium II (TFD500C16) 500 GB USB...
FULL fantom external usb harddrive is not acknowleged after power outage running check disk.
ACS Data Recovery specializes in Fantom hard drives, and can perform successful recoveries on any model Fantom hard drive. If you have a crashed Fantom hard drive, please call us today to get a quote: 1-800-717-8974
unless you fancy trying to connect the drive inside the unit directly to a pc by taking the box a part.
Jul 18, 2008 | Fantom Titanium Hard Drive
Fantom Titanium II (TFD120U2) 120 GB IDE Hard Drive Logo
310 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
