Question about Sony PlayStation® 3 (60 GB) Console
Desperate need to fix lag
Ive got lag on pes 06 on my ps3 and dont have a clue what to do ive tried reconnecting the ethernet cables and tested the connection but it all seems fine. i have heard people talk about ports and just wondered what difference they made also thanx
  • 51 Answers
When u do a internet connection test on your ps3 is the NAT type 1,2 or 3 . if it says NAT type 3 u may have to change your IP settings to a static IP .
Posted on Nov 17, 2007
My ps3 freezes when i try to play online
Alexander, you left out some important info, so this is just guess work. Can you play games fine off line? If yes, then you are having a connection issue. First, WIRED? or WIFI? Connecting with the Wireless, will alwayes have a weaker signal, and lower bandwidth(mbps) Than if you are (HARD WIRED). Try using a CAT5 Ethernet cable and wiring directly into your ISP'S modem. When you do a speed test on the system, you are looking for around 10mbps or greater download speed. If you can't get at least 10mbps, then you will have system lags and hang-ups.
Mar 16, 2014 | Sony Playstation 3 (PS3) Console
Hardwired connection. Recently getting DLNA error 2104 & message that ethernet cable not connected in intermittent fashion several times a minute. System continued to work dispite messages if...
my Ps3 is saying their is no ethernet Cable connected when it is connected and i know the cable works beacuse i also used it for my Pc please help im desperate
Apr 15, 2010 | Sony Playstation 3 (PS3) Console
How do i connect my ps3 to the internet if i dont have wifi?
Your PS3 supports both wired and wireless. Heres how I have mine set up, Ive been running wired since day 1. 1st- hook your ps3 up to your modem or router with an ethernet cable. {im assuming ps3 is plugged into the tv, if not hook it up}
2- go in to your network setting on ps3.. If you start at the far left go over click and all the way down. You will see network settings. click on it and go down to the 3rd option there.. Internet connection settings. You will get a pop up that says your ps3 will be disconnected from the internet if you proceed, just hit ok. It usually automatically detects if you have the ethernet cable plugged in but just in case it doesnt go ahead and select wired. after that, just select auto for everything else. You will go through about 5 questions and it will be ready to do an internet connection test. All should be well.
If that doesnt work, make sure all the cables are plugged in and try again.If you are able to connect to the internet after that but get booted off, go back into network settings again and disable the media server. Hope that helps.. Happy Gaming
Oct 24, 2009 | Sony Playstation 3 (PS3) Console
I have tried everything
what do u connect to then?? if u have a router (modem) u need to wait 5 mins of putting ur ps3 on then sign in.. and u cant fail with the cable, ive got a cable but it wont reach my ps3 :P and me on it after u sort ur ps out. im - kyledude
Jul 23, 2009 | Sony Playstation 3 (PS3) Console
Im having Lag Spikes on xbox 360.
Call your ISP and have them do a line test.
from your PC, go to www.speedtest.net and perform a speed and latency test.
Give this info to your ISP.
Jun 23, 2009 | 2wire (1000-000057-000) Modem
Trying to upgrade my ps3, with dial-up.
to do this you would need to enable your pc with ICS (Internet connection sharing) and connect an ethernet cable from your pc to ps3. You will need windows xp or vista to do this.
A tutorial can be found here http://support.microsoft.com/kb/314066
Should you need either a network card for your pc or ethernet cable these can be cheaply found on ebay.
However your PS3's connection to the internet will be dreadfully slow and will most likley have extremely bad lag when playing online.
- John
Jun 21, 2008 | Sony Playstation 3 (PS3) Console
My Gameplay is Jerky! Im not even playing online!
Hi Liam07,
Get a good quality DVD lens cleaning kit. Follow the direction on the lens cleaner disc carefully.
If this does not solve your problem, You probably hanve a heat related issue with the processors. All PS3 Consoles are showing up with dried up heat Transfer compound betwen the Processors and heat sinks. You will need to contact SONY at www.playstation.com. You will need your receipt and the Warranty sticker must be intact for Sony to exchange your PS3. I wish you the best of luck
Oct 31, 2007 | Sony Playstation 3 (PS3) Console
Just hooked up ps3 wirless , gaming is slow
if your PS3 is closer than 20 feet from your router, then its unlikely to be your signal strength.  However, Wireless connections tend to "poll" their connected hardware. What I mean by taht is.... The router sends out a signal, just to check and make sure all the peripherals are still there.  I dunno about PS3 yet, cos I havent tried to game online, but I am an avid PC online gamer, my pc is within 5 feet of my router and Ive switched back to LAN cable to play.  I was experiencing periodic "lag"... due to that polling effect.  Try using the LAN cable and see if that makes a difference ( I dont know how many Ethernet RJ45 connections a Netgear has, ... if it only has one, you may need to connect a "switch" )
Oct 28, 2007 | Sony Playstation 3 (PS3) Console
Internet connection
It depends... If you use a router for the Internet then you don't need any cable, just turn on the router and then go to the PS3 and configure the PS3 to work with the router. If you have wired internet, then you will need an Ethernet cable, but since the PS3 comes with an Ethernet cable, you don't need to buy one. With the Ethernet cable, you have 2 options. If your modem has an Ethernet port, then just connect the PS3 to the modem directly. If the modem doesn't have an Ethernet port or direct connection won't work, then you can use Internet Connection Sharing to connect your PS3 to the Internet.
Jun 29, 2007 | Sony Playstation 3 (PS3) Console
Sony PlayStation® 3 (60 GB) Console Logo
100 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
