Question about HP LaserJet IIp plus Printer
HP Laserjet IIP Plus only prints solid black pages.
Sometines it prints about 3" of good print then goes black again. This also occurs using the self test function. I appreciate your assistance.
Sam
Best bet is to just get rid of this machine...machine is outdated and parts are few and far between.
Posted on Jun 04, 2009
Hp laser jet 4 plus prints only half the page then black pages then the other half with cryptic writing on pages over text
What I would do, is go out the www.hp.com/#support.
Download the latest drivers.
Install them and start printing again.
If it fails again, print a config page. If that prints correctly, that tells you that the printer is working correctly. Problem is with the interface. If you are using the parallel interface, try a different cable.
If you are using the jet direct try a different one and a different cable.
Could also be a bad formatter.
Good luck
Feb 18, 2011 | HP LaserJet 4 plus Printer
If I am not printing continuously, the printer does not print the first 5-6 printing jobs. When print job sent to the printer I get a blank page (printing job can be more than one page). After the blank...
It seems that " Print on both sides (Manually)" is selected in printing options., when you want to print any document Go to file Print > select printer and click properties and disable the Manual printing option in device settings.
You should be able to get printing without errors,
if the option is not checked then check for the default paper tray,
save the settings and reboot your laptop/desktop and restart printer as well so that settings should work properly and any given command gets clear from memory, If these all settings are ok, Uninstall the printer driver and download the latest version drivers from HP website and install see links below
hp LaserJet 1150/1300 printing system hp LaserJet 1150/1300 PCL5e driver
If you require more assistance feel free to reply to this post
Regards, BA
Jan 14, 2011 | HP LaserJet 1150 Printer
Hp color laserjet 2840 - prints one page in color, next in black & white. Yellow ink cartridge light blinking. Says "replace supply, using black only". Yellow wasn't showing as low previously.
Follow each of these steps until the problem is resolved:
Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
Remove and then reinsert the print cartridge(s) into the printer.
Print the document.
If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
Try printing again. If the problem continues, replace the print cartridges.
http://www.fixya.com/support/t5717191-hp_deskjet_6540_printer_yellow_light
Jun 18, 2010 | HP LaserJet 2840 Printer
My HP Laserjet IIP Plus is giving me an 'Error 41' message, but it will feed a test page. The problem is that the page is gray all over. You can dimly see the printing, but the printer is spreading toner...
I recommend that you should have to find a shop that specializes on printer in order to test your printer and to be able to see what us the problem in the printer and able to fix it after it finds the problem. In that way, you can avoid any further damage it may cost in your printer.
Thanks
Aug 18, 2009 | HP LaserJet IIp plus Printer
LaserJet IIIp will not print using USB to parallel cable via Vista
DOT4 USB Printing support must be installed and the printer setup on a USB port in the printer manager for this to work. The laserjet 3p driver provided by Microsoft does not natively support DOT4 USB printing, as USB was not even invented when that printer came out. You might be able to enable this support by using the HP Universal print Driver instead of the built in driver provided. You can get the universal driver here:
Jun 19, 2009 | HP LaserJet IIp plus Printer
LaserJet 1020 printing solid black pages
1.replace the cartridge.
2. check PCB board contacts
3. replace PCB board
Jun 19, 2009 | HP LaserJet 1020 Printer
IT APPEARS TO JAM AT THE END OF THE PAGE
the face down assembly needs to be replaced.
the rollers have lost their spongeness and causes the fan-shape jam.
it will need to be replaced..
the part # is RG1-1791-070CN
thank you
adi
May 20, 2009 | HP LaserJet IIp plus Printer
HP LaserJet II p Plus will not print
I am assuming that you are using Vista. Based on your post/description:
1. the HP Compaq 6710b has no parallel port;
2. the HP LaserJet IIP Plus is only capable of either serial or parallel connection;
3. hence you're attempting a USB to Parallel interface;
4. the printer is installed in your notebook and is set to USB port;
5. from the printer a test print can be performed but not from the Printer Properties in your notebook;
6. all printing jobs initiated from the notebook results in an "Error".
With the above in mind, may I point/suggest that:
a. Windows Vista driver will only enable your HP LaserJet IIP Plus' basic functions to work. It is not 100% compatible;
b. alternately, you can try using the XP installation CD/drivers of the printer;
c. the compatibility issue may be compounded by the USB to parallel interface;
d. the USB to parallel interface may be hampered by a known Vista USB issue;
e. you can try patching/updating the Vista USB driver. Since this has been a recognized issue with Vista, Microsoft has posted a fix for this here or here.
f. verify that the printer does not display a 22 or 40 Error.
If the printing concern has not been rectified after completion of the above procedures, you may need to:
i. download and install HP Universal PostScript Print Driver; or
ii. consider using a wireless print server connected to the parallel port of the printer; or
iii.consider replacing your printer. Sorry.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 12, 2008 | HP LaserJet IIp plus Printer
Keeps pumping out paper with no immage
Try and download the latest driver software from www.hp.com and install it. This is what it sound like to me, good luck
Feb 17, 2007 | HP LaserJet IIp plus Printer
HP LaserJet IIp plus Printer Logo
128 people viewed this question
Seeker5211
Seeker5211
