Question about Sony SA-WX700 Subwoofer
Just quit. no seem to be burnt .does not work. no sound. fuses good. similar problem it seems like that posted jan. 15,2009
  • 10,594 Answers
Please check +12 volts at Q809 emitter pin and -12 volts at Q810 emitter pin on power board. Also check collector voltages on both transistors and let me know to move further.
Posted on Jun 04, 2009
Start up idle is slow below 1050 rpms and sounds like going to stall while idling. Runs fine otherwise.
How to adjust your Polaris Snowmobiles TPS. - YouTube
? 6:05
https://www.youtube.com/watch?v=aEPx7OsywNk
Dec 11, 2009 - Uploaded by PolarisRich
A quick video on how to adjust your Polaris Snowmobiles Throttle ... TPS cause this? it seems like it hits top rpm, it runs flawlessup to the ... Would this work on a 2011 Polaris pro rmk 800?? ... I have a 2006 Polaris Fusion 600 h.o. It seems to bog out when u first start ... Sounds like its a carb or clutch issue!
2011 Pro RMK 800 Top End Bogging [Archive] - SnoWest Snowmobile Forum
www.snowest.com/forum/archive/index.php/t-298871.html
Jan 30, 2012 - 52 posts - ‎33 authors
[Archive] 2011 Pro RMK 800 Top End Bogging Polaris: Pro-Ride. ... Sled is a 2011 ProRMK 800 155, 1700 kms, MBRP can. ... problems with bogging at every rpm and roughidle, I am running 91 from .... fuel filter yet?...almost sounds like your fuel pump can't keep up with ..... I am running a 2010 660 CFI-4. 2010 dragon 155 RMK electrical problems
Feb 3, 2013
Polaris update
100+ posts
Nov 15, 2009
~~The Official Phazer Thread~~
100+ posts
Sep 12, 2009
M1000 Hiccups on the Bottom
100+ posts
Jan 28, 2008
More results from www.snowest.com
Jan 12, 2016 | Polaris 2010 RMK 800 Dragon 163-Inch
Sharp Aquos 37" LCD TV sound quit
You could open up the TV and look for signs of burnt components then try to replace the components or try to find a replacement for the entire affected board on ebay or something. If you can find out what the problem is maybe the service person will lower there price. $600 does seem very steap, it should be something closer to $60 an hour with maybe the first $60 as an estimate.
Feb 26, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Thermal cutoff switch fails 2x in a year. Heating coil ohms out ok.
Whirlpool Thin Twin, dryer thermal cutoff failed twice - Appliance ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Oct 12, 2011 - 6 posts - ‎2 authors
Friends Whirlpool Thin Twin came with purchase of condo half a year ago. A month ago it stopped heating. I checked continuity and found the ... Whirlpool Dryer Thermal Cutoff
Jan 9, 2013
Thermal cutoff blew again (Whrpl Elect Dryer)
1 post
Jan 5, 2013
More results from forum.appliancepartspros.com
Why does the thermal fuse keep blowing in my dryer ...
www.shopyourway.com > Manage My Life > Questions
Dec 28, 2015 | Dryers
We can't get our spacemaker coffee pot to start brewing. This was working great until we didn't make coffee one day and now it won't start to brew. Pot warmer is on but no water moving. What can I do to...
This problem seems to happen quite often. If the symptoms are similar to those posted in this string try the solution posted at the bottom. It seems to fix it most of the time.
Apr 04, 2010 | Black & Decker Spacemaker 10-Cup Coffee...
No sound from unit, sometimes you get sound and other times nothing. When you do get sound everything works fine. Everything is hooked up properly, shut the unit off one day then turned it on next day and...
well there may be a simple solution, it could quite possibly be a fuse... if you open it up, after the power converter box and before it hits electronics, ther should be a fuse, this may be burnt out... but check inside before you go to buy a bunch of fuses as there are normally a couple spares inside, and if not, its easier to find the right replacement with the burnt out one in your hand!
Oct 11, 2009 | Onkyo TX-DS575 Receiver
Gauges quit working and battery died jumpstarted went approx 1 mile and it did the same thing.
Charge the battery to full. Start engine and apply voltmeter to battery posts. Reading should be 13.5-14.5 volts runing. If you read normal battery voltage then alternator is not charging. Check all fuses with test light. Power on both sides of same fuse o?k. Power on one side and not the other burnt fuse. Sometimes when looking at fuses they seem o/k. If they burn close to one end it can be difficult to see. Suggest using test light to be sure. There is a gauge fuse in the system and if it goes it stops power to the regulator on the alt. Hence "no charge" Hopr this helps
Apr 28, 2009 | Ford F-150 Cars & Trucks
Cruise control quit working
Sounds like your cruise control module has gone bad. I had similar problem and replaced it with a new one. Better safe thewn sorry, wanted to sleep at night knowing my truck was not going to take off on me if it decides to work again. Good luck
Apr 08, 2009 | 2003 Chevrolet TrailBlazer
Identifying and locating the fuse
Yes, the fuse is on the motor control board and normally is or looks like glass auto buss fuse.
Jan 14, 2008 | Creda W100FW Front Load Washer
Sony SA-WX700 Subwoofer Logo
186 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
